Old 8th June 2017, 11:19   #4201
Indianstorms's Avatar
Default Re: Mahindra XUV500 niggles & solutions
Originally Posted by sbala View Post
Glad that you were not stuck in middle of highway with engine breakdown.
Looks like this is a known problem with XUV. With my vehicle, even after replacing Vacuum modulator, I still feel something wrong. Engine noise is really high at high speed. I have got a OBD II device to monitor for error codes, boost related metrics.
Hi sbala
Can you help me with which OBD II device you are using , i purchased a wifi ELM327 device from Amazon and tried with EBOD -Facile app on IOS. It worked on my Ford , but not on my Nano and XUV
Indianstorms is offline   Reply With Quote
Old 8th June 2017, 11:43   #4202
sbala's Avatar
Thanked: 158 Times
Originally Posted by Indianstorms View Post
Hi sbala
I got it from Amazon as well (Black Android Torque SuperMini ELM327 ECU Bluetooth OBDII CAR OBD2 Reader SCANNER v2.1) last week. I have an Android phone and got Torque Pro installed. For very first time, i had trouble connecting with the device. And the usual thing of restart , helped here. Had to switch car on/off, plug in/out multiple times to finally get it working.
I am yet to get the metrics logged. Will be doing this weekend. We have quite a few threads on OBD device here. Please scan through those as well. I am a newbie on this, but will be happy to help with whatever knowledge i learn
sbala is offline   (3) Thanks Reply With Quote
Old 23rd June 2017, 18:07   #4203
avimal's Avatar
Thanked: 47 Times
Anyone found solution to too much of brake dust? I am due for replacement of brake pads. Any aftermarket pads that can perform better?
avimal is offline   Reply With Quote
Old 23rd June 2017, 19:49   #4204
Travelator's Avatar
Thanked: 130 Times
Anyone here who modded the suspension with Tein or likes ? The contact from red rooster performance informed that it can substantially reduce roll (whatever of it is still there) and the bouncy feel over uneven road surface. The cost is 35k + installation. Not a petty amount there, so thought of putting this to the better informed for suggestion.
As for the machine, mine is a new gen W6.
Travelator is online now   Reply With Quote
Old 23rd June 2017, 20:57   #4205
rave20's Avatar
Originally Posted by Prash22 View Post
I own a 2015 new age XUV as well. Its run for 17,000 km. On a drive between Mysore to Bangalore mid-way the engine warning sign glowed and the engine became sluggish on 6th gear.
I was driving with my family(a one year old baby onboard) on a late evening.
I stop the car for about 15 minutes and check the coolant and the engine oil levels with a flashlight and they all looked good.
I stop and called the road side assistance, I immediately hear from the representative that I should stop driving and that they would send me a taxi from Mysore which will probably taken an hour and a half or more. I was told the car will be towed.
With the oil and coolant levels being good I start the car and drive for a distance and I don't find the sluggishness but the engine warning remained. I switched off the AC to reduce the load on the engine and continued driving slowly and made it to Bangalore.
Next day, I decide to take the car to Anant Cars, Bannerghatta Road but end up taking it to Chrome motors near BHEL which is very close to my place. Chrome motors have started servicing XUV's for about a year now.
I don't remember the error code but it pointed to a problem with the vacuum modulator which was replaced under warranty. I asked the SA the reason for the vacuum modulator problem but he did not have a convincing answer.
I had the exact same problem in my XUV during my highway drive to Hasan. In my case the Engine light went off after about 30min of driving. When i showed it to Bannerghatta Anant Motors they told me it was due to Air intake being blocked. No parts replaced since the light didnt come on after that but it was scary it happened on a highway.
rave20 is offline   Reply With Quote
Old 24th June 2017, 09:23   #4206
n.devdath's Avatar
Thanked: 2,072 Times
Brake pads from Brembo are known to have lesser brake dust with marginally better performance but tend to get squeaky. If I were you, I wouldn't bother too much about brake dust.
I've driven XUVs with TEIN and while there is a slight difference, to me it doesn't justify the price unless it is around 5k per corner. See if they have have you drive and experience it first, before you pay for it.
