Old 23rd September 2011, 17:48   #16
k_nitin_r's Avatar
Thanked: 74 Times
Default Re: What would you do if the vehicle you are in caught fire !
Originally Posted by roy_libran View Post
First, kick myself for being in a vehicle with both Power Windows and Central Locking.
I do not know why this thread has central locking discussed as something that prevents the doors from opening. Every vehicle equipped with central locking has a "manual override." Flip/pull the unlock and then pull the handle to open the door. A central locking system with security will simply sound the alarm when you manually unlock and open the doors.
k_nitin_r is offline   Reply With Quote
Old 26th September 2011, 16:26   #17
esteem_lover's Avatar
Thanked: 451 Times
Sometimes you can run into problems at the rear , due to child lock options.
That has nothing to do with CL. Cars without CL also have child lock.
Old 26th September 2011, 18:18   #18
aaggoswami's Avatar
Thanked: 1,542 Times
1) Dont panic. Quite simple on paper/computer screen, but the most difficult to implement in real life. Nevertheless, try to do this.
2) Have the toolkit/hammer with you. This can help a lot, much more than one can imagine
3) Dont waste too much time on opening doors or windows as those things are most likely NOT going to work.
4) Try to open hatch, most likely it has a mechanical link ( to the best of my knowledge,correct me if I am wrong ) or try to open the boot lid ( for sedans ). Flipping over the rear seat and coming out of rear hatch/boot space is better than attempting to break open the windows/windshields.
5) Try to hit the center of rear/front windscreen, it might help break open faster.
6) Always have one window slightly open, I do follow this, specially in monsoon where changes of water making other things inoperable is higher.
This is helpful during fires and breaking off widows is easier.
7) Act very fast and unlock the doors as soon as you notice fumes.
aaggoswami is offline   Reply With Quote
Old 27th September 2011, 08:52   #19
ghodlur's Avatar
Thanked: 2,438 Times
Red face Re: What would you do if the vehicle you are in caught fire !
If you are in a running car which catches fire or you see smoke, pull to the side immediatele, ensure the engine is switched off, try to get out of the car using whatever means (hammer, sharp object etc). I dont think most of the doors get locked in case of any fire as a fail safe measure unless the door themselves get jammed due to whatever reason. Once out of the car, help any occupants of the car get out. After reaching safe distance from the car, call for help (fire engine, police patrol vehicle etc).
ghodlur is online now   Reply With Quote
Old 27th September 2011, 08:53   #20
Thanked: 63 Times
Originally Posted by Tushargohil View Post
Your 2 cents are worth a lot buddy. Just ordered one.
Pray I may not ever use it in my car.
lambuhere1 is offline   Reply With Quote
Old 27th September 2011, 12:07   #21
Found this on ebay, not sure about the quality though :
CAR EMERGENCY LIGHT, SAFETY HAMMER & BLADE - MRP 699 | eBay
sam_hyd is offline   Reply With Quote
Spotted a Parked vehicle with key in place - What would you do? selfdrive Street Experiences 24 8th June 2012 16:33
Indica Vista caught fire on start-up adinathr Technical Stuff 7 8th August 2011 11:39
Ford Fusion Caught fire:Will company cover warranty Pani The Indian Car Scene 55 25th April 2011 21:04
'07 Honda City ZX nearly caught fire! arunksaral Technical Stuff 21 4th February 2011 14:47
What would you do if a vehicle hits you/you hit a vehicle! rajinibm Street Experiences 30 3rd June 2010 12:53
