Old 25th August 2012, 10:11   #376
newtonMeter's Avatar
Thanked: 358 Times
Originally Posted by souravc
Thanks ! I was wondering who amongst the TBHP-ian Vento owners had mentioned a solution involving cleaning the beadings - it was you ! So basically the WD 40 has to be applied to the rubber or the door frame ?
Don't use the red pipe you get with WD-40 ( to get wide solution spray)
Spray on the door frame which was velvet texture . For example for the front door start from ovrm and end till the glass frame ends (just above the locking mechanism)
I'll try to make a video and upload
newtonMeter is offline   (1) Thanks Reply With Quote
Old 26th August 2012, 13:35   #377
Default Re: Volkswagen Vento - User Discovered Features and Quirks
Hey everyone....Thanx @sauravc for the brilliant thread. It helps new Vento owners like me. I have a query here. My previous vehicle Chevy Aveo has a engine temperature Cold....Hot indicator dial which is missing in the Vento. Is there anyway to see that in the Vento TDi HL?
goXrive is offline   Reply With Quote
Old 27th August 2012, 02:13   #378
souravc's Avatar
Thanked: 427 Times
No there is no engine temp indicator in Vento - in case of overheating there is a coil indicator which would glow in the instrument panel
souravc is offline   Reply With Quote
Old 17th September 2012, 18:20   #379
ninjatalli's Avatar
Thanked: 1,177 Times
Just for a knowledge basis - anyone aware where is the fusebox / fuses in the car? Do update.
ninjatalli is offline   Reply With Quote
Old 17th September 2012, 19:26   #380
Thanked: 33 Times
Just above the battery under a cover.
Abhinav.Daos is offline   (1) Thanks Reply With Quote
Old 17th September 2012, 23:17   #381
Thanked: 358 Times
There is on panel below steering column
newtonMeter is offline   Reply With Quote
Old 24th September 2012, 00:57   #382
Thanked: 142 Times
I don't know if anyone knows this and it has been reported here.
On 2012 Highline Vento's (with steering mounted controls), you can cycle through the available media player sources (CD, Radio, USB, etc) by pressing and holding the "Phone/BT" key for about 2 seconds a time.
ie. If you are on radio, pressing and holding the key for 2 seconds will cycle you to the next source - CD, USB, etc.
pillainp is offline   (3) Thanks Reply With Quote
Old 24th September 2012, 08:22   #383
Thanked: 358 Times
I have the same model but doesn't work for me :( is it new sw version? What is your month of manufacture?
Old 24th September 2012, 18:44   #384
Thanked: 142 Times
Mine is January 2012.
Now I wonder if it only works with third party Head Units.
I am using a Kenwood 4038BT, and it works exactly as stated above.
Also, I can start and end calls using the phone button.
Seeing that, I thought it would work with the OE RCD-310 (is that what you have?).
pillainp is offline   Reply With Quote
Old 24th September 2012, 18:55   #385
Thanked: 358 Times
Yes I have the oe 310. How much did your 4038 cost? It had a build in steering interface or you had to buy PAC interface?
Old 24th September 2012, 19:03   #386
Thanked: 142 Times
I got the 4038BT for 31K from our Jerish. The PAC interface and antenna interface had to be purchased and installed separately.
BTW, the new Vento's (at least mine) come with a single connector cluster, instead of the twin connectors on previous versions, so a new type interface connector is required.
Old 30th September 2012, 18:41   #387
Thanked: 84 Times
Well, Ive been head scratching a lot to find out if other owners had similar problems and must say that its indeed a quality problem as so many have complaint of this irritating door rattling. I had one for a long time and hammered the service advisers and they duly applied the lubricants etc and it cured the problem for just 2 weeks and its back again , on any road other than smooth the noise appears again and again.
I will take the car back once again and get it redone and if it doesn't work then i better get some nice music numbers!
Originally Posted by fiesta View Post
When I had complained of this problem to Service center they applied some lubricant to all door beadings. The noise has surely reduced, however its still heard at times :(
It seems they do not have another solution for this issue.
hondacity is offline   Reply With Quote
Old 7th October 2012, 09:55   #388
aniket.tiwari27's Avatar
Thanked: 65 Times
Mine is Feb 2012 manufactured but the above feature does not work for me also. Does it require some kind of software upgrade?
aniket.tiwari27 is offline   Reply With Quote
Old 15th November 2012, 18:42   #389
Thanked: 358 Times
Not sure if this is discussed earlier.
Vento (or the TDI) is tuned for adaptive idling RPM to make it more forgiving. The idling for 1.6 CLNA TDI is 800 rpm (when standing still and in neutral or clutch depressed). But moment the car is moving (or in motion) and then slotted in Neutral or clutch depressed, the idling is at 900 rpm.
To experience this uou could do the following ( Do not try in closed/traffic place)
1. Start the car (keep it in neutral) - observe the rpm - should be at 800 rpm
2. Slot it 1st gear, make the car move, once the car is in motion slot it to neutral and release the accelerator . You will observe, the idling is at 900 rpm (higher than when stand still)
3. Brake and stop the car, you will see the idling drop back to 800.
Old 26th November 2012, 08:59   #390
ninjatalli's Avatar
Vento owners with the refreshed version (RCD 310 player, steering controls, usb) - you can connect your mobiles and use it as a usb drive; just connect your (mobile's) usb cord to the player's usb cord, and the phone gets detected as a pen drive!
Works like a charm for my android mobile; will test BB & Apple phones later to see if this method works with them too.
ninjatalli is offline   (1) Thanks Reply With Quote
Reuters : Has Volkswagen discovered the Holy Grail of carmakers? Anghammarad The International Automotive Scene 17 19th November 2016 12:38
Hidden features you discovered in your car after regular usage SumitBahl The Indian Car Scene 236 26th October 2015 19:26
Communication/behavioral quirks in India? B103 Shifting gears 2 3rd June 2014 21:16
Volkswagen Vento Diesel Highline gets some more features GTO The Indian Car Scene 42 10th April 2012 22:07
1000bhp Testarossa discovered. X-Machine The International Automotive Scene 9 28th September 2004 21:51
