Old 21st September 2011, 18:34   #1
razor4077's Avatar
Thanked: 258 Times
A strange problem cropped up in my 05 elantra crdi today. While driving, the battery light came on and the power steering suddenly had no assist. It became rock hard, as it is before turning on the ignition. Everything else was working fine - brakes, ac, stereo etc. Stopped the car, turned off the ignition, restarted, and voila, steering was fine again and no battery light. Drove cautiously thereafter, and the issue did crop up once again. This time it disappeared in a couple of seconds without having to turn off the ignition.
Has anyone faced this issue in an elantra or any other car? Could it be an issue with the power steering belt? Electricals? Any inputs will be appreciated.
razor4077 is offline   Reply With Quote
Old 21st September 2011, 18:58   #2
.anshuman's Avatar
Thanked: 9,159 Times
Default Re: Elantra crdi steering issue
Elantra CRDi had a common belt for PS, Alternator etc, since at the time when the PS loses assist the charging light also comes up, get the drive belt checked.
.anshuman is offline   (1) Thanks Reply With Quote
Old 21st September 2011, 23:07   #3
razor4077's Avatar
Thanked: 258 Times
Makes sense. The drive belt was always a bit noisy, but the guys at hyundai said it was nothing to worry about. Will get it checked. Thanks
Old 21st September 2011, 23:56   #4
suhaas307's Avatar
Thanked: 6,953 Times
I don't think it's a steering issue. I had the same problem with my 7 year old Santro. I would lose the power-assist in the steering-wheel and the car would just die on me, while moving! I had to start it and get it going, and it would stall in 2nd gear while accelerating, soon after the first stall! It happened over and over again.
Does your car stop, as in stall while on the move, or is it only the power-steering?
It has been sorted out though. Apparently, it has something to do with the Crankshaft Sensor and the TPS (Throttle Positioning Sensor). They also said that the spark plugs and plug wires were faulty and contributed to the problem. We has to get these things replaced and the bill came up to Rs. 6000 exactly!
http://www.team-bhp.com/forum/techni...ng-santro.html (My 7 year old choking Santro)
I don't have the bill with me, at the moment. I shall acquire it tomorrow and pen down the list of things I had to get changed.
Don't worry. it isn't a very serious issue.
suhaas307 is offline   Reply With Quote
Old 22nd September 2011, 09:26   #5
razor4077's Avatar
Thanked: 258 Times
Nope, car doesn't stall. Just the assist to the power steering cuts out on some rare (until now) occasions. It's a diesel, so spark plugs don't factor in.
It all points to a drive belt issue, but will get a thorough check up done in any case.
@anshuman: any idea what's the damage for a drive belt replacement? Might even be an issue with the pulley - had faced that with my scorpio.
Old 22nd September 2011, 09:29   #6
suhaas307's Avatar
Oops yeah, I was under the impression it was a petrol Elantra. Didn't quite read it clearly enough. My bad.
Do get a thorough diagnosis of your car's engine. How old is your car and how much has it done?
Old 22nd September 2011, 10:01   #7
razor4077's Avatar
Thanked: 258 Times
6 years old, done around 75k kms. Been with me for over a year, and this is the first "issue" I've faced.
Old 22nd September 2011, 10:17   #8
suhaas307's Avatar
That is quite a number of miles it has notched up there. Do get a thorough engine diagnosis done. You will get a comprehensive list of what parts might need to be changed, now, or perhaps sometime in the future. Don't worry, a few regular running parts might need replacement. Not uncommon with older cars, especially diesels.
Old 22nd September 2011, 12:27   #9
.anshuman's Avatar
I don't really remember how much i paid for the drivebelt. Let me check the old service bills.
Elantra Petrol vs Elantra CRDi palani81 Sedans 1 24th October 2006 13:59
Elantra GT vs Elantra Crdi(Was skoda vs elantra) azifali Sedans 39 17th August 2006 12:56
elantra crdi gtd vs elantra crdi (leather pack) super_700a Sedans 3 10th August 2006 07:38
Suggest me, Elantra CRDi or Elantra GLS hsmraj Sedans 16 11th April 2006 02:28
Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi lamborghini Sedans 36 30th January 2006 00:03
