Old 19th June 2015, 15:58   #46
RSR
RSR's Avatar
Thanked: 4,549 Times
Default Re: Excessive/unnecessary engine braking
Originally Posted by createrkid View Post
Other suggestions are more than welcome.
I suspect it could be an issue with either the Idle Air Control Actuator/Valve (it could be clogged) or the Throttle Position Sensor.
Please get your engine oil & oil filter changed if it's long overdue (even if it's not related to this issue), as it may harm the engine otherwise.
RSR is offline   Reply With Quote
Old 19th June 2015, 16:34   #47
Thanked: 14,610 Times
Thanks for the suggestions guys, I will try them over the weekend and update the thread if anything has changed. Other suggestions are more than welcome
Nope, check engine light is off as it should be
Please get the engine oil, air filter, fuel filter and oil filter changed.
I agree but I have doubts that OP says the acceleration is normal only suspicion is braking being more from the engine side so if the throttle position sensor is faulty, acceleration should be affected. Right?
a4anurag is online now   (2) Thanks Reply With Quote
Old 19th June 2015, 16:46   #48
Thanked: 465 Times
Hyundai Getz gls (petrol - 2005)
So I was driving and I noticed that the engine seems to be braking a lot these days. The car has no issues with accelerator input. It still seems very punchy. Noticed an evident decrease in speed in third gear when I let go off the accelerator . I don't think that brakes are the problem because acceleration is quite the same as before. Can anyone point out to me what's wrong with my car? Also, I haven't changed the engine oil in quite some time, could this be the issue?
Agree with what most of the fellow BHPians advised. Check the tyre pressure, condition of the lub oil and condition of the wheel bearings. If any of these are responsible, you will also see drop in the fuel efficiency.
If the throttle calibration has been affected, I expect to see higher idling rpm. This will reduce your fuel efficiency more in the city than on the highway.
Rahul Bhalgat is offline   Reply With Quote
Old 19th June 2015, 18:03   #49
RSR
RSR's Avatar
Just to clarify, I mentioned those two in addition to / after ruling out other possible causes mentioned by fellow BHPians (in the absence of an error code). Then I would get the Idle Air Control (IAC) Valve/Actuator checked and cleaned if necessary. Only then would I suspect the Throttle Position Sensor (TPS). A vacuum leak could be another possible cause.
It's indeed true that a classic symptom of a faulty TPS is acceleration getting affected in some way. It's rarer for a faulty TPS to cause unwanted engine braking, but it can do so, especially in a vehicle with a conventional accelerator cable like the Getz.
Intermittently Silent Horn nura Technical Stuff 50 19th April 2018 07:56
Hyundai drags Mahindra Renault to court (over the "Sandero" name) subbarao The Indian Car Scene 67 3rd November 2009 09:45
Help my computer screen goes pink intermittently rahul_intlad Gadgets, Computers & Software 17 17th July 2007 14:01
Which off these "Drags" would you like to see? Shan2nu The International Automotive Scene 3 14th March 2004 14:16
