Old 15th September 2011, 12:46   #91
nileshch's Avatar
Thanked: 370 Times
Default Re: Volkswagen Vento - User Discovered Features and Quirks
Originally Posted by krishnaprasad View Post
I also noticed that the clutch is bouncy and I always seem to jerk the vehicle a bit especially while accelerating no matter how slowly I release the clutch
Originally Posted by souravc View Post
You can minimise the jerk or bounce if you release the clutch at zero accelerator dip point - illustratively , take your foot off the pedal and then release the clutch
@Krishnaprasad, like Sourav said, release the clutch without foot on accelerator pedal. Or if you are not at the right speed, transition the clutch and accelerator pedals exactly at the same time, albeit slowly (not sudden release and press). You can avoid the jerk. You will learn this quickly, I think.
Originally Posted by bala80 View Post
I have been driving diesels for years now, and I'm still unable to avoid this jerk, especially if im driving in a spirited manner.
It's the other way for me. When I am in slow moving traffic, I am not able to avoid the jerks. At high speeds, it's pretty smooth.
nileshch is offline   Reply With Quote
Old 15th September 2011, 16:08   #92
To Noopster,Bala, Sourav & Nilesh
Many thanks. I will try the mentioned techniques for the next few days.
I have also summarized your replies in this post for ease of others.
thanks again
krishna
Originally Posted by noopster View Post
Hey KP, welcome to the Vento club! Yes, the single reverse light is a shame: an example of the cheesy stuff companies come up with to cut costs.
The fog lamp occupies the same position as the one you'd expect the right reverse lamp to be, so I doubt you can fit and rewire this in a simple manner. Any wire-cutting will void the warranty, don't forget.
Yes, clutch of the vento has a long travel range and has a pretty annoying bounce back action. This gets a little better with time (or you get used to it), but you need to really master the release position to avoid jerk during gear changes. You will notice this jerk all the more when you release the clutch pretty quick during a upshift/downshift.
Bala has rightly explained important aspects of the clutch . You can minimise the jerk or bounce if you release the clutch at zero accelerator dip point - illustratively , take your foot off the pedal and then release the clutch . Should help .
There is no escaping from the hard clutch though
krishnaprasad is offline   (1) Thanks Reply With Quote
Old 15th September 2011, 23:19   #93
Thanked: 364 Times
The technique that souravc described works the best. Release the clutch completely and then provide accelerator input. Issue is sometimes your knee starts feeling sore due to the hard clutch after driving in B2B traffic.
Some amount of jerk is inevitable if you are trying to shift quickly. You will understand this and will get used to it though.
thanks again
krishna
bala80 is offline   Reply With Quote
Old 16th September 2011, 00:38   #94
souravc's Avatar
Thanked: 427 Times
I missed out on another interesting quirk / feature - had discussed it in the official Vento thread , was reminded again today while refilling my tank . There is a small air lock button at the inlet of the fuel tank which can be depressed to release potential air locks . This allows 6-7 litres of incremental fuel in the tank. I feel obliged to point this feature out of a guilt feeling - once I had blown my top with a fuel station attendant when he did this and refuelled my car by more than 57 lts which came as a shock as the capacity is supposedly 55 lts . I was wrong as I have learnt through various tests across pumps that indeed the air lock button when depressed allows much more fuel to be pumped in . Similar feature exists in Skoda cars too, thats where the fuel station attendant had learnt the trick ( a packet of mishti, apologies and thanks for teaching me something new, a few days later hopefully undid the damage . That day I also had my first experience of how useless the VW helpline is !)
The actual capacity of the Vento tank IMO is around 60 lts rather than 55 lts
souravc is offline   (1) Thanks Reply With Quote
Old 16th September 2011, 09:42   #95
plain.vanilla's Avatar
Can someone explain how the motion sensor works? I locked myself in the car and waved at the motion sensor but nothing happened. The alarm came on only when I opened the door without unlocking the car.
plain.vanilla is offline   Reply With Quote
Old 16th September 2011, 09:50   #96
naveen.raju's Avatar
Thanked: 3,137 Times
It works even if you move inside the car. I tested this when I got the car. Try moving your hand in front of the sensor. If this doesnt activate the alarm, check with the dealer.
naveen.raju is offline   Reply With Quote
Old 16th September 2011, 11:54   #97
Thanked: 56 Times
Discovered an interesting thing while test-driving few days back regarding the emergency blinkers.
