Old 18th September 2006, 12:20   #31
Thanked: 229 Times
The Maruti Swift is officially supporting the newer CAN BUS Protocol. It was splashed in all their AD's when they announced the car.
Manik
Traveler is online now   Reply With Quote
Old 1st December 2008, 13:58   #32
Swifty2008's Avatar
Originally Posted by manikahuja View Post
Manik
Hello Manik,
I have 2006 Swift VXI. I would like to own a OBD2 toolkit. Following your instructions, I have narrowed on the following toolkit:
OBD Diagnostics, Inc. - OBD2 All-In-One Scan Tool w/ USB
But I would like to know whether if I manage to get it, I can connect and use with Swift?
Appreciate if you could PM your contact.
Thanks.
Swifty2008 is offline   Reply With Quote
Old 2nd December 2008, 15:09   #33
ask77's Avatar
Originally Posted by Swifty2008 View Post
Hello Manik,
Thanks.
Maybe you can try the ELM 327 based used tool it is available in India with these people ELM 327 USB | OBD-II Scantools | iRide Technologies
ask77 is offline   Reply With Quote
Old 26th January 2010, 08:10   #34
anku94's Avatar
Thanked: 33 Times
Sorry for reviving such an old thread, but can anybody tell me if Chevrolet Spark is OBD compliant or not ? Just curious....
I think it is coz my dad was saying that the service center guys connected a laptop to some place near the steering and got all the details.
anku94 is offline   Reply With Quote
Old 26th January 2010, 22:23   #35
anku94's Avatar
Thanked: 33 Times
I found this port in my car. It's some diagnostic, I'm sure of that. But is it OBDII ?
Assuming it is...are GM Daewoo Spark OBDs standard ? I mean, do I need a scanner to read this ?? Or just a serial cable would suffice ?
Old 27th January 2010, 02:52   #36
pranavt's Avatar
Thanked: 274 Times
Looks very much like OBDII, yeah.
Old 30th January 2010, 02:37   #37
driverace's Avatar
Thanked: 164 Times
Lightbulb Some more of the concept..
( I seem to remember, of reading somewhere, the Skyline became a overnight star in Drift championships owing to its wide-ranged-remapability of the ECU thr a simple lappy connection from n00bs-to-geeks!
can anyone share some more on that?)
Other than ECU interfacing/data reading,
I was also thinking more on the line of a suggestive/interactive role of the Carputers, what I mean is:
Inputs:
-Engine temps (multiple points- with history)
-Coolant inlet/outlet temperatures (in correspondence with above point)
-Brake callipers reading (read- travel/retract positions) --determine sticky pads/ change requirement based on increased travel !
-Speed picks from 4Wheels ( to get history of driving Vs relative responses-- may be to prove that ABS works/worked at XX time !!)
-Tire Pressure monitoring ( remind air fill / alert a puncture /or even over inflation due to continuous runnings!!)
-Door lock-feed (safety!)
-fuel level ( real time fuel indications - mark patterns of fuel consumptions!!)
-Auxiliary power use in car ( ICE+A/c+Headlamps+Carputer itself!+others) <too much !! I know!!>
-Gear shifts with rpm and torque at shift points ( history- perhaps may help us fine tune our driving style/perfections!!)
-Clutch/Accelerator/Brake lever travel wrt the respective effects curves !!
-remind Oil changes/fuel refill due periods + probable vibration sources if any
-Ground clearance monitoring with loads/ brushing of tyres to sidewalls!-alerts
terrain identification/warnings!!
Can we think of achieving these ?! (quite a lot, I think, but surely not out of reach.. when we are already installing carputers here!!)
Care.
Ace.
driverace is offline   Reply With Quote
Old 30th January 2010, 11:53   #38
UniqueMods's Avatar
Thanked: 50 Times
OBD Types.
J1850 VPW--The connector should have metallic contacts in pins 2, 4, 5, and 16, but not 10.
ISO 9141-2--The connector should have metallic contacts in pins 4, 5, 7, 15, and 16.
