Thread Tools
Old 27th February 2006, 22:22   #1 (permalink)
moralfibre's Avatar
Default M800 Type 1 Mods
A friend of mine owns a Maruti 800 '87 model. He would like to know if the existing cylinder head can be replaced with the head of the MPFi 800's (5 Speed ones)? Is it a direct fit or will it require some modifications to accomodate the MPFi engine head?
Secondly can the 5 Speed gearbox be fitted in lieu of the existing 4speed box?
__________________
"As long as there are short, balding, middle-aged men, there will always be a market
for the Porsche 911." - A BMW Owner. :)
Old 25th February 2008, 22:16   #2 (permalink)
rider60's Avatar
okay i missed this thread, and i have an answer too. my cousin did this head swap when he had to do the engine overhauling and dint bother much about the GB, he was happy with the power there after.
and moralfiber, did your friend do this swap and what is the current status of your friend's car is it sold or something?
rider60 is online now   Reply With Quote
Old 25th February 2008, 22:50   #3 (permalink)
gopz's Avatar
Interesting! I would watch this thread.
gopz is offline   Reply With Quote
Old 26th February 2008, 09:28   #4 (permalink)
humyum's Avatar
Both would be a direct fix.No problem at all.Have seen individual cases of both of them.
__________________
Life is a lemon and i want my money back!!!!
humyum is online now   Reply With Quote
Old 26th February 2008, 10:46   #5 (permalink)
krazydriver84's Avatar
Hey Can you please tell me how much the engine and gear swap might cost me?
I have a 2003 model.
__________________
Rockin to the Sound of the Engine...
krazydriver84 is offline   Reply With Quote
Old 26th February 2008, 19:34   #6 (permalink)
rider60's Avatar
approximately 25grand is what it cost my cousin! i dont have the complete list of what has been done on the car but then it was awesome to drive the car after that!
i think he got the whole head,bore and piston set along with the mpfi unit!
Old 26th February 2008, 20:21   #7 (permalink)
Default Cylider Head Swap
HI HUMYUM, i think there is great confusion, carb. cyl head and mpfi 5speed cylinder heads can not be inter changed. The cyl block is allso different. Certainly not direct fix.
alankarmotor is offline   Reply With Quote
Old 26th February 2008, 21:04   #8 (permalink)
v1p3r's Avatar
MPFI 800 is also 2 valves, IIRC. I don't see what advantage you will get.
Try sourcing an Alto 1.1 engine with wiring and gearbox. That should be fun.
__________________
Singh is king?! He's a bloody baadshah!
v1p3r is online now   Reply With Quote
Old 26th February 2008, 21:22   #9 (permalink)
rider60's Avatar
just that he had an engine rebuild done and with mpfi i think he got 45bhp instead if 40! nothing big!
Old 27th February 2008, 10:13   #10 (permalink)
Hey I had this question for a long time in my head, but no could answer... good info, Just curious, does this head swap apply to all the maruti suzuki engines, I mean bigger once too [zen, esteem,etc], are 4 valve heads direct swap with the two valved once.
dinar is offline   Reply With Quote
Old 28th February 2008, 01:02   #11 (permalink)
v1p3r's Avatar
You will need to swap more than just the head. Wiring harness, ECU, manifolds, sensors, all that jazz.
Yes, in most cases. But compression differs.
__________________
Old 28th February 2008, 02:01   #12 (permalink)
rider60's Avatar
well i did say there were other things too and i dint have the complete list. thats the reason the total cost of rebuild was 25k! or does it cost even more?
Old 28th February 2008, 03:39   #13 (permalink)
v1p3r's Avatar
Rebuild? Pistons, rings, bearings, gaskets, labour etc should cost well over 25k, if that's what you mean by rebuild.
__________________
Old 28th February 2008, 06:12   #14 (permalink)
rider60's Avatar
and you mean the mpfi kit including the harnesser, costs extra apart from all that you mentioned?
Old 28th February 2008, 13:08   #15 (permalink)
v1p3r's Avatar
Yes it does. The parts that I mentioned are normally used in an engine rebuild/overhaul.
__________________
Thread Tools
Accessories & Mods for Ford Fusion ( New Type) Iyer Modifications & Accessories 7 19th May 2008 11:06
landing diesel engine in m800 and other mods harry2223 Modifications & Accessories 18 16th January 2008 18:26
Advice for Engine enhancements/ mods - 5 Speed MPFI M800 gopz Modifications & Accessories 10 11th September 2007 12:55
Modifiction of Type I M800 to Type II sathyaprakash Modifications & Accessories 17 3rd July 2007 21:56
S350 with AMG mods, S-type islero Super-Cars & Imports in India 1 23rd April 2005 00:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
