Old 22nd July 2012, 00:27   #646
anm
Default re: Mahindra XUV500 niggles & solutions
thanks guys.
The check list is toooooooooo long. I may not even understand all the items. I will first check against the niggles list, and then paint job, tyres and odometer.
Regarding W6 vs W8 - there is ready stock of W8 with one distributor. Sales guy is saying June manufacturing. For W6 I need to wait. If I have to go for waiting, then I will definitely go for W6.
anm is offline   Reply With Quote
Old 22nd July 2012, 12:28   #647
scopriobharath's Avatar
Thanked: 1,259 Times
Smile re: Mahindra XUV500 niggles & solutions
Originally Posted by anm View Post
thanks guys.
To keep things simple - try this
Check whether ODO is working or not. Ensure the kms keep increasing as you drive. this will ensure ODO is NOT disconnected. Secondly just observe the external body for signs of scratches / dents / repaints etc. Thirdly just ensure all electronics are working.
If you get a W8 readily available and you need a vehicle right way, go ahead and pick it up. I think if you book a W6 now, it should take you 16-20 weeks(4 Months).
scopriobharath is offline   (1) Thanks Reply With Quote
Old 22nd July 2012, 14:26   #648
Sathya_sc's Avatar
Thanked: 670 Times
Do any of you guys know how to adjust the low beam from the engine bay. I took the vehicle for a minor check up yesterday where I asked them to raise the Low beam a little bit. Looks like it has got raised a lot so that it puts a black patch at the start of the throw.. meaning the it lights a little far from the car and the area immediately in front of the car is marginally dark. However fog lights come for help there..
so just wanted to know how to do this in the DIY mode.. so that we can adjust it to our satisfaction..
Pls post a pic of the screw/or some mechanism to be fiddled with in the headlight cluster..
Sathya_sc is offline   (1) Thanks Reply With Quote
Old 23rd July 2012, 13:03   #649
mannubhai's Avatar
Thanked: 285 Times
My right indicator has conked off again. It works for a while and then gives up.
This was supposed to have been rectified last week. Now i have to take the pain of driving all the way to whitefield to get it done.
Some one is gonna have a bad day that day
mannubhai is offline   Reply With Quote
Old 24th July 2012, 08:18   #650
Wind's Avatar
Thanked: 74 Times
I too have observed this batch patch at the start of the throw in my XUV. I was under the impression that it was one among the myriad features of the Cheetah :-) . Thanks for bringing this up. I will ask the RM to look into it during the next visit to the service center.
-- Wind
Wind is offline   Reply With Quote
Old 24th July 2012, 11:52   #651
sheelapratosh's Avatar
Thanked: 66 Times
Originally Posted by SDP View Post
Saw 2 XUVs yesterday night (noticed the diff. number-plates) with LED lights on one side not working.
Anybody else seen this in their own vehicles?
I had this issue. M&M promptly replaced the entire headlight assembly.. It is a known issue to the service folks.. Insist on getting both side's headlight assembly replaced instead of one (There will be color difference if you dont do it..)
sheelapratosh is offline   Reply With Quote
Old 24th July 2012, 12:43   #652
mannubhai's Avatar
Thanked: 285 Times
Looks like it has got raised a lot so that it puts a black patch at the start of the throw.. meaning the it lights a little far from the car and the area immediately in front of the car is marginally dark. ..
Sathya, Are you talking about this dark spot ? Im having thisone from day one, and the RM and service team says, M&M hasnt been able to figure it out. I drive with the dark triangle on my RHS ever since .
SDP, my RHS led conked off ... Now i realise many things have conked off
mannubhai is offline   (1) Thanks Reply With Quote
Old 24th July 2012, 13:05   #653
naveenchhillar's Avatar
Thanked: 31 Times
Sathya,
Yea, I asked them to do the same in front of me & saw the position of the screw. Will try to take a picture of the same location & post it here.
Was fairly easy, must say.
Meanwhile, you can try to do a little bit from inside the cabin. The vertical rollbar on the right side (near to diesel tank open button). If you want to lower the beam - please try to go to position that's numbered 3 against it. 3 is the lowest beam possible that can be done from inside.
0 is the highest in terms of beam.
naveenchhillar is offline   Reply With Quote
Old 24th July 2012, 13:34   #654
SDP
SDP's Avatar
Thanked: 8,302 Times
Manoj, thanks for picture.
When you mention the dark-traingle, are you talking about the area circled in red?
On a seperate note, I have not understood why the light has that clipped part shown by blue line? I have observed the same characteristic in my XUV as well.
SDP is offline   Reply With Quote
Old 24th July 2012, 13:38   #655
mannubhai's Avatar
Thanked: 285 Times
Attachment 961203
SDP,
Im talking about the area beyond the blue line. Thats the dark triangle formed. It is not visible in high beam though.
To add, the photo was taken under diary circle, and the light was pointed towards slight elevation. On a normal even road, the dark portion is menacing. Especially when one is driving along side the divider, and when those stones are left over on the road, you tend to not see them due to the lack of light.
Old 24th July 2012, 13:39   #656
Isn't it surprising that a car with so many issues is still going great guns. In any other country a lot of them would have been recalled. The best that I have heard is XUV 500's brakes fail or do not work up to the expectation. One of my close relative had a near fatal experience thanks to it. I wish someone at Mahindra is doing something about it.
shonak159 is offline   (1) Thanks Reply With Quote
Old 24th July 2012, 13:42   #657
SDP
SDP's Avatar
SDP,
Hey, thanks for clarifying. I believe I have the same problem. Would take a pic for sharing and would also try to debug.
Old 24th July 2012, 16:33   #658
Thanked: 66 Times
Folks, I have this exact issue. I checked in atleast 10 other vehicles - all of them have the same issue. I dont know if its by design (or) yet another niggle.
Old 24th July 2012, 17:26   #659
mayankjha1806's Avatar
Thanked: 821 Times
I have herd of that too, in my own organization, someone bought an XUV and on highway the brakes almost failed on highway speeds. Havent yet spoken to the actual owner yet. Others close to him tell me that once that happened he limped back to Mysore and then had to spend the entire day in there to get it rectified.
mayankjha1806 is offline   Reply With Quote
Old 24th July 2012, 18:54   #660
shankar.balan's Avatar
Thanked: 5,349 Times
Won't it be fun if Richard Hammond, Jeremy Clarkson and James May popped over and did a test drive and review of the XUV?
Im sure it would be a hatchet job but perhaps thats what is needed to make our manufacturers do a better job of quality and diligence!
I mean, having the brakes fail on a 16 lac vehicle is criminal!
I have also heard that the Export Quality XUV uses far better steel and has greater double reinforcement especially around the columns and so on to actually be safer than the India spec one. This is probably why it scored 4 stars on the ANCAP though there were comments about structural rigidity anyway!
Why do they short change their own countrymen with sub standard rubbish while giving special treatment to Phoren markets?
Till the government steps in and makes safety mandatory, these manufacturers will always take short cuts for local sales.
shankar.balan is offline   (2) Thanks Reply With Quote
My "not so great" experience with the Mahindra XUV5OO W8. Too many niggles!! hell yeah Technical Stuff 77 13th May 2015 16:01
Received a copy of the Coffee Table book on the Mahindra XUV500 from Mahindra Corp. shankar.balan Shifting gears 3 2nd April 2012 16:26
