Old 3rd March 2006, 16:03   #1
nirola's Avatar
Default santro acceleration
hi,
i found this forum very very helpful but i have some specific query regarding santo which i would like to clarify.
since the day one my santro has this unique problem of increasing its speed outomatically. i mean even if i not press the padel it can, sometimes, go to the speed upto 40 kmph .
then we even went to the showroom and that guys attached electronic pad to the socket of car and checked the speed they said its OK.
what we analayised that if we start our car and INSTANTLY move, its speed increasing tremondusly, but if we wait for 20-30 sec before moving (switching to 1st gear) its normal. however i have not seen this problem in any other santro.
i hope this first post will help to my problem
kindly analyise..........
thanks
nirola is offline   Reply With Quote
Old 3rd March 2006, 16:12   #2
speedsatya's Avatar
Thanked: 712 Times
this happens due to the auto choke in mpfi cars ...when u start the car in the mornings or after a long time the rpm will be more ....once the engine reaches operating temperature the rpm comes down ...
this is normal ..nothing to worry about ...
speedsatya is offline   Reply With Quote
Old 3rd March 2006, 17:35   #3
Thanked: 9 Times
This is becaue of the ECU (engine control unit), its a pre-programed electronic device which manages the engine at optimum level based on the inputs it gathers from sensors placed at varous places in the engine in real time (while the engine is running).
One of its functions is to reduce stalling of the engine, this it does by increasing the RPM of the engine when under load. That is the reason one can drive and ECU controlled MPFI car on a level road with out using the gas pedal, the ECU in this case manages the engine. But again this function of the ECU is to protect the engine against stalling and not to drive around in the same way. You can do it for a experiment tough.
My Indica also touches 35-40 kmph on a level road with out the use of the acclerator.
This is nothing to worry about.
Also, on cold starts for MPFI vehicles the engine runs at a slightly high rpm for the first few seconds (typically 15 - 40 seconds) and then settles down on its natural rythm, its better to let the car idle at this stage. Its good to move the car once it settles into its natural idling rpm.
Hope it helps.
Ryder
ryder is offline   Reply With Quote
Old 4th March 2006, 05:48   #4
chetanhanda's Avatar
Thanked: 44 Times
The oxygen sensor on some MPFI cars does not have a heating element, it takes some time to come upto operating temperature.The 02 sensor provides readings based on difference in voltage above a specifc temperature.The ECU adjusts the RPM to mantain correct Air fuel ratio according to various parameters which involves the oxygen sensor as a major input. Since , in the morning/cold engine condition the reading sent to ECU is sent by a cold O2 sensor, the ECU thinks the air-fuel is lean so it increases the fuel, thereby increasing the RPM.
When the sensor comes to operating temperature the correct reading is sent and the engine comes down to normal RPM.
chetanhanda is offline   Reply With Quote
Old 4th March 2006, 06:05   #5
Thanked: 44 Times
Hope it helps.
Ryder
can you explain this.. ?
5.5 lac budget. Best in-class acceleration and handling? senthildsk Sedans 57 5th August 2006 23:55
Acceleration at low gears zen-ith Technical Stuff 8 4th July 2006 20:57
Acceleration List - Worlds Quickest Cars Stratos The International Automotive Scene 13 31st January 2006 18:13
Autocar goofs-up acceleration figures...twice in a row? Shan2nu The Indian Car Scene 19 6th December 2005 13:26
zen acceleration problem hellspawn Technical Stuff 3 10th September 2005 11:15
