Old 25th February 2006, 11:53   #1
cooldude1988765's Avatar
Thanked: 108 Times
Default WagonR problem
Hi everybody
I have a wagonR Which is 2.5 years old and has done 20k kms.Of late there has been a decrease in the performance of the car i.e the pick up has reduced and even for mild slopes i have to change to 1st gear.
I always give the car for servicing to Varun Motors at regular intervals.
I am in a fix as to what the problem could be.I fill speed petrol from a reputed BP outlet(I have been going to the same petrol bunk from the time i bought the car).I am filling speed from the past 1 year.Do you think the problem is due to the fuel? please help
cooldude1988765 is online now   Reply With Quote
Old 25th February 2006, 13:31   #2
extreme_torque's Avatar
Thanked: 1,487 Times
Finish the remaining petrol in the tank and fill from another outlet. If this doesnt help, clean the injectors. There is nothing much that can go worng with a MPFi car.... lest its something terrible.
extreme_torque is offline   Reply With Quote
Old 25th February 2006, 13:44   #3
luv_bikelover's Avatar
hi i too own a wogonr , my car hasnt given such kinda trouble but i guess check the injection system give it a clean and maybe fuel is problem so tyr filling premium speed for sometime else take a summary for a engine i dont think mpfi engines face this kind of problems
luv_bikelover is offline   Reply With Quote
Old 25th February 2006, 14:53   #4
SLK
SLK's Avatar
Thanked: 190 Times
1st gear?.... then it 'should' be clogged injectors.
Better take it to Maruti Service Station.
SLK is online now   Reply With Quote
Old 25th February 2006, 16:00   #5
Thanked: 108 Times
I dont have any doubt on the fuel because i have been filling there from many years even for my previous cars
Old 26th February 2006, 01:51   #6
nitrous's Avatar
Thanked: 285 Times
Get a tune-up for ur engine from a good garage in Hyd.
That must solve the problem.
Old 26th February 2006, 02:20   #7
check engine oil, check spark plugs, and as everybody else mentioned get the injectors cleaned. i'm sure this should solve the problem.
abhishek2 is offline   Reply With Quote
Old 26th February 2006, 03:44   #8
.anshuman's Avatar
Thanked: 9,159 Times
the problem is definitely with the injectors or any of sensors malfunctioning,i had a jerking problem with my accent that was solved by cleaning the injectors.
Maruti WagonR over Hyundai Eon? EDIT : Bought WagonR with ABS / Airbags BoneCollector Hatchbacks 35 22nd May 2015 11:49
Only a WagonR can replace a WagonR ! From F10D to K10B.. DCEite Test-Drives & Initial Ownership Reports 27 19th April 2014 23:02
Problem with WagonR central locking paish Technical Stuff 7 18th December 2007 16:45
WagonR or Swift?(calling swift and wagonR owners) rajshenoy Hatchbacks 43 29th March 2007 09:54
