Old 6th September 2011, 14:37   #76
Thanked: 23 Times
Default Re: Volkswagen Vento - User Discovered Features and Quirks
Originally Posted by STARCHILD View Post
I also like to keep the re-circulation mode on as it helps in faster and better cooling, also keeps outside odours away. With auto enabled there is no way to confirm if re-circulation mode is off or on.
I too keep the AC in re-circulation mode, but once in a while experience outside odours inside the cabin. When I checked with the service supervisor, he explained that in the re-circulation mode, once in about 15min or so, the unit brings in outside air to refresh the air quality inside the cabin and also help in humidity control. Another feature ?
krish11 is offline   Reply With Quote
Old 6th September 2011, 18:16   #77
Thanked: 364 Times
I dont think so this is true. Re-circulation is controlled by a flap which opens and closes per the mode chosen. As far as experiencing outside odour in a while goes, Some amount of odour will always sneak through irrespective of whether re-circulation mode is chosen or not and is fairly common in all the cars.
You can attempt driving through an area with thick smoke/strong odour and validate this fact. I remember there is a thread under the technical section of this forum discussing the reason behind this too.
bala80 is offline   Reply With Quote
Old 6th September 2011, 21:13   #78
BuRnT RuBbEr's Avatar
Thanked: 11 Times
quite a few cars with ACC have this feature.
BuRnT RuBbEr is offline   Reply With Quote
Old 6th September 2011, 22:08   #79
souravc's Avatar
Thanked: 427 Times
While I am not sure about this , I can share one experience that I recently had with the ACC . One day suddenly we got some awful fishy smell in the car . With all the rain and muck in Mumbai , i thought that its due to footwear or something from outside which is causing it . In spite of checking thoroughly the car we could not find anything amiss though the AC continued to stink . Finally , without much of an idea of anything better to do, I started running the car with the AC in ventilation mode . Within a few minutes , the AC stopped smelling and has been fine ever since . I guess the active deodoriser component needs periodic running in ventilation mode (though i can't say that i am too sure about it) - I had not used ventilation for months together , hate the Mumbai stench!
souravc is offline   (1) Thanks Reply With Quote
Old 7th September 2011, 13:09   #80
Thanked: 364 Times
Found this thread that I was mentioning about in the technical section (and there are similar other one's too).
http://www.team-bhp.com/forum/techni...tion-mode.html (Outside air entering cabin even with a/c in recirculation mode.)
To summarize - Cabin of the car isnt completely air-tight and some amount of outside air/odour does come in once a while.
Good thing about the vento is that it has pollen filter to avoid the dust particles from entering in the cabin when the A/C is in fresh air mode. If I recollect right, this part is changed as a part of your first service at 15k kms.
Old 9th September 2011, 17:13   #81
windsurfer's Avatar
Thanked: 25 Times
Is there a way to disable internal motion sensor?
windsurfer is offline   Reply With Quote
Old 9th September 2011, 17:29   #82
Ramsagar's Avatar
Thanked: 62 Times
Yes, you can. There is button on B-pillar, right below the seat belt on the driver side. Just click that thing. Your motion sensor will get disabled.
Ramsagar is offline   (2) Thanks Reply With Quote
Old 9th September 2011, 17:35   #83
naveen.raju's Avatar
Thanked: 3,725 Times
That's correct. But guess you will have to do this every time you start your car. Correct me if am wrong.
naveen.raju is offline   Reply With Quote
Old 9th September 2011, 18:48   #84
DieselDon's Avatar
Thanked: 132 Times
I wonder how useful the motion sensor is when you have a reachable disable switch. Looks like alarm systems are being tampered by crooks. Do we need it ? Just thinking loud. One possible reason would be to avoid incidents like this I guess. But wouldn't being careful be the safer option.
DieselDon is offline   Reply With Quote
Old 10th September 2011, 00:29   #85
souravc's Avatar
Thanked: 427 Times
The motion detector has be switched off through remote key first and then the disable switch has to be activated for the alarm system not to be triggered going forward . Its not like someone can break into the car and then disable the motion detector through the switch for the alarm not to sound .
Old 11th September 2011, 00:47   #86
souravc's Avatar
Thanked: 427 Times
One more quirk to be added to the list :-
When one locks using the remote key and then opens the boot using the remote key , the lock light ( on the driver's side door) glows . So effectively the unlock makes the "lock" light glow . Savvy ?
Old 14th September 2011, 16:24   #87
I recently bought an Vento Highline TDI in which only one light glows for reverse light and rear fog light. Does anyone know if we can add the bulbs for other sides of reverse lights and rear fog lights in the Vento?
I also noticed that the clutch is bouncy and I always seem to jerk the vehicle a bit especially while accelerating no matter how slowly I release the clutch. Do any of the more experienced drivers/owners know if this goes away over time or do we develop muscle memory to work with this?
thanks in advance.
-krishna
krishnaprasad is offline   (1) Thanks Reply With Quote
Old 14th September 2011, 17:40   #88
noopster's Avatar
Thanked: 9,591 Times
Hey KP, welcome to the Vento club! Yes, the single reverse light is a shame: an example of the cheesy stuff companies come up with to cut costs.
The fog lamp occupies the same position as the one you'd expect the right reverse lamp to be, so I doubt you can fit and rewire this in a simple manner. Any wire-cutting will void the warranty, don't forget.
I didn't experience any bounciness in the clutch of the TDI I test drove, maybe it's just a matter of getting used to?
Edit: This is my 1500th post on T-BHP
noopster is offline   (1) Thanks Reply With Quote
Old 14th September 2011, 20:17   #89
Thanked: 364 Times
Congratulations on your new car Krishna. Since Noopster has already answered your first question , I'll share my thoughts on your other concern that you raised.
Yes, clutch of the vento has a long travel range and has a pretty annoying bounce back action. This gets a little better with time (or you get used to it), but you need to really master the release position to avoid jerk during gear changes. You will notice this jerk all the more when you release the clutch pretty quick during a upshift/downshift.
I have been driving diesels for years now, and I'm still unable to avoid this jerk, especially if im driving in a spirited manner.
Old 15th September 2011, 10:32   #90
souravc's Avatar
Thanked: 427 Times
thanks in advance.
-krishna
Bala has rightly explained important aspects of the clutch . You can minimise the jerk or bounce if you release the clutch at zero accelerator dip point - illustratively , take your foot off the pedal and then release the clutch . Should help .
There is no escaping from the hard clutch though
souravc is offline   Reply With Quote
Reuters : Has Volkswagen discovered the Holy Grail of carmakers? Anghammarad The International Automotive Scene 17 19th November 2016 12:38
Hidden features you discovered in your car after regular usage SumitBahl The Indian Car Scene 236 26th October 2015 19:26
Communication/behavioral quirks in India? B103 Shifting gears 2 3rd June 2014 21:16
Volkswagen Vento Diesel Highline gets some more features GTO The Indian Car Scene 42 10th April 2012 22:07
1000bhp Testarossa discovered. X-Machine The International Automotive Scene 9 28th September 2004 21:51
