Old 25th October 2011, 19:50   #16
sagarpadaki's Avatar
Thanked: 1,337 Times
Default Re: Issues with my new possession-Sonata V6
Even a multiaxle volve gives 2.5 kmpl!!
Jokes apart, get the complete service history from the HASS .From that you will know if something is amiss(like frequent changes of the same part),what all have been changed and when.So before you go on a changing spree,just study the service history
Old 27th October 2011, 21:06   #17
Thanked: 126 Times
Originally Posted by piyush350 View Post
1.3-2 is way low man.
i currently have the 2.0 auto and it returns me 8 on the highway and 6 running around town.
A friend owns the 2.7 and he gets the same figures but he's a bit gentle on the gas pedal.
Update us after a full service.
Piyush
Thanks, Piyush. I am planning as to what to do with the car's upkeep.
I shall keep you updated.
Its very surprising though, that the HASS people didnot have the computer needed to diagnose the errors in these so called high end cars.
BTW, My fusion seems far more advanced wrt the features.
deepfusion is offline   Reply With Quote
Old 7th November 2011, 20:11   #18
Thanked: 7 Times
Hi Again
Normally I am not bothered about the fuel efficiency of my car hence I do not work out the mileage, just top up and go.
However last week as I was to do a long trip I thought to extract the best possible mileage on the highway. I was easy on the gas and did constant speeds between 120-140km. 65 litre tank of petrol got me back home which was 784 km/490miles.
Hence the figure of 12 km was achieved which I believe is very good.
There were only 2 passengers one way and the rest was solo driving.
The car is in ship shape and is regularly serviced.
piyush
piyush350 is offline   Reply With Quote
Old 8th November 2011, 09:48   #19
Thanked: 126 Times
I have not been able to get the car serviced, which I have an intention to get done, as soon as time permits.
During the service, I plan to:
1. shift to Synthetic oil,
2. change all the fluids of the car, and
3. get the car professionally cleaned, inside out.
Do I need to do anything else for the upkeep of the car?
Old 1st March 2012, 03:18   #20
Harish.Krovvidi's Avatar
Thanked: 75 Times
Hi, i own a 2005 2.7 v6. Issue is with the etacs system in the car, if the etacs locks you out the remote wont work and th imobiliser gets activate stopping the car from starting. So when this happened to me in bangalore i opend then fuse box orn the driver side, below the fuse you will find a black box, remove it carefully and gently, wait for 5 to 10 min then pulg it back and the wait for few more min and try the remote as well as the key it will work just fine. Remeber to unplug etacs box remove battery terminals and after putting back the etacs box plug them battery terminals back. Remove the positive and negtive. Call me if u need some phone help
Harish.Krovvidi is offline   (2) Thanks Reply With Quote
Old 1st March 2012, 21:21   #21
Thanked: 126 Times
Thanks very much for your valuable input. I shall surely give it a try ASAP.
I took it to two Hyundai authorised workshops near my workplace but even they could not detect the problem, even after the vag com they used to detect the error codes.
Hope this solves the problem.
Will update you of the results.
Old 3rd March 2012, 00:47   #22
Thanked: 75 Times
Unhappy Re: Issues with my new possession-Sonata V6
Originally Posted by deepfusion View Post
I admit I bought a car which is low on fuel efficiency. But a mileage of 1.5-2 kmpl is simply unacceptable.
try changing the tires.
my sonata is 73k as of today, the worst fuel effeciency is 4.8kmpl. Why it it low was my question, i changed to syntic oil, spark plug etc. But the best i got was about 5.4kmpl (City driving fast & stopping hard & frequent slow moving traffic. It takes 45min to go 12km a/c is always on @ 17 degrees). NOW the same car use to give me 7 kmpl in same conditions, without the oil ans sparkplug change. What changed so dramatically; the tires yes i couldnt belive it, so i did a test, took 205/60r16 from SX4 voila a, back at 6.8 kmpl. I was running 205/55 R16 .. At least that what i conculded was i need a chnge pf tyre size. Unfortunately i had replaced the tires at 67k hence no money to switch back to the correct size . if any of you feel that 60 to 55 profile should not impact so much pls let me know your thoughts, we can try it out if your in bangalore.
Harish.Krovvidi is offline   Reply With Quote
Old 3rd March 2012, 09:53   #23
Thanked: 126 Times
I haven't done much with the car still, as my daily drive is my beloved Fusion.
No service, no oil changes, nothing. I am planning to take leave from office around Holi to give time to the v6 to get it back into shape.
But still, to make a mention here, the car is giving around 6kmpl now.
Old 3rd March 2012, 20:36   #24
1self's Avatar
Thanked: 270 Times
Did you try a de-carb the engine. After 73K, your intake will be quite a mess with a LOT of carbon deposits. Do it at an authorised Hyundai workshop.
1self is offline   Reply With Quote
Old 3rd March 2012, 23:15   #25
Thanked: 75 Times
1self good idea, am waiting forthe oil preassure switch to arrive next week will ask them to de carb the eingine at the same time. BTW i went for a 1 dayer today 406 KM and the refill stopped at 55 liters. hence my computation was 404/55 i.e 7.34 KMPL. then its good news for me (Still using the SX4 tires BTW). my next step is to see if city driving also it gives same figures but it may take me about 3-4 weeks to cover same distance to home and back to office. then am definelt going to get tires upgraded will try for some used ones if i can or swap the existing ones.
Also am planning to go in for sequential ALPG kit! anythoughts 1self
deepfusion your getting there. but i feel anything more than 7 is a dream for a sonata, beased on my now exp till now
Old 4th March 2012, 04:44   #26
1self's Avatar
Thanked: 270 Times
They have a German machine with very high quality fluids for the de-carbonizing. Standard across all Hyundai workshops. Ask them to do a through job of it because I have seen those intake & specially exhaust valves having a THICK coating of carbon. If your engine does not breathe properly it will consume more fuel.
The LPG kit would be nice. But remember to switch back to petrol when doing uphill or high rpm runs, ie. when there is a lot of load on the engine. If you do this, your engine will last a long time.
1self is offline   (1) Thanks Reply With Quote
Old 27th April 2013, 19:24   #27
Thanked: 7 Times
My car is running on 205/65r15.
Restoration and The Untold story of Our Prized Possession "The 1974 Bajaj 150". sushil_n79 Post-War 301 16th April 2018 22:50
My Prized Possession - Ritz Vdi gaddiwale Test-Drives & Initial Ownership Reports 106 27th July 2012 01:26
My new possession - Mitsubishi Lancer VR-X mezereo Test-Drives & Initial Ownership Reports 12 11th August 2011 15:40
Sonata facelift w/ new interior: now called Sonata 'Transform' Ramon The Indian Car Scene 126 27th March 2009 10:21
Skeletor Chopper - Priced at 3 lakhs - new possession of Jackie Shroff emkay456 Motorbikes 19 2nd March 2009 22:05
