Old 3rd November 2016, 14:58   #4036
Thanked: 112 Times
Default re: Mahindra XUV500 niggles & solutions
I am not sure on the over tightening part as once you start lifting the tyre using the winch, it produces an audible sound after the specified height has been attained by the spare. Seems some extra metal is jutting in the enclosure causing the damage. I had two services done but the service guys never touched the spare.. The only times the spare touched the ground was when I winched down to check the air pressure that too only twice in last 1 year. A point to ponder is the damage can be seen on the alloy due to visible scoring but then what are the chances of the tyre itself also getting damaged or unnecessary pressure being put on the sidewall at certain points.
RajeVenu is offline   Reply With Quote
Old 3rd November 2016, 15:31   #4037
nitinralli's Avatar
Thanked: 645 Times
So its 5th Birthday of my Silverstreak. The reason i am posting it here is so that i can document all that things that went wrong and how they have been holding up since then.
I had a terrible experience while buying my W6 when it was launched in 2011 from the dealer (Koncept Mahindra Okhla). Since it (XUV) was a rage at that time hence i had to deal with them. But i took some steps which ultimately helped all XUV owners down the line. i.e Insurance: Dealer wanted to take insurance from them only and not from outside, hence they were charging way too much. Personally took this to Anand Mahindra on this and WON. Things changed after that for all.
Also went ahead with other members and got service interval changed from 6 months interval to one year.
So it was not a rosy picture in the beginning. But then i had no other choice rather than fight it.
Now came the ownership experience.
It was my first long trip with my Silverstreak. At night just before leaving for 600 km journey, i stopped at a pump early morning to have tank filled. To my shock, just when it was about to get to max level, fuel started to leak from under the body. It took half hour or so before it stopped so i guess there was a hole or something on the upper side of tank. Went ahead with the trip and made sure not to fill up to max. Once back had it replaced under warranty.
Later on Silver Box issue started popping up. Not just me, almost all started reporting here I too was not spared and it was replaced once in these five years (Touchwood), though it was reported that few had to replace them twice or thrice in there ownership.
I had a major trouble with headlights conking off now and then. There was a time when the entire right hand side lights were not working (Low/high/fog lights). For a month had to travel like a scooter at night ( you know what i mean) before getting it replaced. This issue went on for good year and a half till the time they replaced wiring of the entire lights (thats what i was told). Since then no issues at all (again touchwood).
Apart from these, i had and still have alignment issue that almost everyone faced or are facing. Done everything from alignment to balancing to air pressure etc. nothing works. So now i have better muscles in my right arm compared to left arm
One thing that i have to say. All this while, i never had any engine issues at all (again touchwood). Its like a ROCK. Will take you where ever you want to go without a fuss. Electronics can play a bit, for e.g. ABS light comes on on its own and then goes off but nothing with engine.
Things i like the most.
Cornering lights, its a boon in our country and it has one of the best throw compared to European version of using fog lights. I feel XUV have a much better throw and effect.
Engine pulling power. No words for it, especially 3rd and 4th gear.
Looks: I still like and love the older version looks. Current one looks more tamed and boring (sorry just my thought so no offence please).
Space: More than you want. Just one wish that never came through was adjustable middle row so that we can make more leg room for third row. (maybe we might get it in new version down the line).
All in all, Loved living with it all these 5 years. Will hope to see this through another 2 years at least (touchwood AGAIN). Currently running on new set of tyres from Maxxis. Got it serviced from outside at 70K interval for only 8K including all filters,oil changed and that too at HOME.(yes there is this service where they come to your place office or home and get your car serviced).
Here are the current pics of my beast after i did a delhi mumbai run.
@Mods: I am posting all this here as you can see its more of issues i faced all this while and how it went through. If you think it should be in other thread like Long term ownership, then please do so. Thanks.
Last edited by Zappo : 7th November 2016 at 15:59. Reason: Limit yourself to a maximum of 2 smilies per post please.
nitinralli is offline   (4) Thanks Reply With Quote
Old 3rd November 2016, 15:49   #4038
how does the avg mileage reading work ?
I have a 3 month old XUV AT and the reading is showing as 13kmpl. which means on a tankful (72L) one can get 900+.
however I am getting 750-775 kms which means 10-11 KMPL.
can anyone help clarify this puzzle
thx
ta1017 is offline   Reply With Quote
Old 3rd November 2016, 16:51   #4039
Tanveer_2558's Avatar
Thanked: 2,040 Times
Originally Posted by ta1017 View Post
thx
Reading on the infotainment system, Will not be accurate, It will only give an estimate, Best way to calculate is via tank full method, Also Since your car is just 3 months old, I assume you haven't done your first 5000 kms servicing done, I have noticed in both my XUV's the fuel efficiency had increased the most after the 10k servicing, Along with the engine getting smoother.
Tanveer_2558 is offline   (1) Thanks Reply With Quote
Old 3rd November 2016, 23:15   #4040
Thanked: 52 Times
thx
I have a XUV AT, which has done 7480 km in 4 months, the mileage I am getting is 13 in Highway and 7.5 in city. This is using tankful method. I say in Bangalore and my daily commute is 48km from home to office.
tirthankard77 is offline   Reply With Quote
Old 4th November 2016, 10:25   #4041
avimal's Avatar
Thanked: 45 Times
My ASC suggested to get cutout with 100/90 bulb to address weak low beam. Has anyone tried? Any feedback on improvement
avimal is offline   Reply With Quote
Old 4th November 2016, 10:50   #4042
nkrishnap's Avatar
Thanked: 4,163 Times
A cut out with 100/90 generally comes in the H4 specification. I wonder how the ASC suggested this when the bulb specification for XUV headlights are H7 for low beam and high beam.
