Old 6th March 2006, 00:15   #1
BUSA's Avatar
Arrow Steering Position?
Why Should the Steering not be put in the highest position. The Optra Booket says so (page 3-14) Why shouldnot the highest position be put? Is it to do with airbag or something? Please some one put light on this.
Old 6th March 2006, 00:18   #2
karthik247's Avatar
Thanked: 16 Times
I used to hear a "kkkrrrr" sound when turning the steering when i first got my car. It used to go when the steering position is adjusted. It never showed up again tho'.
karthik247 is offline   Reply With Quote
Old 6th March 2006, 03:38   #3
Rehaan's Avatar
Thanked: 22,606 Times
Interesting... That sounds like the most probable reason.
The airbags are also the reason manuals say to hold the steering wheel at the 9o'clock and 3o'clock position nowadays intsread of the 10 and 2 position.
cya
R
Old 6th March 2006, 05:01   #4
Mpower's Avatar
Thanked: 1,682 Times
what do you mean by highest position. Do you mean full lock?
At full lock, the powersteering pump is pumping fluid against a wall... so to speak because the rack cant move anymore. its like stuffing a sock into a vaccum cleaner. Hence the sound Karthik described.
Old 6th March 2006, 06:42   #5
Rehaan's Avatar
Hey Mpower,
I think he means adjusting the steering using the lever on the "steering column" that lets you move the steering wheel up and down for purely ergonomic reasons...
cya
R
Old 6th March 2006, 10:36   #6
BUSA's Avatar
Wink
Originally Posted by Rehaan
Hey Mpower,
cya
R
Yes thats what i meant. In that a lower position the steering just might touch me so why is it so. Also since Optras come without airbags the instruction is for all optras.
Old 6th March 2006, 12:18   #7
Rehaan's Avatar
So it doesnt "break your neck" when the airbag goes off (if the steering is at the upper most position) ?
cya
R
Old 6th March 2006, 12:31   #8
BUSA's Avatar
Question
cya
R
Can you elaborate a bit?
Old 6th March 2006, 12:36   #9
Rehaan's Avatar
If the steering is pointing towards your neck and face (upper position), and the airbag inflates (which is does at an incredibly fast rate (thanks to explosives that infate the bag)) the airbag which comes out from within the steering wheel has a higher chance of inflating and injuring your neck and face, even more so if you were not wearing a seatbelt.
I guess this risk is reduced by lowering the steering so the airbag inflates towards your chest.
cya
R
10-2 steering position? Nope, it's 9-3 for Airbag-equipped cars sumeethaldankar Street Experiences 96 4th December 2015 15:56
Driving Position / Where to hold the steering wheel! Torque-ative Technical Stuff 69 17th July 2012 19:23
Steering position ballkey Technical Stuff 67 30th November 2009 13:41
Steering wheel grip position chanapli Technical Stuff 1 23rd January 2007 09:51
