Old 11th December 2012, 12:49   #421
volkman10's Avatar
Thanked: 19,856 Times
Default Re: Volkswagen Vento - User Discovered Features and Quirks
Originally Posted by Mighty_Lothar View Post
Nevertheless, in my case, the indicator lights are not turned on. The car’s ignition is OFF and what happens is ONLY 1 of the Parking light remains on. The other parking light is off. I have noticed this in couple of occasions.
Could you try this again. As Ninja as stated seems something different you are seeing, maybe an undiscovered feature or something defective.
Does the normal situation as indicated by Ninja work?
Cheers!
volkman10 is offline   Reply With Quote
Old 11th December 2012, 19:10   #422
SUPERSPORT's Avatar
Thanked: 246 Times
As far as my knowledge goes parking lights on one side can be turned on as follows- Just turn the park lights ON first. Then use the indicator stalk. Switch off the park lights. Parking lights stay on only the corresponding side of the indicator stalk. All the dashboard lights except the one on the light switch will be turned off (saving energy too).
SUPERSPORT is offline   Reply With Quote
Old 12th December 2012, 09:01   #423
volkman10's Avatar
This is what Ninja and I had explained but Mighty_Lothar is getting something different. Seems more of a defect.
Cheers!
Old 12th December 2012, 09:33   #424
Mighty_Lothar's Avatar
Thanked: 72 Times
Hi Volkman10/Ningatalli/Supersport,
I tried my level best to reproduce this issue but vain. However, I am sure in my case, indicator lights are not in the picture at all. When I notice it next time, I will try to figure out what is going wrong since I have some fine inputs from you guys.
Ningatalli,
If things go well, I am planning to gear up my Vento’s competence with a KIIRUS remap. And yeah, I am a BIG FAN of Mandrake and LOTHAR and hence the epithet is.
LOTHAR
Mighty_Lothar is offline   Reply With Quote
Old 12th December 2012, 15:02   #425
SUPERSPORT's Avatar
Thanked: 246 Times
Sorry guys, but there is a mistake in my earlier post. Actually you don't have to do anything with the park lights for this function. Just flick the indicator stalk when the car is switched off and the park light stays ON on that side. I was thinking the other way because I had changed my parks to LEDs and sometimes I use them as DTR lamps. I had observed this most of the times when I had the parks on. Now I have to ensure the that the indicator stalk is in the centre position otherwise the lights just stay ON. They should have found some better way of activating this feature. In my Linea this feature works only after switching the parks ON.
Old 26th December 2012, 21:30   #426
Thanked: 92 Times
Originally Posted by bala80 View Post
I have the technical documents for the vento (wokshop maintanence manual, Training manuals etc), which had these information. Credit to the member "dingolphie" who provided me these documents, if you want to have a copy, PM me your email address and I shall send it over to you.
hi
I have a Rapid and i suppose the cars share the same mechanicals to a large extent so it would be a great help to have a copy of the manual
torque18 is offline   Reply With Quote
Old 26th December 2012, 21:45   #427
ninjatalli's Avatar
Thanked: 1,344 Times
Originally Posted by torque18 View Post
hi
This should help. Contact @bluevolt if the below link doesn't work.
Rapid Manual
Edit: I don't have the other manuals @bala had mentioned in his post.
ninjatalli is online now   (1) Thanks Reply With Quote
Old 26th December 2012, 22:24   #428
Thanked: 92 Times
Rapid Manual
hey! thanks for the link but its for the owner's manual. I am looking for the Rapid/Vento's service manual. I think Bala has it, waiting for him to respond
Old 26th December 2012, 22:36   #429
Thanked: 92 Times
Another thing..today i noticed that my rear right power window was not working at all. I panicked a bit and then searched this forum for Bala's post describing how to reset the auto roll function (i remembered having seen it at an earlier point of time ). having read it, i walked to the car but before performing the reset i tried the convenience opening of windows from the key fob and it worked! I got in the car checked the operation from the switches and it was absolutely fine!
I am glad that its working otherwise it would have been an another sleepless night for me. however, I am still wondering what would have been the issue and how it got resolved on its own and if there is actually something wrong! May be i am thinking too much but its little worrying to me. What could have caused such a behaviour?
Old 27th December 2012, 09:10   #430
Alisiddiqui's Avatar
Thanked: 42 Times
This is due to dust on the frame. Vw sprays some liquid to ease the stuff. Its due to the anti pinch function i think and maybe a bit too sensitive. Known problem with vws. Next time dont panic. Try it in sometime. Or carry the spray wiht you.
Alisiddiqui is offline   (1) Thanks Reply With Quote
Old 27th December 2012, 15:17   #431
Thanked: 92 Times
thanks for that info. didnt know it was so sensitive. i will try to keep it more clean
Old 31st December 2012, 22:46   #432
pc73's Avatar
Thanked: 53 Times
Don't remember seeing the following "feature" mentioned:
Applicable for RCD 310 + steering mounted audio controls.
If the mute/pause button is activated using steering mounted audio control, the audio can be unmuted/resumed by turning the volume control knob on the head unit.
Useful for front passenger - he/she can unmute/resume if driver forgets to do so!
pc73 is offline   Reply With Quote
Old 2nd January 2013, 18:20   #433
Rachit.K.Dogra's Avatar
Thanked: 737 Times
Recently during my recent road trip to my hometown in Himachal, I was driving early morning and suddenly got a beep from the MID. It was showing 4 degree Celsius. At first I got confused and worried as it seemed to be a warning or something. When the MID went to normal display, I browsed and checked and yes the temp was showing 4. I think it is a feature built in that if temp drops to 4 deg C, the MID shows a beep.
Rachit.K.Dogra is offline   Reply With Quote
Old 3rd January 2013, 12:28   #434
ishlinea7260's Avatar
Thanked: 262 Times
Not only does it beeps , it even shows a snowflake!
ishlinea7260 is offline   Reply With Quote
Old 7th January 2013, 10:02   #435
Thanked: 42 Times
What does it signify though. In Gurgaon today.
Alisiddiqui is offline   Reply With Quote
Reuters : Has Volkswagen discovered the Holy Grail of carmakers? Anghammarad The International Automotive Scene 17 19th November 2016 12:38
Hidden features you discovered in your car after regular usage SumitBahl The Indian Car Scene 236 26th October 2015 19:26
Communication/behavioral quirks in India? B103 Shifting gears 2 3rd June 2014 21:16
Volkswagen Vento Diesel Highline gets some more features GTO The Indian Car Scene 42 10th April 2012 22:07
1000bhp Testarossa discovered. X-Machine The International Automotive Scene 9 28th September 2004 21:51
