| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Feb 2006 Location: New Delhi
| Hello.. i have a safari about 2 years old. The problem is that the brakes are really underpowered and get ruined in 2-3 months. i was wondering if there are any performance brakes which i can get fitted in the car. the stock brakes are 271mm ventilated disks. Another problem is with the steering there is alot of play and turning left is more responsive than turning right, is there any way it can be fixed or atleast improved somehow.any information would be highly appreciated. |
| | #2 (permalink) |
| Senior - BHPian | hi there, abhishek. you say your safari is 2 years old- so it's a 2004 model, then. tata had sorted out most of the safari's glitches by 2004, with little left to complain. firstly- is yours a 4x4? because if it is, it affects the turning radius and steering characteristics. especially when you engage 4x4, you'll find that the car refuses to budge from a standstill when the steering is under full lock, either to the left or the right. even under 2wd mode, the standard feel is slightly different from that of the 4x2. as for the play, your steering pivot arm bush might be worn out. get it checked. also, check the power steering gearbox for adjustment. as you already know, the front discs are ventilated solid 271 mm dia discs, with the rear having mechanical expanding shoe type drum brakes, incorporating an lspv. the thing is, you don't get many aftermarket systems for the safari, mechanically. the only thing you can try is overhauling your booster, change the diaphragm/felt, and check the vaccuum lines for any leaks that might be causing the sluggishness in the brakes (actually, my safari's brakes used to feel pretty okay, and were upto the task of hauling the 2 tonne beast down from speed). if you feel that everything is fine with the stock brakes, then i'm afraid there's pretty much nothing you can do. but since since you mentioned that your brakes get ruined in 2-3 months, there's definitely something amiss. the front callipers might not be free, and the pads might be binding to the disc all the time, causing the discs to overheat and hence, brake fade. try getting the front callipers overhauled, and get the tandem cylinder kits for the rear drum brakes changed. your authorised tata mechanic should be able to do that for you. still, if you are interested in aftermarket enhancements for the brakes, i'm afraid you'll have to spend a lot of money for getting the parts and modification work. you'll need to get brembo kits with four-pot callipers (if my memory serves me right, i'm guessing the stock ones are two-pot), and matching rotors. all this, alongwith the labour charges for the modification work, could cost you a pretty penny (we're talking on the better side of a lac here). hope this helps. ciao.
__________________ DAD |
| | #3 (permalink) |
| thanks veyron for that amazing help youve just given me. yes most of the faults which were in the car earlier have been sorted by tata but the mechanics at tata say that the play won't go no matter what i do. even my usual alignment guy tells me it's not possible but if it's a mechanical part how can it not be fixed. anyways it's a 4x2 the thing is the brakes are not sluggish but feel as if worne out, when the brake is engaged after about 2-3 seconds of braking the car vibrates furiously and gives a feel of worn out pads.. about 3-4 months back i had the discs turned which worked fine for 2 months or so and the problem has resurfaced. |
| | #4 (permalink) |
| BHPian Join Date: Jul 2004 Location: Madurai
| Working on the discs are usually a bad idea and that could be the problem. Dont machine them cos I really dont think there is any local lathe who can true it perfectly. Make sure you use only genuine pads. I have a Safari too and the stock brakes (in good shape) are not bad at all! |
| | #5 (permalink) |
| Senior - BHPian | you're most welcome, abhishek. but you see, a certain amount of steering play WILL be there no matter what, as it's a sort of deliberate thing by the tata engineers. as you say, your brake (the pedal) judders when the pedal is pressed, right? well, i don't think the mechanics have done a good job at "cutting" or aligning the rotors. brake judder usually happens when; a) the disc rotors are misaligned, b) any of the brake lines (hydraulic lines to the 4 wheels) are clogged, c) if the brake pads (front) are worn out and the base part of the pads are rubbing the discs. and if you feel the pedal is mushy, bleed the brakes and check for bubbles or air in the system; if it still persists, check the master cylinder and the booster. the safari has pretty good brakes, actually; so check the brakes thoroughly, as there might be some fault with the system itself. try driving another safari, and compare the feel.
| Thread Tools | |
Similar Threads | ||||
| Query on Steering Play in Tata Safari 2.2 VTT | smsrini | Technical Stuff | 3 | 5th March 2008 16:28 |
| Loose Steering (Too much play in the steering) | mithun | Technical Stuff | 6 | 14th February 2008 14:02 |
| the Ikon.. bad brakes | Hatari | Technical Stuff | 28 | 5th September 2007 12:26 |
| My accident - Bad brakes, bad rain, bad luck... | vezj420 | Street Experiences | 41 | 22nd May 2007 10:49 |
| some play in the steering | sankeerthreddy | Technical Stuff | 6 | 9th February 2007 15:53 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
