Old 29th September 2011, 15:23   #1
Default Sensitive Sensor
My new i20 Sportz has a fully loaded anti theft mechanism. The flip side is everytime the car hood is being cleaned, even slight pressure causes the alarm to go off... tried many options but still does not work. It becomes irritating when kids are playing they playing tap the hood. The only alternative is to use the manual key to lock it. Any suggestions on how to get the sensitivity reduced?
brillian is offline   Reply With Quote
Old 1st October 2011, 04:26   #2
dhanushs's Avatar
Thanked: 4,507 Times
Default Re: Sensitive Sensor
Call the company customer care. Most modern systems come with an option to reduce the sensitivity. I'm sure they should be able to help you. Infact, they may even guide you through a DIY, to reduce and increase sensitivity.
dhanushs is offline   (2) Thanks Reply With Quote
Old 11th October 2011, 11:12   #3
SURPRISE! The technical team does not know how to reduce sensitivity - they have advised me to remove the speaker wires to resolve the problem! Sanity check - anyone!
MAP Sensor golem Technical Stuff 11 12th August 2014 15:46
Cam Sensor-Crank Sensor-TDC Sensor. Are They The Same Thing? genesis Technical Stuff 8 5th October 2009 11:17
Speed sensitive steering and MP3 Din 1 VMG Technical Stuff 3 16th November 2007 13:33
We need to be more sensitive towards security issues Zappo Shifting gears 2 30th December 2005 06:56