Old 3rd July 2017, 22:46   #4207
Would request eexpert feedback on the aircon. I recently got home a preowned W8 Oct'13 45K done well maintained, previously owned by my cousin who has immigrated to Canada. The AC didnt seem to cool well so got it serviced from my regular guy. Despite the servicing (filter & condenser cleaning, gas topup), the AC doesnt seem effective at all. It stands nowhere compared to my 8 year old Linea's aircon which is super chiller.
Today I measured the grill temperature and the lowest in XUV was 7C vis a vis 1.8C for Linea. Upon calling the service guy post this observation, he says the AC in XUV is a bummer and hardly effective. Expert views pls.
WanderNomad is offline   Reply With Quote
Old 3rd July 2017, 23:14   #4208
jacobvarughese's Avatar
Thanked: 217 Times
Incredulous to learn a Mahindra executive commenting on the inefficiency of the air-conditioner, particularly when its renowned to be called a 'bone chiller'- A tiny suggestion, did your service bloke check out the blower speed? Also, please see if you could try out other XUV's and gain a first-hand experience yourself. Do keep us posted on how it goes.
jacobvarughese is offline   Reply With Quote
Old 3rd July 2017, 23:29   #4209
Sorry for being not clear - I didnt get the AC serviced at A.S.S, it was my regular AC guy. I plan to take it to A.S.S now.
Old 3rd July 2017, 23:31   #4210
Thanked: 137 Times
Not true for me at least.
My three year old XUV can chill the hell out, even without setting it at lowest temperature.
carbookie is offline   Reply With Quote
Old 4th July 2017, 11:33   #4211
Guys figured out the cause - the ECON button was pressed. Sorry for the inconvenience. Figured out that ECON is similar to Low Cool on the Scorpio. Separately wondering what if this button makes any sense on a climate control model. Isnt the cooling propensity auto determined by the set cabin temperature.
WanderNomad is offline   (1) Thanks Reply With Quote
Old 4th July 2017, 11:38   #4212
Bit of background first:
I own a XUV 500 W10 AT AWD for past 15 months. Have driven it 30K through all terrains from Bangalore to Ladakh. Facing a weird issue for past 2-3 months and would like some expert opinion on it:
Every so often, randomly I might add, I get this warning "Front brake pads are worn out. Please drive at reduced speeds". I got my brake pads changed at 20K from my local mechanic. In past 2 months I have gotten it rechecked and cleaned twice, but the warning still keeps coming. I am satisfied with the braking performance of my XUV. No issues there. According to my mechanic the brake pads still have 80% of life left. I have driven it in rains and dry weather and I am getting the warning in both cases.
Any ideas?
pkjains is offline   Reply With Quote
Old 4th July 2017, 20:41   #4213
rahul_kej's Avatar
Thanked: 263 Times
Any ideas?
Its the brake pad sensor issue. Get it checked at the ASS and even there were cases of sensor wires breaking in starting batches of Xuv way back in 2011-12, didn't hear about that issue again.
rahul_kej is offline   (1) Thanks Reply With Quote
Old 5th July 2017, 11:22   #4214
Thanked: 19 Times
I have XUV 500 AT AWD W 10 bought on Sep '16. I used to feel brake noise and asked SA to get it looked. After Service now, the brakes give squeaking sound which is similar to BMTC buses. Post complaint they did check on brake pads and the discs. With measurements and run off tests, they changed brake pads but not disc rotors. Noise is still there but of low volume. Also it comes when car has run for some time, may be heating plays a role. Has anyone else faced similar issue and how was it resolved.
Does changing rotors / discs solves the problem.
SanjeevKalra is offline   Reply With Quote
Old 5th July 2017, 11:38   #4215
Thanked: 2,107 Times
I had similar issues cropped up towards end of prescribed life of the brake-pads. But since the life was not completely over, I had asked the SA to clean brakes and calipers and fit it back. That solved problem to greater extent. And of curse when the new brake pads came in, this noise wasn't there.
If the brake-pads have life left, just insist for the cleaning, bleeding and force them to fix it. if you still need to change rotors, ask for warranty claims only. They will deny as blaming you for wear and tear/ driving style blah blah, but persist.
abirnale is offline   (1) Thanks Reply With Quote
My "not so great" experience with the Mahindra XUV5OO W8. Too many niggles!! hell yeah Technical Stuff 77 13th May 2015 16:01
Received a copy of the Coffee Table book on the Mahindra XUV500 from Mahindra Corp. shankar.balan Shifting gears 3 2nd April 2012 16:26