Lets say that both the blinkers are on since you have pressed the emergency/ hazard switch at the center.
Now, in between if you use the left/ right turn indicator ; the emergency blinkers stop automatically and only the single turn indicator (left or right) is activated.
After the turn is completed ; the emergency blinking i.e. both blinkers resume automatically.
This isn't there on my Fiesta or Figo in which once the hazard switch is pressed both the blinkers continue to function even if a single turn is needed/ activated in between.
gaurav911 is offline   (4) Thanks Reply With Quote
Old 16th September 2011, 13:03   #98
noopster's Avatar
Thanked: 9,197 Times
This is fabulous- I had no idea this happened.
But please keep in mind you should use the emergency lights *only* when stationary/in need of help and not as many of our countrymen do, to increase visibility during fog, rain, slow driving and the like.
Has anyone noticed that if you snap the turn indicator in the middle of a turn, it completes that blink before going off? This doesn't happen in Jap/Korean cars. Neat!
noopster is offline   (2) Thanks Reply With Quote
Old 18th September 2011, 11:40   #99
souravc's Avatar
Thanked: 427 Times
Noticed the feature only when you mentioned it . On the emergency blinkers , I do switch them on when in heavy rains , in tunnels , stopping by a the highway, etc - isn't it right?
souravc is offline   Reply With Quote
Old 18th September 2011, 12:39   #100
Thanked: 364 Times
Only stopping by the highway part is correct, rest aren't.
In a nutshell, hazard lights needs to be turned on only when you are interrupting the flow of traffic, not otherwise.
For improving visibility you have the front and rear fog lamps, which can be used as required.
A moving car should never have emergency blinkers on.
bala80 is offline   (1) Thanks Reply With Quote
Old 18th September 2011, 12:55   #101
Thanked: 33 Times
Did you know many cars have a feature where if you break hard the blinkers automatically turn on?
Abhinav.Daos is offline   Reply With Quote
Old 18th September 2011, 16:03   #102
Thanked: 364 Times
And what do you think is the reason behind it?
It is because you are decelerating at a rapid pace and showing an intent to stop.
Old 18th September 2011, 16:26   #103
nileshch's Avatar
Thanked: 370 Times
Bala is right, Sourav. You should avoid using blinkers at all costs when driving.
I don't know if you have been on the Mumbai-Pune expressway in heavy rain during peak hours of evening. This situation has always been a nightmare for me. The poor visibility coupled with the crescendo of blinkers put on by all surrounding cars, SUVs & trucks screws up your judgement completely . It is such a bad situation that I can neither drive too slow to allow all others to pass me (with the fear that someone might rear-end me) nor too fast to get away from others (with the fear that I might rear-end some slow moving car). A recipe for disaster, I may add.
nileshch is offline   (1) Thanks Reply With Quote
Old 20th September 2011, 12:24   #104
windsurfer's Avatar
Thanked: 25 Times
Another one from me, though lot of people would know this already.
When you need to change the lanes, just depress the indicator lever a bit. The lever would pop back immediately but the indicator blinks for 2-3 times. Very useful in 4 lane highways.
windsurfer is offline   (2) Thanks Reply With Quote
Old 20th September 2011, 13:18   #105
noopster's Avatar
^^Yup that's an awesome feature, very common on German cars I believe. It blinks 3 times.
noopster is offline   Reply With Quote
Reuters : Has Volkswagen discovered the Holy Grail of carmakers? Anghammarad The International Automotive Scene 17 19th November 2016 12:38
Hidden features you discovered in your car after regular usage SumitBahl The Indian Car Scene 236 26th October 2015 19:26
Communication/behavioral quirks in India? B103 Shifting gears 2 3rd June 2014 21:16
Volkswagen Vento Diesel Highline gets some more features GTO The Indian Car Scene 42 10th April 2012 22:07
1000bhp Testarossa discovered. X-Machine The International Automotive Scene 9 28th September 2004 21:51
