Old 1st February 2012, 13:28   #226
Thanked: 364 Times
Default Re: Volkswagen Vento - User Discovered Features and Quirks
Yes this is true, but this isnt a feature exclusive to the vento either. Even aftermarket remote locking systems provide this functionality.
Originally Posted by plain.vanilla View Post
Another feature that I noticed in the Vento is that if you unlock the car using the remote but do not physically open any of the doors, the car locks itself up again in approximately 30 seconds.
bala80 is offline   Reply With Quote
Old 5th February 2012, 13:08   #227
Thanked: 364 Times
Was reading up on the ABS (Bosch 8.2 system) in the vento when came across the following
- Emergency hazard warning flashing on braking force greater than 7m/s
If true, this would qualify for a place in this thread, however I personally havent experienced this so far. Anyone who can verify?
Old 5th February 2012, 15:59   #228
souravc's Avatar
Thanked: 427 Times
I think its the deceleration that's being referred to here rather than the brake force or pressure , 7 m /sec squared means roughly 100 - 0 kmph in 4 secs . I doubt whether Vento's brakes or any of the mid range sedan's have that much of braking power available .
Sorry I can't even volunteer to test that too
souravc is offline   Reply With Quote
Old 5th February 2012, 19:17   #229
Sathya_sc's Avatar
Thanked: 670 Times
Not sure whether I can post about a Linea here. But I have seen my friends Linea flashing all 4 lights under severe hard braking (in BLR highway). I witnessed the MJD coming to a grinding halt because of a last minute unexpected lane change of a lorry. I was at about 160 (mine is a T-Jet) when MJD overtook me to immediately brake because of the lorry! Actually this works.
My heart actually skipped a few beats though since I thought it was the end of my friend (almost the nose of the MJD was a few inches from the underbelly of the lorry).. It was really scary.
Sathya_sc is offline   (2) Thanks Reply With Quote
Old 5th February 2012, 19:30   #230
Thanked: 364 Times
Lol, Souravc, you are right. It is the deceleration that is mentioned here and under hard braking, the hazard lights automatically turn on to indicate the same to the other road users.
Ford advertised this as a feature in Figo and hence thought I would post it up here too.
On a serious note, anyone experienced ABS kicking in the vento yet?
Old 5th February 2012, 21:28   #231
lamboguy's Avatar
Thanked: 119 Times
Sorry to butt in. Many of the features mentioned in this thread are found in the Jetta too (atleast the new one) . And some of us Jetta owners have been following this thread. Keep up the good work guys!
ABS kicked in the Jetta once. It probably saved my life that day. While returning from igatpuri from a TBHP meet, I was at a blind left curve doing some 100 - 120. Suddenly a family of 3 decided to cross the road which took me by shock. I slammed hard on the brakes. The pedal started "pumping" and the car did not screech. Instead, it slowed down rapidly and felt rough as if driving on a broken road (which I guess is how the abs works) . Braking hard without ABS on that curve would have surely led me into the divider.
lamboguy is offline   (2) Thanks Reply With Quote
Old 5th February 2012, 22:57   #232
ninjatalli's Avatar
Thanked: 1,344 Times
Woah! Is that the effect of ABS? Then that has happened to me a few times. Of course, in my case it always has been the occasional (invisible) speed breakers that I miss out seeing while at high speeds, thankfully never the kid or the family on the road. Honestly, everytime it happened, I always used to think there was something wrong with the brakes, never thought it was the ABS Infact I tried repeating it immediately but never could re-create the exact scenario.
Lol. Now I understand. Could you also clear one more confusion for me? How would presence of EBD improve the situation as compared to only ABS?
ninjatalli is offline   (1) Thanks Reply With Quote
Old 6th February 2012, 10:25   #233
souravc's Avatar
Thanked: 427 Times
Thanks Sathya - this feature can surely prevent a rear ending !
ABS had kicked in once for my car at much slower speeds of around 50 kmph but the road was a dry under construction road with gravels strewn all over . I was overtaking a truck when it veered towards the right ( into my path ) and I had to slam my brakes hard to prevent myself from slamming into a flyover pillar. There is a thud-thud feel on the brakes when it kicks in.
EBD helps in distribution of brake force to take care of situations where there are significantly varying grips in various tyres [ like for example say when you brake the left rear tyre is on an oil patch on the road, the right rear tyre on dry concrete , the right front on a patch of grease and left front on grass ] EBD will allow brake force distribution of varying degrees onto each tyre , without EBD the oil patch and grease would rule assuming they allow the least grip .
The bosch units have EBD + ABS standard and I think thats the case with the units on Vento too - trust the Germans to miss out mentioning stuff !
@ Ninja - given that you are a Ninja , can you please try out the flashing lights under extreme braking ?
A few of us have - you have better tyres now so the chances of your experiencing ABS has reduced
Old 6th February 2012, 12:14   #234
ninjatalli's Avatar
lol.
7m/s would mean a 100 to 0 in less than 4 seconds. I wonder if I'll be able to replicate such a test scenario. Also I didn't know the Vento brakes were capable of doing that!
ninjatalli is offline   Reply With Quote
Old 6th February 2012, 13:25   #235
Thanked: 26 Times
Post deleted by Team-BHP Support Team. There are numerous threads discussing how ABS/EBD work on the forums. Please limit this thread to user-discovered features and quirks in the VW Vento. ABS is hardly one of those
anToNIcHeN is offline   Reply With Quote
Old 7th February 2012, 02:33   #236
Thanked: 33 Times
Same here happened to me a few times at speeds of 40-70kmph when I had to brake suddenly before a speedbraker or pothole. The pedal would vibrate, and there would be a grinding noise coming from the brakes with the feeling of driving over a rough patch. Even I though something was wrong with the brakes as I never noticed the ABS sign light up or any beep when this happened though I was never paying attention.
Has anyone else noticed the ABS sign light up when that happens?
Abhinav.Daos is offline   Reply With Quote
Old 7th February 2012, 20:13   #237
Thanked: 364 Times
ABS sign will not light up when it kicks in. It will only light up if the ABS unit malfunctions .It will momentarily flash during the vehicle start-up when all the systems are checked for any issues but not thereafter.
Old 8th February 2012, 00:24   #238
Thanked: 50 Times
@ People who have gotten their speed-sensing locks activated: Has anyone gotten it done in Mumbai. I booked my Dec 2011, Beige @ Tornedo Motors in S'Cruz, but the RM seemed unaware about the feature.
Annibaddh is offline   Reply With Quote
Old 8th February 2012, 01:27   #239
Thanked: 33 Times
You should try to talk to someone on the workshop floor about it as the sales people can be ignorant of such features.
Abhinav.Daos is offline   (1) Thanks Reply With Quote
Old 8th February 2012, 16:53   #240
Thanked: 364 Times
Please refer fellow member souravc ownership thread, he has provided all the details in there. You can click on his handle on either one his posts and find threads started by him.
bala80 is offline   (1) Thanks Reply With Quote
Reuters : Has Volkswagen discovered the Holy Grail of carmakers? Anghammarad The International Automotive Scene 17 19th November 2016 12:38
Hidden features you discovered in your car after regular usage SumitBahl The Indian Car Scene 236 26th October 2015 19:26
Communication/behavioral quirks in India? B103 Shifting gears 2 3rd June 2014 21:16
Volkswagen Vento Diesel Highline gets some more features GTO The Indian Car Scene 42 10th April 2012 22:07
1000bhp Testarossa discovered. X-Machine The International Automotive Scene 9 28th September 2004 21:51