J1850 PWM--The connector should have metallic contacts in pins 2, 4, 5, 10, and 16.
If your vehicle has this style connector, but doesn't have these pins populated, you probably have a pre-OBDII vehicle. To add some confusion, even having the connector with the contacts shown above is not a guarantee of OBD II compliance. This style connector has been seen on some pre-1996 vehicles which were not OBD II compliant.
OBDII pin out, Signal Assignments - pic attached.
  1. -
  2. Bus positive Line of SAE-J1850
  3. -
  4. Chassis ground
  5. Signal ground
  6. CAN high (ISO 15765-4 and SAE-J2234)
  7. K line of ISO 9141-2 and ISO 14230-4
  8. -
  9. -
  10. Bus negative Line of SAE-J1850
  11. -
  12. -
  13. -
  14. CAN low (ISO 15765-4 and SAE-J2234)
  15. L line of ISO 9141-2 and ISO 14230-4
  16. Battery voltage
Checking which will work.
I have a Santro and i have attached a pic of my obd connector.
mine matches ISO 9141-2 as i have connectors pins 4, 5, 7, 15, and 16.
This way every one can check their ODB pin layout and find out which scanner will work.
UM
UniqueMods is offline   Reply With Quote
Old 18th March 2010, 02:22   #39
speed0mania's Avatar
Any news on what works with swift?
speed0mania is offline   Reply With Quote
Old 26th March 2010, 14:50   #40
The swift has connector pins on 4,5,6,7 and 14,16. What protocol would that be?
Old 26th March 2010, 17:57   #41
COUGAR's Avatar
Thanked: 86 Times
Default Gypsy Connector
Struggling with this myself. Attached is a shot of the connector on my gypsy (MPFI 2007 model).
It has wires on 4,5, 7 and 16. based on (above) is it 9141-2?
the last attempt to connect a scangauge II did not work. The gauge did not go beyond the "Connecting..." message. Didnt change any settings on the Gauge (refresh settings etc) and connected it as is. The Gauge is otherwise connected to an Emberra and works fine there.
Any help will be appreciated.
COUGAR is offline   Reply With Quote
Old 14th April 2010, 12:34   #42
wmanu's Avatar
Experts, can anyone advice which one from these work with Swift Zxi (Mar 2006, Patrol)?
Any one tried OBD scan tools with Swift, so far?
wmanu is offline   Reply With Quote
Old 26th April 2010, 17:47   #43
mtnrajdeep's Avatar
Thanked: 101 Times
Default Swift Diesel OBD connector
I have a Swift VDi ABS model (Aug 08) and the connector has additional connections. There are connections for 4,5,6,7 and 14 and 16. I am attaching a snapshot below. Can anyone tell which protocol this connector is for?
mtnrajdeep is offline   Reply With Quote
Old 27th April 2010, 15:17   #44
Thanked: 103,333 Times
You guys should probably search within this mega OBD thread (OBD (On-board diagnostics) for Indian Cars). I see the Swift is well covered in that discussion.
Old 27th April 2010, 15:54   #45
Rehaan's Avatar
Thanked: 25,037 Times
Heres an iPhone app that lets you tap into your OBD port with some additional hardware.
DevToaster - Rev - iPhone app development, Great iPhone apps, and more
However, it costs $39.99 !! Plus you have to buy some required hardware.
There is also a FREE "Rev Lite" version, but you'll need to but the interface hardware for that as well!
cya
R
Standards-based CAN/OBD communication in Etios ECU vishnugs Technical Stuff 22 12th August 2016 07:59
Punto 1.2 OBD issue : ECU replaced at Fiat's cost ~~h Technical Stuff 18 1st May 2012 09:36
Grande Punto : USB Interface / Auxiullary Interface / IPod Interface wind_rider In-Car Entertainment 1 4th March 2010 16:43
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
All Honda cars e10 compliant superamerica The Indian Car Scene 12 17th August 2007 13:22
