Old 6th October 2011, 11:14   #1
Sankar's Avatar
Thanked: 4,654 Times
Default Hyundai i10 1.2 Kappa Uses a Non Standard Spark Plug
I was looking for Iridium plugs for my i10 Sportz and contacted the dealer who sourced me the iridium plugs for my AStar. But i was told that there is no alternative spark plug available for the i10 from any manufacturers. This was a bit hard to digest for me since i thought car makers have to follow a standard. But i was wrong and a bit of searching on the Internet i learnt that the 1.2 Kappa motor indeed uses a different spark plug with a longer reach.
Edit: If someone does come across an alternative. Please list it here
Old 6th October 2011, 19:30   #2
Thanked: 1,083 Times
Default Re: Hyundai i10 1.2 Kappa Uses a Non Standard Spark Plug
In the good old days spark plugs had only one thread diameter. Today there are lot of thread diameters! so if you want spark plug spanners in your collection, you need at least three sizes.
Spark plugs used to come in various thread lengths also, hence I do not think that i10 plug is non standard, it is just one of those sizes not interchangeable with other engines prevalent in India.
Here are links to all spark plug related technical data Spark plugs uk, NGK, Champion and Denso spark plugs
and the NGK chart NGK spark plugs symbol code which decodes the diameter, thread size, heat value etc.
Croiss Reference Cross reference other manufacturers to NGK
Aroy is offline   (2) Thanks Reply With Quote
Old 7th October 2011, 10:43   #3
Sankar's Avatar
Found one Spark Plug Hyundai i10 1.2 from NGK - 4288 Its one step colder than stock though. Stock: Spark Plugs - NGK - LZKR6B-10E Look at that thread reach, 26.5mm!
Found another one too. VXUH22l/IXUh22l http://www.globaldenso.com/en/produc...2010/07_4.html
Sankar is offline   (1) Thanks Reply With Quote
Old 12th May 2014, 15:17   #4
latentpotential's Avatar
Thanked: 380 Times
Bumping up this thread.
Any viable alternatives available in India?
The standard "Champion" plugs are for approx 400 each at Hyundai A-S-S
If possible I would go for Iridium plugs once.
latentpotential is offline   Reply With Quote
Old 16th January 2018, 09:07   #5
Sankar's Avatar
NGK Iridum Alternative: ILZKR7A
PS: Like the Denso alternative above this one is also one step colder than OE.
Old 16th January 2018, 22:28   #6
R2D2's Avatar
Thanked: 2,052 Times
Just in case you're interested here's another i10 spark plug topic.
should-i-upgrade-my-spark-plugs
Old 17th January 2018, 08:00   #7
Sankar's Avatar
Oh yes I am interested because I have an i10 Kappa now after a long gap, the one this thread was made for was sold 3 - 4 years ago. I have already ordered the plugs.
Old 24th January 2018, 12:31   #8
Sankar's Avatar
NGK Laser Iridium (OE series) sparkies for the 1.2 Kappa. Densos are expensive and work the same. Iridium center and Platinum ground electrodes.
What will happen if one uses a hotter spark plug fighterace Technical Stuff 33 30th March 2013 20:08
Is It necessary to add new plug wire,ignition coil if adding new NGK Iridium Plug finetuning Modifications & Accessories 20 12th September 2011 10:45
1989 Bullet(Standard)350 CC oil leak from below the spark plug..help needed makeshr Motorbikes 6 15th December 2010 21:04
i10 Magna (1.2 Kappa) Vs i10 Sportz (1.2 Kappa) MutantX Hatchbacks 52 12th September 2010 00:55
Need help to plug USB in i10 Kappa sportz version. sam_boy In-Car Entertainment 11 7th October 2009 20:17
