Old 2nd March 2006, 13:58   #1
subbarao's Avatar
Thanked: 39 Times
Default High engine Noise
Dear BHPians,
As i drive ZEN 2001 MPFI, 24k kms done, mainly on B'lore streets, since from 15-20 days, i experiencing sudden rise in engine noice, when in closed glass, i hearing like booom noice, first it was very silent,smooth on both LPG & petrol, it's pleasure to sit in, even in engine idle condition. on 25th of feb. i made the service of vehicle in RNS B'lore, complaing them about noice, but they are not able identify the problem, after this, i contacted my old experinced mechanic, he says there may be a probem in fuel injectors/air/vaccum pipes, but i hesitate to give him.
please advice me on this. waitng for your valuable replies.
Thanks in advance.
subbarao is offline   Reply With Quote
Old 3rd March 2006, 09:15   #2
aah78's Avatar
Thanked: 1,751 Times
Thumbs down no replies
you say you had the problems examined by a dealership and a mechanic and they couldn't sort it out...
how would you expect people who haven't even looked at your vehicle to sort out them out for you?
give it some time. people will answer your queries.
aah78 is online now   Reply With Quote
Old 3rd March 2006, 12:56   #3
nitrous's Avatar
Thanked: 285 Times
Dear SubbaRao,
A lot of people don't have much tech about diesel cars,old models,etc.
Even i didn't have any replies when i posted about my Sumo's woes.
Just be patient.Don't expect replies in a single day. Moreover ur problem hasn't been clear to me.
Old 3rd March 2006, 13:27   #4
Thanked: 103,534 Times
Subbarao,
I had a Zen, and clearly remember that the air-con compressor noise was loud with a typical whine. I have seen it in countless other zens.
Try switching the air-con off, and checking for the booming noise.
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 61 13th July 2016 15:49
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
