Thread Tools
Old 1st March 2006, 17:47   #1 (permalink)
mtnrajdeep's Avatar
Question Zen 98 model service manual
Hi
I am rajdeep, a new member here. I stay in hyderabad
I bought a 98 model zen (run 54000 km) from maruti truevalue last year.
When I start the car in the morning, I can see light colored smoke, after which there is no visible smoke. Also, I have difficulty in cold starting. Could anyone tell me what needs to be checked?
Also, where can I find a service manual for the 98 model zen? (tried searching the forum, but was unable to find anything) could anyone please email it to me if they have it?
mtnrajdeep is offline   Reply With Quote
Old 2nd March 2006, 08:21   #2 (permalink)
protege's Avatar
Yours is a carb.. so this will happen always.. it happens with my Zen98 too.. done 55k... in your next service ask them to clean the carb jets.. also use good additives to keep the fuel jets clean.. You should also press the acceleator a bit while cold starting to force some fuel for burning.. But all the above solution will not eliminate the problem (unless you pull the choke.. which overflows the engine with fuel.. not recommended at all).. it will make the cold start a little faster.. for me it takes about 30s to 1.5min to start. These problems doesn't happen in MPFI engines.. However after the engine is warm.. it should be smooth.
__________________
Protege
protege is offline   Reply With Quote
Old 2nd March 2006, 11:59   #3 (permalink)
speedsatya's Avatar
go to any MASS and you can order a MH410 service manual for 600rs ...for mpfi u have to pay 600 extra
speedsatya is offline   Reply With Quote
Old 2nd March 2006, 12:30   #4 (permalink)
mtnrajdeep's Avatar
@protege: yeah, its a carb model. Will do what you suggested! thanks. do you have any idea about the light colored smoke that i see during the cold start?
@speedsatya: will do so ...thanks
Old 6th March 2006, 08:15   #5 (permalink)
Rehaan's Avatar
Does it happen all the time or only on particularly cold mornings?
cya
R
Old 7th March 2006, 08:14   #6 (permalink)
mtnrajdeep's Avatar
Smile
cya
R
It happens only when i start it in the morning, the smoke is not seen later while driving. Being in hyderabad, i wouldnt say that its cold in the morning in this season
-rajdeep
Old 20th March 2006, 08:42   #7 (permalink)
mtnrajdeep's Avatar
Hi
This problem of cold starting got solved!! The culprit in this case was the starter motor, which needed servicing and the belt whihc was replaced!!!!
Thanks for your inputs!
-rajdeep
__________________
Aug 08 Swift VDi ABS
Oct 07 SX4 - ZXi
2002 Pulsar 180
1998 Zen LX -- SOLD
Old 18th February 2008, 21:11   #8 (permalink)
eagle_f1's Avatar
Default 1998 Carb ZEN Service Manual
I require the service manual for 1998 carb ZEN any idea where can i procure it from ???????
__________________
SNM : Run It Through Your Veins
eagle_f1 is offline   Reply With Quote
Old 18th February 2008, 21:38   #9 (permalink)
Just walk over to your friendly neighborhood Maruti Authorized Service Centre, and they'll get you a copy - costs around 500 INR.
techn0l0gist is offline   Reply With Quote
Old 19th February 2008, 10:40   #10 (permalink)
sushrutha's Avatar
I have a soft copy of Zen Manual.
__________________
Honda City
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 19th February 2008, 20:44   #11 (permalink)
eagle_f1's Avatar
Pls e mail it to me buddy !!!!
__________________
Old 19th February 2008, 21:16   #12 (permalink)
nripin's Avatar
Do u have a service manual or a owner manual ?
__________________
Cheers!
Nripin Babu.
nripin is offline   Reply With Quote
Old 20th February 2008, 10:16   #13 (permalink)
sushrutha's Avatar
I have Owner's manual
@eagle f1
Chk out you mailbox
__________________
Honda City
Maruti ZEN - SOLD
Maruti 800
Bajaj Pulsar
Old 21st February 2008, 08:13   #14 (permalink)
nripin's Avatar
Any one having a service and repair manual for a Carb Zen ?
PS:i'm not talking of owner manual
__________________
Cheers!
Nripin Babu.
Thread Tools
Does anyone have an MM540DP user/service manual? princezahed 4x4 & Off-Roading 3 4th September 2008 13:39
Wanted Service Manual E250D W210 nripin Technical Stuff 0 25th February 2008 11:26
service manual for my Frazer1000-2007? FrazerRazor Motorbikes 5 6th February 2008 14:29
Service Manual for '94 Mazda MX-6 RJK Modifications & Accessories 8 15th June 2007 09:08
Manual for Merc E220 W124 1996 Model kailashnj Technical Stuff 6 25th March 2007 04:01
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
