View Poll Results: What suspension options for the OHC Vtec
Go for standard set up....anything more is a waste ! 2 5.71%
Try hard, stand on your head for a set of Koni's 25 71.43%
Stick with standard set up and look at some rear suspension mods 4 11.43%
Retain standard suspension set up and play around with bigger tyres 5 14.29%
Multiple Choice Poll. Voters: 35. You may not vote on this poll
Old 19th February 2006, 15:45   #1
Thanked: 11,078 Times
Default New Suspension for the Vtec
After a hard 5000 km + some hard cornering in Chennai, my Vtec's suspension is shot. By the look of it, no one imports specialised suspension components (makes most road warriors look like a bunch of polishers). Methods do not import Koni's for OHC.
Need your opinions on
Old 19th February 2006, 16:33   #2
v1p3r's Avatar
Thanked: 27 Times
Go to SAG Racing...
Old 19th February 2006, 16:58   #3
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Speak to psycho , he imports koni's .. Expensive , but surely worth it ..
Old 19th February 2006, 19:25   #4
Ford Rocam's Avatar
Thanked: 16 Times
I have recently upgraded my suspension front & rear in OHC both are adjustable KY-B Stiffened with ride height lowered by 1.25in in rear & 1/2 in in front & Boy With 205 Profile 15" GIII the handlings is great & runs rock solid. Exactly What kind of Suspension Setup are you looking for your VTEC?
Ford Rocam is offline   Reply With Quote
Old 19th February 2006, 20:07   #5
something not too low but provides a better placed rear end- where did you get the kit from and how much did it cost?
Old 19th February 2006, 20:36   #6
car_crazy1400's Avatar
Thanked: 204 Times
Red face
Hey Rocam , even I am looking for such stuff for my OHC 1.5 , but haven't been able to find much, I would really love to get an estimate on your set up . 'coz I have similar sized tyres(195/55 R15 Bridgestone Potenza's), But the ride leaves a lot to be desired. Ne help pls?
car_crazy1400 is offline   Reply With Quote
Old 19th February 2006, 21:00   #7
Mpower's Avatar
Thanked: 1,687 Times
Rocam, KYB for shocks....do you know what springs you are using. Eibach, ground control ??
Also how does she handle the speedbumps. OHC already has an issue with its underbody scraping at full load.
PS, did anyone notice that there was a silver Baleno running at the track day with a KONI livery. I thought he was a dealer or something.
Old 19th February 2006, 21:05   #8
Thanked: 35 Times
Yes that baleno belongs to Shreshta Patil the rally driver .. He has given up the esteem class and is planning to take part in the balenos henceforth ..
Old 19th February 2006, 22:37   #9
Ford Rocam's Avatar
Thanked: 16 Times
[quote=Mpower]Rocam, KYB for shocks....do you know what springs you are using. Eibach, ground control ??
I m not sure which make the springs are but it has come as a kit specifically for city the hight of springs were almost half the oem size, the ride quality is quit acceptable and i havent found any problem on speedbumps but i slow down often, the tyre & underbody doesnt scraps i have tested with 4 persons loaded and some luggage and on expressway it feels as if you are glued to the road
@car crazy1400 ,Set of 4 Adj Shock & spring costed around 45K including installation, I had installed these shocks cause of Engine + daily street strip driiving the ride quality is acceptable.
@Ajmat I got the kit from KS Motorsports price mentioned above
Old 19th February 2006, 22:53   #10
nitrous's Avatar
Thanked: 285 Times
Ajmat, did u speak with PJ about the coilovers he's using on his Vtec??
Psycho can also help u with the konis.Get the bolt-on set for the OHC since its gonna be a daily driver and we're not experimenting with cornering,angle, speed,etc..
Old 19th February 2006, 23:11   #11
Mpower's Avatar
Another thing to consider for 'track use only' are 'camber plates' They allow you to run negative camber which will give you not only more grip but also reduce the kind of one sided tire wear that you see. Considering the price of imported sport tires and the rate at which they wear, its well worth the investment.
But it may not work in combination with bolt on strut bar because it also bolts on to the top strut mount. Another option to get negative camber is to get a service strut with a cam bolt.
Old 20th February 2006, 08:17   #12
PJ does not deal with them anymore - am looking at a simple bolt on set for a daily driver
Old 20th February 2006, 10:23   #13
Godfather's Avatar
Thanked: 65 Times
there are 2 sets of konis that you can buy
the koni red is the complete rally setup or you can go for the softer street koni yellows...
The yellows should suit your city much better and are also cheaper. 20G a pair i guess.. ask keshav..
Godfather is offline   Reply With Quote
Old 23rd February 2006, 21:03   #14
Koni do not supply any more ...at least thats what the Singapore Disti told me.
Looked on Ebay - some options from Tokico and KYB for around $200 + freight and the dealer will put a lower price on the invoice.
Some questions:
1: How much duty would one expect to pay ?
2: How good is Tokico ?
3: Can someone confirm that the 1992-2000 Honda Civic uses the same parts to ensure I am getting the right stuff!
Old 23rd February 2006, 23:42   #15
Mpower's Avatar
There were two generations of Civics that existed in that timeframe. They both had a SLA or double-wishbone setup on all 4 corners and the Indian City has McPherson strut F with multilink rear. U can check with Iceman, he has a '92. So, civic parts wont fit.
Your new cars suspension: How long should it last on our roads? Rtech The Indian Car Scene 102 15th November 2015 07:23
NEMSIS II : new paintjob and a new suspension and new alloys accord masters Modifications & Accessories 63 30th December 2008 02:38
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
NHC-Vtec or OHC Vtec..which is a better buy? sunith Sedans 4 2nd May 2006 21:25
Indian vtec 106 bhp  Thai Vtec 120 bhp ajmat The Indian Car Scene 7 7th March 2006 18:21
