Old 1st November 2011, 19:03   #16
SushilBajpai's Avatar
Thanked: 116 Times
Default Re: The strange Santro issue - switches off after 2kms
Originally Posted by supremeBaleno View Post
Start the car in the morning, it starts at first crank, drive around and within 2kms, it will just switch off. Even if you stay stationary, it will switch off after a few minutes. Now try to start the car, it will take a few cranks before it starts. For the unsuccessful cranks, it looks like no current is getting through. After the car starts, it is now no longer predictable when it will shut off next. Maybe soon or might take some time. Scary because if you are in the middle of an overtaking manouvre and the engine dies.
Several years ago my Santro had also developed similar symptoms. In fact it used start without a fuss and then unpredictably die on me. After several frustrating days, for no reason, and upon a hunch, I added IFTEK to fuel and the problem sorted itself out after some time.
Since then Santro has remained on the diet of IFTEK (1ml per litre of fuel). The problem has not resurfaced.
I have no idea why the problems cropped up in the first place and why (and if) IFTEK resolved it. I mention it here because symptoms were similar and the issue was not getting resolved by normal visits to service centre.
SushilBajpai is offline   Reply With Quote
Old 2nd November 2011, 12:37   #17
amrisharm's Avatar
Thanked: 302 Times
Originally Posted by libranof1987 View Post
So, you mean something like an Immobilizer. But why let the car be driven for 2kms?
The Immobilizer that most cars have these days don't allow the fuel lines to open at all if the correct key is not inserted.
Yes, i am talking about a malfunctioning immobilizer. One that kicks in when it should not.
amrisharm is offline   Reply With Quote
Old 9th November 2011, 19:15   #18
supremeBaleno's Avatar
Thanked: 1,711 Times
Thanks for all the responses/suggestions, guys. I took a printout of the whole thread and gave it to my friend. When I told him that most responses point to fuel-deprivation as the cause, he said that he did suspect it initially, but ruled it out due to the underlined part below in my opening post.
So, he basically checked and found that when the car does not start, there is no current at the plugs. Ofcourse why it happens this way is not known.
The car has currently gone to the HASS where they are supposed to simulate the problem with the scan-gauge connected to identify the root-cause.
Old 9th November 2011, 19:26   #19
manjot1912's Avatar
Thanked: 26 Times
^^ I had earlier quoted that exact part which you have underlined and asked you to get the fuel pump relay checked. Was it done?
manjot1912 is offline   Reply With Quote
Old 9th November 2011, 19:41   #20
Since the car was taken to the HASS by the time I could get the responses to my friend, this was not done. Let's see what the HASS has to say after using scan-gauge.
Old 9th November 2011, 19:50   #21
I had similar issue to my Santro- 2000 Model, after few kilometers it suddenly stops. Even the Diagnostic Scanner hasn't reported any problem, it reported everything was fine.
After repeated checks the service engineer at Lakshmi Hyundai - Hyderabad diagnoised it as fuel pump problem, after replacing there had been no issues.
Chevy is offline   Reply With Quote
Old 26th March 2018, 23:26   #22
Thanked: 12 Times
Hi, I am asking response for almost 7 years old thread, I recently bought a Santro AT and I am facing similar issue, in case your friend still remembers can you help me to check with your friend what was the issue and what was fix suggested by HASS?
soarer is offline   Reply With Quote
Old 28th March 2018, 13:14   #23
Will surely check with him if he remembers this issue and how it was fixed.
Since this was 7years ago, not sure how much success we will have - I myself forgot all about this thread till your update popped it up on top of my subscription list.
Old 19th May 2018, 15:42   #24
Ok so this is happening in a Santro Xing that i am working on car starts runs for a bit and then shuts down then again runs for a bit and shuts down. In my case it is the fuel deprivation but a little tricky. When cold the car starts but after a bit the fuel pump relay heats up causing it to fail (temporarily) and in turn causing the fuel pump motor shut down thus stalling the car. Check the fuel pump relay if it is hot if not then open two 12no. nuts and take out the fuel pipe if no fuel comes out then it is fuel related. If no current in plugs then its your Crank Sensor.... (most probably). let me know what you find... CHEERS!!!
Shiva's Regal is offline   Reply With Quote
Air Recirculator intermittently switches off in Polo TDI layndrivr Technical Stuff 4 19th May 2011 18:53
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
Please help ---Esteem suddenly switches off kris Technical Stuff 9 17th July 2008 22:44
HU switches off during ignition zakaaaaasss In-Car Entertainment 38 10th July 2007 13:31
Fiat group switches into profit vivek_pinkoo The Indian Car Scene 6 28th July 2005 23:30
