Old 3rd September 2011, 18:25   #16
sagarpadaki's Avatar
Thanked: 1,337 Times
Default Re: Does tire grip depend on the road asphalt quality?
Then why is not a standard quality of tarmac maintained across all the roads in the country? Is cost cutting a reason since the authorities feel that rural roads do not warrant high quality asphalt?And compromise on safety aspect?
sagarpadaki is online now   Reply With Quote
Old 3rd September 2011, 19:27   #17
Thanked: 1,083 Times
The design of asphalt mix is based on a lot of factors, primarily :
. Traffic Density and composition
. Terrain
. Temperature range
. Nature of the road - all weather, fair weather, all year, partial (as in the case of the Manali Leh road)
. Environmental damage
In short it has to be tailored to the local conditions, and one size fits all is not possible.
Of course cost plays an important role, we do not have unlimited funds. A good highway (Asphalt) costs about one crore per lane per kilometer to construct and about 10% annually to maintain. What may be economic/feasible for a busy National Highway, may not be so in case of a Village Road. Again as in case of hill roads, if the road is going to washed away regularly due to land slides, you do not use material which has long term benefits, but use what can be laid fast and lasts a season!
Again there is a lot more to a modern highway than its surface. If you notice when a new road is being constructed, the carriageway is nearly a meter thick with layers of soil, stones, asphalt with large stones, asphalt with small stones and finally the top layer. Shortcoming in materials or labour in any layer will result in a sub standard road, leading to early failure.
Do safe driving speeds actually depend on the type of car you drive? syravi Drive Safe 25 19th February 2018 17:57
No hope for traffic sense? Study says quality of driving depends upon quality of government! tsk1979 Street Experiences 14 23rd April 2016 16:18
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
Use of Old car tire, Tire Art! Beautifully done, Must see. SirAlec Shifting gears 2 18th March 2011 22:02
