Old 8th November 2011, 19:46   #1
libranof1987's Avatar
Thanked: 2,793 Times
Default Varying a/c blower throw in Honda City (current gen)
The a/c blower in my Honda City (current gen) throws up varying amounts of air occasionally. Earlier I thought it was a one-off thing but I have observed this rather regularly.
The car is just over a year old and is serviced regularly. The a/c is used almost 100% as are most vehicles in Gurgaon. During use, the a/c suddenly throws a lesser amount of air and then returns to normal after a while.
Please note :
- the a/c is used in internal circulation mode
- the variation is observed when the car is at the same speed/ gear/acceleration
- this is observed at blower speeds (1 and 2; 3 & 4 haven't been used as yet)
- the duration of the variation in throw is not constant
- the variation occurs randomly
I haven't observed this in my Zen or Corsa hence find it abnormal.
Is such behaviour routine or I need to get something checked?
MODS : please merge it in my ownership thread if necessary.
libranof1987 is offline   Reply With Quote
Old 8th November 2011, 23:41   #2
dhanushs's Avatar
Thanked: 4,054 Times
Default Re: Varying a/c blower throw in Honda City (current gen)
Does the amount of air thrown/fan speed proportional to the rpm?
EDIT: Also, does the lights, electricals, et al dim, when it happens? Just to make sure it isnt a supply issue.
Old 8th November 2011, 23:56   #3
Nope, forgot to mention that.
It is irrespective of the rpm.
Old 9th November 2011, 23:53   #4
dhanushs's Avatar
Nishad, try this:
1. Turn OFF the ignition switch.
2. Now, press and hold the recirculation button and rear window defogger button, and turn ON the ignition switch.
This is said to be a diagnostic test for Honda's Manual AC.
After the 1st two steps, the recirculation indicator will turn on for about 2 seconds, then self-diagnostic function begins.
If there is a problem, then then recirculation indicator will blink.
Let me know how many times it blinks.
Old 8th January 2012, 20:06   #5
The car had gone in for servicing today; I'd asked my father to report this.
As it turned out, there was *too* much dust all along the a/c unit; right now from the a/c filter to the air pipes.
The airways, vents and the a/c filter was cleaned thoroughly.
The problem has been resolved now.
libranof1987 is offline   (1) Thanks Reply With Quote
Old 8th January 2012, 22:10   #6
I used to face this problem untill third service in my year old ANHC. I tried to explain it to SA couple of times. Somehow I havent noticed this in recent months. Will obserivce and follow the seteps.
AKNAN is offline   Reply With Quote
Old 9th January 2012, 10:20   #7
vigsom's Avatar
Thanked: 581 Times
If the cabin air filter was indeed fine,so much muck should have escaped into the air ducts,unless of,course the dust went in from the vents.
I think the filter could have been clogged with some fibrous stuff which would have resulted in variations in speed whenever the stuff would block the pores,and the speed would normalise when the stuff shifted.
The curious case of highly varying FE during city & highway driving libranof1987 Technical Stuff 25 3rd October 2011 12:15
Throw out everything you thought you knew about tyres. Auto Bild India knows best Nikhilb2008 Tyre & Alloy wheel Section 28 19th June 2009 19:26
Short throw in low beam Samurai Technical Stuff 17 7th October 2008 01:39
Can someone throw light on this please!!!! srinath34 In-Car Entertainment 13 25th March 2008 05:58
