Old 23rd May 2017, 14:29   #31
arnabchak's Avatar
Thanked: 1,085 Times
Default re: Car jerking while accelerating
I am so sorry!! I completely misunderstood the caption on the OP. and guesstimated what in the world Adya means by "Jerking while accelerating"!!!
Pun aside, please get your accelerator cable checked. It could be a case of the cable being worn out.Had this problem in my Wagon R and got it rectified after a simple change of the cable.
arnabchak is online now   Reply With Quote
Old 23rd May 2017, 14:42   #32
Thanked: 609 Times
Same here. I was thinking: accelerating while jerking would have been more apt
On a serious note, this could well be due to clogging of spark plugs or fuel injectors.
Nav-i-gator is online now   Reply With Quote
Old 24th May 2017, 07:56   #33
Originally Posted by AutoSphere View Post
I guess the Jazz has a "direct ignition system" (also called distributor-less) which is generally reliable. So the most likely causes could be the fuel quality itself or the fuel-injection system. Have you changed your filling station recently?
Not really. For the last year or so its been the IOCL outlet on the eway.
Now that you guys pointed it out, the topic is hilarious!
freak1201 is offline   Reply With Quote
VW Jetta TDI - noise while accelerating aghosht Technical Stuff 1 3rd August 2012 16:26
Noise while accelerating Punto 1.4 Sujai Technical Stuff 6 7th December 2010 22:52
Squeeking sound while accelerating. Need remedy. Torque123 Technical Stuff 14 2nd November 2009 19:31
Noise & Jerking the M800 while giving accelerator in 1st & 2nd gears. vinfriend Technical Stuff 1 22nd May 2009 23:45
Brake warning light comes on while accelerating bottle Technical Stuff 12 22nd December 2008 23:40
