Old 17th February 2006, 10:44   #1
Thanked: 9 Times
Default Engine jerk/glitch
Well well well....the first real problem (still may turn out to be a false alarm) I have had in my car in about 9000 kms...
I started out at 8am yday morning...and the car gave a coupla jerks while in low rpm...I was like maybe due to the cold engine but when I was in neutral at a signal I noticed the rpm was wavering/ up n down from abt 800 to 650 (rough since the tacho has a least count of 250 rpm)..which was quite low and the engine was jerking on its own...then in any gear I shifted this would happen til the rpm rose to abt 1.5k.. I have never had any engine jerk problems till y'day and I was kinda worried. I reached office and decided to show it to service guys (car had its 2nd service just last week)
In the evening though it seemed to lessen and at one point on my drive back it suddenly disappeared completely ! The car was able to stay in low rpm in 3rd or 4th gears in traffic like it usually does and I was kinda relieved.
Also when it was jerking earlier I noticed a lack of power too as the rpm would not rise quickly when I pressed the throttle.
Should I show this to the mechanics even though now there doesnt seem to be a problem? What could be the reasons though?
Bad fuel ? ( I filled last saturday at HP pump on University Rd opposite Agriculturel College - Pune ppl will know this...) ECU problems ? Sensor or what.....since it seems to have rectified itself I am thinking poor fuel....experts ?
Abhay is offline   Reply With Quote
Old 17th February 2006, 11:04   #2
amitoj's Avatar
Thanked: 1,691 Times
A bad fuel problem wont take almost a week to show up (since u filled on saturday and the problem showed up on thursday), unless you didnt take the car out until thursday!
Isnt ur car almost due for servicing ?
amitoj is offline   Reply With Quote
Old 17th February 2006, 11:42   #3
Zappo's Avatar
Thanked: 2,079 Times
Abhay... I think what happened was that some piece of accumulated junk (could be carbon deposit or any other floating deposits) broke loose. This was hindering the flow of fuel to the engine thus causing the jerk. Once it cleaned up the vehicle stopped jerking. The fact that it was jerking even when you were parked on neutral only makes me more suspiscious.
I would say you take the car once to the servcie station and tell them the problem as well as ask them to check the fuel tank for any sort of accumulated debris. If something manages to clog some fuel line permanently or worse still some smaller particle lands up inside the engine it may not turn out to be such a good experience.
P.S. Sometimes even air blockage can cause the engine to jerk till it escapes.
Zappo is offline   Reply With Quote
Old 17th February 2006, 13:20   #4
2fast4u's Avatar
if you have tanked up recently just see to it that the petrol cap is closed properly. and as zappo says its not getting proper fuel, blocked line / air / grime in the line. just keep observing it or if u r in doubt visit the service guys.
2fast4u is offline   Reply With Quote
Old 17th February 2006, 14:36   #5
Originally Posted by Abhay
I was in neutral at a signal I noticed the rpm was wavering/ up n down from abt 800 to 650 (rough since the tacho has a least count of 250 rpm)..?
i am no expert but, i did face the same problem with a 5 year old car. the problem engine needed to be tuned, they even did a temp job where the Mechanic ajusted the axel cabled located near your engine!
ancer is offline   Reply With Quote
Old 17th February 2006, 16:09   #6
Thanked: 9 Times
amitoj, I did drive the car on Tuesday and no problems then.....btw car was serviiced just last tuesday!
afast4u , I will check the fuel cap just in case, and yes I will ask the service guys too...
Old 17th February 2006, 17:27   #7
2fast4u's Avatar
THERES u are now. well if it was serviced then its some error on mechanic part.
1) check oil level if it was changed - i had similar problem just a month back due to excess oil filled.
2) check air filter if all is secure. hoses etc
3) engine needs to me timed - mech can help u on that.
Old 19th February 2006, 22:52   #8
turbo_c's Avatar
Thanked: 7 Times
Had a similar problem in my MPFI Esteem some time back... Mine was caused by a loose fuel injector connector.
Im not sure if your Indica runs on petrol, but if it does you can try what I did:
In my case, one cylinder was not firing consistently, I figured that out from the feel of the engine and the noise from the exhaust. To confirm, with the engine running, I momentarily disconnected the spark plug of each cylinder (one at a time). Every time I disconnected the spark plug of a cylinder that was firing correctly, the engine would become (more) unsteady. Finally, when I disconnected the spark plug of one of the cylinders, the engine didn't get any more unsteady... so this was my "faulty" cylinder.
I reconnected it's spark plug cable after ensuring that it was indeed getting power (by allowing the free end of the cable to spark against the engine block), then started fidgeting with the fuel injector connector and viola !
Once I identified the problem, I just cleaned out the connector with WD-40 and my engine has been purring like a dream for the last 4 months. (Still, I carry a small can of WD-40 just in case )
- T u r b o C -
turbo_c is offline   Reply With Quote
Old 19th February 2006, 23:01   #9
nitrous's Avatar
Thanked: 285 Times
I've had this problem before and have heard a lot of people having this.
Ignition Coil. This happens because of a faulty coil which renders 1 or more spark plugs to misfire.
Check and replace if needed.
PS: U didn't mention what car this is.
nitrous is online now   Reply With Quote
Old 19th February 2006, 23:37   #10
Mpower's Avatar
Thanked: 1,687 Times
Nitrous, check out the signature, its there. Lgi is petrol?
Old 20th February 2006, 00:02   #11
nitrous's Avatar
Thanked: 285 Times
Oh, Mpower. I forgot to check his signature.
Then, he must still be having his warranty. But, i'm not sure if tata provide warranty for electrical parts. Ford doesn't.
Old 20th February 2006, 12:09   #12
Thanked: 9 Times
its an Indica petrol indeed!
Yes the car is under warranty and I have given it to the service guys again y'day..He said it will be ready today.
Thanks for the suggestions I will let you know what the problem was when I find out myself....
Old 2nd July 2006, 20:58   #13
sajo's Avatar
Thanked: 1,064 Times
I think this is a recurring problem with Tata petrol vehicles. Both the Indica we had and the current Indigo have developed slight jerking, similar to that mentioned by Abhay. The Indigo is just back from servicing, and the problem is still there. Will send it back again on Tuesday. And on both cars, the problem was particulary pronounced in the monsoons. I wonder why..
sajo is offline   Reply With Quote
Old 2nd July 2006, 23:18   #14
heelntoe's Avatar
i agree with sajo. our brand new indica xeta is having starting trouble in the mornings and after it has started it will jerk until driven for a certain distance(just reving it will not make it go away). will be taking it in tomorrow to see whats up
heelntoe is offline   Reply With Quote
Old 2nd July 2006, 23:27   #15
sajo's Avatar
Yups..the jerking goes away after some time, but not necessarily so. As heelntoe mentioned, it does not disappear by revving it. Could it be an ECU fault?
@Abhay : What was the cause as told to you by the service station?
SWIFT Petrol Engine jerk subbarao Technical Stuff 25 18th June 2012 21:07
Gear linkage glitch ! EFF-EIGHT-BEE Technical Stuff 2 3rd August 2010 23:08
ikon ac: water condensation & engine jerk silver_shadow Technical Stuff 2 5th May 2008 19:10
glitch with number of posts. heelntoe Shifting gears 1 3rd May 2006 00:06
And so it happens...First electronic glitch in the C220 GTO Technical Stuff 30 4th April 2006 22:16
