Old 19th October 2011, 00:20   #16
Thanked: 89 Times
Default Re: Defective A/C in the pre-PDI stockyard FIAT T-JET
@DRIV3R- Are you sure about this?
I'm almost certain the Punto doesn't have this feature. I've driven close to 100kms after the low fuel warning. By the time I reached the filling station, I must have had a litre or two at max...nowhere during this drive did the compressor cut off.
sukrit7 is offline   Reply With Quote
Old 22nd October 2011, 11:19   #17
DRIV3R's Avatar
Thanked: 1,433 Times
Hey guys, I have heard from other Linea and Punto owners who are enthusiasts about this and also remember going through this feature in one of the Discover FIAT threads here.
I tried locating that post, got only this for now.
http://www.team-bhp.com/forum/test-d...ml#post1968940 (Silver Streak Linea :))
Let me check this out by myself and update you guys.
DRIV3R is offline   Reply With Quote
Old 22nd October 2011, 12:19   #18
souravc's Avatar
Thanked: 427 Times
Originally Posted by wannabe-elite View Post
On further probing, found that the pressure of the refrigerant was low.. a boy in the stockyard pushed a pin at the lowside and saw the discharge was low pressure.
The same happened for 3 cars. And, I was told that they could fix it. I was not happy, I mean, if it leaks over the time .. and I know this is a tricky car issue and this gas leak could happen in a few places..
I am not an expert on the matter but i do know for a fact that the refrigerant is inflammable so maybe to limit fire hazard they are kept low . I guess an (inexpensive) refill should do the trick for you - a PDI is supposed to detect these kinds of deficiencies
souravc is offline   Reply With Quote
ARTICLE: Pre-delivery Inspection (PDI) & Check List normally_crazy On buying a car 608 9th July 2018 16:53
Defective Skoda Laura? Nope, defective dealer! Sam Kapasi The Indian Car Scene 146 22nd April 2018 21:41
Ferrari Pre-PDI and Post PDI. ferrariKSA The International Automotive Scene 66 4th January 2012 14:55
Maserati Pre-Pdi and Post Pdi. ferrariKSA The International Automotive Scene 33 21st April 2010 18:57
