Old 6th October 2011, 22:36   #16
dot
dot's Avatar
Thanked: 714 Times
Default Re: Vento AT acceleration problem
Originally Posted by noopster View Post
My friend is still not 100% convinced- he has been driving it and says it still doesn't match the performance in its early days, but since the VW folks are adamant that the problem is resolved and ONLY if it recurs will they consider the last resort: replacing the transmission completely (at their own cost), he is OK with it. That was the solution that Raosaheb and others had offered.
Glad to know that the issue might have been resolved. Maybe your friend can go for a 0-100 type test and see if the car is giving back numbers that it should. I cant imagine that the tranny has bust due to hard braking.
dot is offline   Reply With Quote
Old 7th October 2011, 00:41   #17
BuRnT RuBbEr's Avatar
Thanked: 11 Times
SO, isn't this self learning gone wrong? i mean, an occasional incident of hard braking is fair enough and expected in indian conditions at least. If this sends an AT box into limp mode of sorts, what should one make of the robustness of the gearbox that requires such protection?
BuRnT RuBbEr is offline   Reply With Quote
Old 7th October 2011, 08:09   #18
Thanked: 1,083 Times
Right. This sounds like a ridiculous problem. Don't VW test their cars?
How about asking your friend to brake very very hard from 120kmph once again?
And how about doing the same on a TD car (Vento AT)?
anandpadhye is offline   Reply With Quote
Old 13th October 2011, 11:23   #19
rxpaul's Avatar
Thanked: 100 Times
I think this is a good suggestion. Your friend should request VW to test drive one of their AT test drive cars (in his presence) with hard braking at 120 kph.
rxpaul is offline   Reply With Quote
Pulsar 180cc Acceleration Problem Wayne D Motorbikes 25 17th December 2014 09:58
Esteem jerky acceleration starting problem...help devp24 Technical Stuff 27 18th November 2010 12:50
Bajaj Avenger 180cc: Unresolving issue with acceleration (Not a carburetor problem) Mansha Motorbikes 36 20th August 2010 12:02
$1M prize for identifying car acceleration problem bj96 Technical Stuff 0 3rd March 2010 15:40
zen acceleration problem hellspawn Technical Stuff 3 10th September 2005 11:15
