Old 5th March 2006, 09:54   #1
zzzehar's Avatar
Thanked: 43 Times
Default The Matiz bootlid doesn't stay up - Lost Pressure?
Hi Guys
the canopy of the trunk of my matiz doesn't stay up. I have to hold it up till the time I am accessing my trunk ! what could be the reason?
Is there a way to get it repaired and how? Thanks.
zzzehar is offline   Reply With Quote
Old 5th March 2006, 11:03   #2
if its the boot lid you are talking about then i guess you will have to replace the hydraulic leaver which holds the boot lid up
sanket12 is offline   Reply With Quote
Old 5th March 2006, 11:04   #3
zzzehar's Avatar
Thanked: 43 Times
Yes, that's a more suited word ! The Boot Lid. Isn't there another way to fill pressure again or something?
Old 5th March 2006, 11:16   #4
better to replace it than try & get the lever repaired
Old 5th March 2006, 11:17   #5
zzzehar's Avatar
Thanked: 43 Times
Any idea how much would it cost? I think both of them went bad !
Old 5th March 2006, 11:22   #6
i guess around 500 each..
Old 5th March 2006, 15:29   #7
jkdas's Avatar
Thanked: 1,436 Times
if thers two of those hydraulic things, replace both as one would have become
weak by now.
Old 5th March 2006, 17:43   #8
SLK
SLK's Avatar
Thanked: 190 Times
Strangely, If you open the Boot lid more often the hydraulic levers go bad sooner than if you don't use it much.
My 800.. now about 6 years old.. perfect... Alto about 3.5years old.. lost strength.
SLK is offline   Reply With Quote
Old 5th March 2006, 22:40   #9
nitrous's Avatar
Thanked: 285 Times
Consider these consumables like tyres and wiper blades.
And they come at 'a dime a dozen'.
If it doesn't challenge you, it doesn't change you! EPMV Introduce yourself 7 30th March 2016 12:17
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Power window doesn't come up! Why? Deeps Technical Stuff 3 10th April 2006 17:27
How about w-matiz or e-matiz Gtea Modifications & Accessories 38 3rd February 2006 02:12
Alloy wheel doesn't come off when trying to replace satish_appasani Tyre & Alloy wheel Section 6 7th August 2005 22:35
