Old 14th September 2011, 01:28   #16
Thanked: 229 Times
Default Re: Smell in Honda CRV cabin ...after revving hard.
The smell that has been described could also be from the catalytic converter. Try checking the exhaust pipe for the smell. Also the smell would permeate the cabin from the area where the gear shift / handbrake is usually mounted, this could also explain why you get that smell even when the Air con is off and set to recirculation mode.
It is the heat and smell from the catalytic system that gets inside the cabin from the area I mentioned above. Check your exhaust system for leaks especially the joints where the exhaust is coupled to the catalytic converter.
Traveler is offline   (2) Thanks Reply With Quote
Old 7th August 2012, 11:03   #17
prateek_ch's Avatar
Originally Posted by humyum View Post
Burning clutch smell, Happens in the swift petrol too. Normal. Dont worry about it.
Humyum
I have a similar situation with my Swift VXi 2006.
The burning smell comes into the cabin with AC on recirculate whenever there is spirited driving(high RPMs).
Is this normal?
Am I messing the clutch? The clutch is 10k Kms old.
prateek_ch is offline   Reply With Quote
What to check for outside smell entering the car cabin? satish_appasani Technical Stuff 25 10th May 2018 17:24
Revving hard! jphukan Introduce yourself 1 17th August 2016 14:19
Traffic smell entering Cabin through the Boot Voyager-1 Technical Stuff 12 23rd July 2014 21:25
burning smell in car cabin harry2223 Technical Stuff 12 22nd May 2012 13:53
Bad smell after starting the car (NHC-2004) anandpadhye Technical Stuff 35 23rd August 2007 10:50