Name:  XUV Bulbs.jpg
You do get H7 cut outs and bulbs with 80W (Philips) and 100W (Hella) that you can install. PM me if you need help to install it.
nkrishnap is offline   Reply With Quote
Old 7th November 2016, 15:24   #4043
PGA
Thanked: 138 Times
Thanks for consolidating all those nostalgic issues with XUV. Earlier pages of this thread captures most of the discussion we had on these issues.
I sorted left pulling by going for off A.S.S alignment. The car has done about 30000 kms since then including a drive to Sumdoh and back, no issues. I don't have alignment values as my son got it done and teenagers don't believe in carrying the baggage.
Only other issue I had was repeated conking off of silver box after car came out of warranty, which finally got sorted when I raised the matter to Mahindra Care, as local A.S.S for Nippon and Mahindra were trying to play ping pong with my case.
PGA is offline   Reply With Quote
Old 7th November 2016, 16:07   #4044
Zappo's Avatar
Thanked: 2,017 Times
Originally Posted by balpreetsingh View Post
Thanks Ajay.
Earlier it showed a Value ( 26/28 etc.) Now it shows OK like the info unit. So earlier I knew even in OK, if its around 26 or so, I have to get the air filled.
Originally Posted by ajayclicks View Post
I use an android phone, and when I checked yesterday, mine still shows the individual tire pressure. My app is for the refreshed XUV.
I think this is an issue that shows up with time. I think those crappy chinese tyretronics sensors stop reporting the pressure. I am seeing this since last 6 months on my front left tyre. Other 3 are doing fine. I still have some time left for my 5 years of total warranty to expire. Wondering whether to take the car one of these days to the A.S.S. and demand a replacement sensor under warranty. Problem is that the A.S.S. are so badly loaded that they just refuse to look into anything other than preappointed service requests. Also, with warranty at its fag end they just try their level best to shrug out of their warranty obligations. Nonetheless, those I can fight out. Its just that I am too lazy as also the fact that I know that eventually one by one the others will also start conking, most probably once the warranty runs out. I don't think I am going to chase them everytime one of these conks off in future.
Zappo is offline   Reply With Quote
Old 7th November 2016, 16:50   #4045
Thx.
My XUV is approaching its first service.
Can anyone advice me on which service is best in delhi NCR. I had purchased mine from koncept/synergy.
Old 9th November 2016, 15:25   #4046
Just completed my 40K Service and a month to go before my 3 year warranty gets over.
In the last 6 month I have got both the rear doors & Fuel lid replaced due to rusting. India Garage helped in getting this replaced. After end of 3 years warranty one cannot claim any rust related issues, does any one else have faced this in the past? Are there any other areas prone to rusting that I should be aware of.
I am going to buy extended warranty but it does not covers many things.
vijaymishra is offline   Reply With Quote
Old 18th November 2016, 16:06   #4047
iamnarayang's Avatar
Thanked: 22 Times
I need to change the front wiper blades for my 2012 XUV 500 W8. I want to buy Hella Curvo wiper blades. Is the wiper specification for the 2012 model same as the new age XUV 500, or I need to be specific about the model, while buying the wiper blades? I want to buy online. Please advice.
iamnarayang is online now   Reply With Quote
Old 22nd November 2016, 14:19   #4048
nitinralli's Avatar
Thanked: 645 Times
Its the same across all models and years.
nitinralli is offline   (1) Thanks Reply With Quote
Old 26th November 2016, 17:17   #4049
Thanked: 20 Times
Today I took my new Age W10 XUV for a drive to Thiruvannamalai from Bangalore, strangly i noticed this issue..
In one of the place with lot of potholes, I shifted to 2nd gear but suddenly i noticed the steering got tight and I immediately noticed engine off, I immediately switch on again and continued, it happened again while traveling back, both time the vehicle speed was about 25-30kmph,
Is there any reason about this behavior?
-AM
muke31 is offline   Reply With Quote
Old 28th November 2016, 10:14   #4050
Thanked: 2,073 Times
Originally Posted by muke31 View Post
In one of the place with lot of potholes, I shifted to 2nd gear but suddenly i noticed the steering got tight and I immediately noticed engine off, I immediately switch on again and continued, it happened again while traveling back, both time the vehicle speed was about 25-30 kmph,
Is there any reason about this behaviour?
It has never happened to me unless I was in very high gear. Its sometimes when you are not very attentive, you would be on 4th gear and believe being in 2nd. Thats when the engine stalls as we would be around 10 kmph or lower speed. I don't see any other possibilities unless you have discovered a new niggle.
abirnale is offline   Reply With Quote
My "not so great" experience with the Mahindra XUV5OO W8. Too many niggles!! hell yeah Technical Stuff 77 13th May 2015 16:01
Received a copy of the Coffee Table book on the Mahindra XUV500 from Mahindra Corp. shankar.balan Shifting gears 3 2nd April 2012 16:26
