Old 23rd February 2006, 17:30   #1
shazikon's Avatar
Thanked: 19 Times
Default Variable Intake system and performance air filter
Newer cars in INdia like the Aveo nad Ford Fiesta come with VIGS or Variable intake geometry manifolds.. How does this work?? Since this is nothing but controlling the air inlet (into cylinders) thorugh valves which open or close based on speed at which the automobile is moving. By fitting a high flow air filter like K&N on such intake manifolds, it is assured that more air flows even at lower car speed and valves will open at a much lower speed than the OE calculations... Wont this affect the air-fuel ratio and affect the ECU operation?
shazikon is offline   Reply With Quote
Old 23rd February 2006, 20:27   #2
Mpower's Avatar
Thanked: 1,687 Times
How do you know the Fiesta has it. Is it the 1.6 engine or the 1.4
Optra also has it on the 1.6NY.
Air filter and Air intake sunilvarma Technical Stuff 10 4th November 2010 10:58
Diffrence between an ordinary cold air intake and a ram air intake?? Vys De BlUR Technical Stuff 24 1st April 2008 12:59
Best air filter or cold air intake for Skoda RS Kartik9500 Modifications & Accessories 9 7th February 2008 03:43
Ford Fusion FE - Air Filter, Intake, LPG / CNG, etc pepperoni Modifications & Accessories 2 29th April 2007 23:15
