Old 11th October 2011, 21:23   #121
Thanked: 186 Times
One thing I observed during reverse. Once you are too close to the object on reverse gear there is a continuous audio beep. But when you change the gear to first, the beep still screams till you move the car forward. The reverse sensors I know on few cars stop beeping once you disengage from the reverse gear.
prabhuferrari is offline   (2) Thanks Reply With Quote
Old 11th October 2011, 21:39   #122
souravc's Avatar
Thanked: 427 Times
Default Re: Volkswagen Vento - User Discovered Features and Quirks
It wasnt a upgrade, just a normal 55/60 bulb change!
Guess every other part is 1000ish for VW. You need fuel filter, air filter, pollen filter etc during 15k service which adds up to this amount.
Originally Posted by bala80 View Post
I dont know the charges but 1200 Rs for a 55/60 W bulb sounds ridiculous, I hope it isnt true.
By the way, these are normal HL bulbs and can also be procured after market right?
Absolutely agree with Bala , Rs 1200 for a 55/60 is way too high - I changed to 90/100 and the bill was around 1200 which included the cut-outs , this was done at a normal shop .
JK , VW parts are not that frightfully expensive but their labour charges are horrendously high . Could you please check the break-up of the 1200 , maybe the figure is after including VW "special" labour charges .
souravc is offline   Reply With Quote
Old 11th October 2011, 22:56   #123
jithudigitised's Avatar
Thanked: 94 Times
Cool Re: Volkswagen Vento - User Discovered Features and Quirks
@souravc Rs 1200 is for the headlights only and not with labour charge. The labour charge they quoted on bill were less
BTW mine is a red vento tdi highline.
Attached the bill for reference.
Volkswagen Vento - User Discovered Features and Quirks-vento_bill_upload.jpg
jithudigitised is offline   (2) Thanks Reply With Quote
Old 11th October 2011, 23:58   #124
souravc's Avatar
Thanked: 427 Times
Hey Jithu , just searched for your ownership thread and realised we are one less red tdi - look forward to yours
Are the stock bulbs halogen ? I doubt it ( my view point only after considering the brightness) though I am not sure. I am curious why you needed to change the stock bulb so quickly . Considering that I paid as much for 90/100 Phillips and that included cutouts and installation , I have to say that VW overcharged. When i changed to the 90/100 i kept the stock as spare and the guy who did the job mentioned that similar quality stock bulbs cost apprx Rs 500 for a pair - no idea how trustworthy that estimate is though !
Old 12th October 2011, 00:36   #125
Thanked: 94 Times
@souravc my swift has the Philips Rally 130/100 with PMP relay installed and that had cost me just above the rate the volkwagen says.
In the bill itself, it says halogen, so i don't think its some other.
The guy told me that the bulb has some focussing issue and so they changed.
Since i tried to focus the bulbs myself using the rotor above the headlight earlier, i thought this might somehow damaged them.
But when asked about warranty, he said it isn't covered.
Anyway i have mailed Volkswagen customer service regarding this and waiting for their reply on the issue.
Well about the ownership thread..its on process. hehe
jithudigitised is offline   Reply With Quote
Old 12th October 2011, 11:00   #126
Thanked: 26 Times
This actually is a useful feature. Suppose you are in an incline. You shift to reverse and you see a block in your sensors. You put your forward gear, it still gives you a feedback as to how much your car can go back while you engage your clutch (For some people, engaging the gear and taking forward the car in an inclination is a big challenge). Now if the feed back stops the moment you engage your forward gear, you would have to take a guess as how tight the reverse distance is.
From what I have observed in Vento, the throw of light / brightness etc of the stock light is very good than normal cars. I had Osram lights in my previous car. The moment I started driving the new Car, it reminded me of Osram head lights (My opinion :- Osram headlights and Vento stock lights have "similar" brightness and throw of light).
Hence my conclusion is that they have indeed used "high quality" lights as stock lights. "Could" be one of the reasons why they charge more!
BTW, Osram lights costs around 1200.
PS: We had an innova at home. When its lights were changed, I remember we were charged 1500 for the same! So I guess 1200 is "cheap" compared to innova
anToNIcHeN is offline   Reply With Quote
Old 12th October 2011, 12:36   #127
ninjatalli's Avatar
Thanked: 1,332 Times
+1 to that. Even the optical display stays on for a few extra seconds.
@antonichen - actually the problem here is the beep keeps continuing for a few seconds even after you start driving. Normally (as you gave an example) it's a good feature. But in traffic or in narrow roads, it becomes a problem - every time I need to recheck if I haven't gone back into reverse instead of 1st gear (the gear position is same for both).
2000+ for the labor; isn't it the norm to mark the labor charges against the line items? In this manner, they could very well add high labor charges for any of the service activities.
