Old 24th February 2006, 02:32   #16
buzzin_hornets's Avatar
yes nitrous thats what im doin rite now.. jus pm him..
buzzin_hornets is offline   Reply With Quote
Old 24th February 2006, 05:52   #17
.anshuman's Avatar
Thanked: 9,159 Times
the problem is definitely with the fan motor ,the motor have got weak over time and is unable to transfer not much air that is ok on move but on standstill it is causing problems.
Old 24th February 2006, 10:36   #18
yeah thats what i suspect too.. but the fan definitely doesnt cost 10000. .lol.. i suppose 1k-3k at the most!
Old 24th February 2006, 13:13   #19
prkothan's Avatar
Thanked: 25 Times
Its appalling to see even Honda ASS sucks. I have seen numerous cases where Maruti, Hyundai and TATA ASS sucked. Leave out FIAT its well know for poor ASS.
I recently read a news in Hindu, a customer court gave verdict in favour of a customer to replace his Accent with new one because of very poor quality and very bad ASS.
prkothan is offline   Reply With Quote
Old 24th February 2006, 13:29   #20
Sideways's Avatar
Thanked: 18 Times
Originally Posted by buzzin_hornets
btw my problem of the heat level rising @ idle still persisits.. i called up the honda guys n he said plz bring in your car for rerectification.. he said they must have not chkd it properly!!?? what kinda sevicing is that.. n the idiots have also connected my brakes to my headlights!! so everytime i break my headlights(dim) come on!! he also mentioned that it could be the problem of my radiator fan which could cost 10000 ... lol... that was a good joke.. n he did mention that my steering was heavy cuz my steering rack was leaking (power steering oil), n that ccannot be repaired but replaced for 30000 .. wow!! ur reply guys.. n 1 more thing plz dont ever give ur car to linkway honda @ goregaon (e), they didnt even clean the interiors of my car!, n they had misplaced my key n had to wait like about 1/2 n hr for them to find it.. sux..
Well I said it might be the fan and it is. very simple way to cjeck is to start the car and open the bonnet. The fan should come on afte about 10 minutes of idling.
Check and let me know.
Sideways is offline   Reply With Quote
Old 25th February 2006, 16:29   #21
yes sidewayz i notice the fans wernt turning.. it did sometimes..wierd.. newayz now after the serivce there is a new problem, the car wont rev above 3000rpm, there is black smoke coming outta my exhaust n Viper n Sanjit belive it to be a faulty oxygen censor.but the case turned out to be completley diff where sanjit found the problem to b that the honda guys have tampered wid my ecm n have probably swapped a faulty ecm into my car!.. damn linkway faggot!! arrhhnow im probably gonna right a letter to the manager of linkway n try n get a new ecm fitted in my car for free wid the help of viper n sajit..
p.s. must say viper is very very helpful n has a vast knowledge of cars!!
n yeh gto hope to see ur jeep in action..
n cheers to Elf n his Green Lancer
Old 25th February 2006, 17:11   #22
zenx's Avatar
Thanked: 75 Times
Originally Posted by wildthings
I had the exact same problem with my OHC. It turned out that the radiator fan was not working. I took it to Ichiban(ugh!) and they promptly gave me an estimate for Rs. 14,000!
Got a new fan from "outside" for Rs. 1100... Rest is history.
This seems to be a Honda dealer habit! I've given up for them...
zenx is offline   Reply With Quote
Old 25th February 2006, 17:22   #23
viper's Avatar
Thanked: 9 Times
Hey,
Got bad news for you buddy. We checked your car out thoroughly and have 2 doubts as of now.
1> Somebody has swapped your ECM
2> Somebody has cut/messed up your ECM wiring as we cannot read the ECM data.
I would suggest you to take the car back to Linkway Honday and finish their happiness. Please write a letter to the Works Manager detailing the problem you gave the car with and what happened subsequently and make sure you have an acknowledgement.
I can help you solve the problem but you rather try Linkway and fight for them to do it for free. If they are goign to charge you make sure they inform you and give you an estimate before starting work.
Viper
viper is offline   Reply With Quote
Old 25th February 2006, 17:41   #24
k thnx for all the help viper!! u r sanjit have gone outta ur way to help me! is it ok if i pick up the car on monday??.. n can u help me word the letter that im gonna b givin linkway honda ..
n if the wires r cut ..can that b checked??..
is there a way to get solid proof that ecm has been swapped..?
like sanjit was sayin that he cud get the entire history of the car.. he cud get to know the ecm serial # that came wid my car..
once again thnx for all ur help buddy! will see u soon
take care..
cheers
Ash
Old 25th February 2006, 17:51   #25
viper's Avatar
Thanked: 9 Times
take care..
cheers
Ash
You can take the car on Monday no issues.
I'll do whatever I can to help you. It is time consuming to get the original ECM number but the problem is you are I guess 2nd owner and no way of knowing if the earlier owner/dealer had changed it.
Viper
Old 25th February 2006, 21:19   #26
hey viper, like i mentioned to u last time we met that wen i was in goa the ecm check light had come on.. they had plugged in2 the ecm n solved the problem which was that my speedometer cable needed to be replaced. Now linkway wud have checked through the ecm cuz there was a overheating problem. n i suspect they are the 1s who have tampered with the ecm wiring/swapped my ecm.
lookin forward to ur letter which i will personally diliver to them.
thanx once again
cheers
Ash
Chennai : A New Detroit Rises In India (WSJ) petrol_head The Indian Car Scene 79 9th June 2015 14:22
2013 Dodge Viper Spied For The First Time | The Legend Rises From The Ashes! Scorcher The International Automotive Scene 38 25th December 2012 02:16
Help! Corsa 1.4 engine temp rise androdev Technical Stuff 5 4th January 2008 13:04
At what Temp should the Engine Oil be drained off ? mithun Technical Stuff 3 14th August 2006 16:18
CNG lancer out- HM rises for Cedia devarshi84 The Indian Car Scene 61 30th July 2006 23:22