Edit : @JD - 300Rs for Nitrogen filling? Isn't that way too high?
ninjatalli is offline   Reply With Quote
Old 12th October 2011, 12:56   #128
Thanked: 26 Times
I cited that eg. coz, I underwent the same scenario just 2 days back. Hence I found that 'delay' in switching useful!
This is just a matter of getting used to!. I am already comfortable with putting reverse and 1st just by the gear feel. Hence this is not an issue with me.
This is what I do. I rest my hand on the hand rest (a perfect comfortable position. I am 5'9"). If I want to engage reverse, I push down the gear lever and then push forward to engage. If its to 1st, I just push it forward. This works great (rather perfect) for my height, hand rest position and gear lever config.
anToNIcHeN is offline   (1) Thanks Reply With Quote
Old 12th October 2011, 13:28   #129
Ramsagar's Avatar
Thanked: 62 Times
You can try adjusting the Lamp leveling device position to "0" and check.
I'm happy with the Vento stock lights. The throw of light is reasonably enough when I set my "Leveling device position to 0" and I'm satisfied.
Ramsagar is offline   Reply With Quote
Old 12th October 2011, 13:51   #130
Today a colleague of mine was telling me that he read in this month's AutoCar magazine that one should not pressure wash the underside of Vento (there are some sensors that would get damaged). Does anyone know about this is true and has more details?
krishnaprasad is offline   Reply With Quote
Old 12th October 2011, 15:40   #131
souravc's Avatar
Thanked: 427 Times
That would be shocking - just imagine what would happen to the sensors when gravels and small stones hit them instead of high speed water .
I don't believe it
Old 12th October 2011, 15:50   #132
VeluM's Avatar
Thanked: 757 Times
I don't believe it
I don't think the damage referred to is physical, but electrical due to shorting. If that is the case, then it is strange because the underside of the car is exactly where all the water spray from roads goes. Either that or they expect Vento owners to crawl during the rains
VeluM is offline   Reply With Quote
Old 12th October 2011, 15:58   #133
Thanked: 186 Times
I was reading the user manual yesterday, and there was a section on driving the car in water. It was clearly mentioned that one has to drive slowly and at times when other vehicles come in opposite direction the waves might get under the car body and this might impact the braking accuracy. So one has to drive slow in water is what VW recommends. I am not sure why someone will drive very fast if there is water on the road?
But then the question here is about high pressure wash on under body and not on water on the road. As sourav said this is something highly unlikely. The only caution I remember reading in the manual is about salt water causing erosion.
prabhuferrari is offline   Reply With Quote
Old 12th October 2011, 16:20   #134
Thanked: 364 Times
Few points from my side -
- 1200 for pair of bulbs is definitely on the higher side (@souravc - I think you wanted to mention xenon, all normal HL bulbs are halogen). However, I would be interested to know the OEM manufacturer of this. Jigu - Can you provide this detail? I would want to find out how much this costs aftermarket. Its afterall a 55/60W bulb, is there any big deal in replacing it outside VW service center?
- 226 Rs for screenwash concentrate is also on the higher side. I admit it gives a pleasent frangrance and all, but still price is high. I have no idea what's the quantity and how long it lasts though.
- Nitrogen filling is ridiculous. Most petrol pumps (atleast in chennai) offer it free with a tank full of fuel.
- As for the high pressure wash - it isnt the underbody, but the engine bay and ECU that is the suspect. I remember reading it in polo maintanence thread that the ECU/some component in engine bay needs to be covered with plastic cover before a high pressure wash and hence washing anywhere else outside VW service station isnt recommended. Will try to dig out that thread and post here for your reference.
bala80 is offline   Reply With Quote
Old 12th October 2011, 16:25   #135
VeluM's Avatar
Thanked: 757 Times
Who said anything about driving "very fast"? There is a difference between going slow and crawling. Going slow will still result in water spray onto the underbody, but the vehicle will not aquaplane and will remain in control. The only way to prevent water from getting onto the underbody is crawling at speeds less than 5kmph.
About the waves, if one is actually wading through water deep enough to submerge the underbody when waves are formed, one would certainly be taking a huge risk of stalling, and the chances of damage are high anyway, so that's obvious.
Reuters : Has Volkswagen discovered the Holy Grail of carmakers? Anghammarad The International Automotive Scene 17 19th November 2016 12:38
Hidden features you discovered in your car after regular usage SumitBahl The Indian Car Scene 236 26th October 2015 19:26
Communication/behavioral quirks in India? B103 Shifting gears 2 3rd June 2014 21:16
Volkswagen Vento Diesel Highline gets some more features GTO The Indian Car Scene 42 10th April 2012 22:07
1000bhp Testarossa discovered. X-Machine The International Automotive Scene 9 28th September 2004 21:51
