Old 13th July 2013, 20:14   #1966
yogibear007's Avatar
Thanked: 54 Times
Default Re: XUV 500 niggles and their solutions
Originally Posted by fundagenie View Post
Haven't checked out the flickering light issue in my Xuv. However I would not expect such light flickering or fuse blowing when operating more than 1 power window in a 15 lac vehicle. Never faced similar issue with my Honda city or accent. And I always used to raise more than 1 power window simultaneously in both this cars and the fuses never conked off till date. Also haven't noticed the issue of flickering lights when AC cuts on or off in these cars. I had seen this issues mainly in earlier maruti 800, zen, esteem models etc.
FundaG
The voltage fluctuation while operating power windows, sunroofs is a normal thing in all the vehicals. If you want to verify, have a close look at the Instrument Cluster light intesity while operating the windows. You will see fluctuation in the cluster intensity when you operate the windows. But Headlight fluctuation is something new. I also never experience it earlier. Will check with my XUV too. The flutuation due to window operation should be ironed out through the headlight assembly ensemble I believe.
yogibear007 is offline   Reply With Quote
Old 13th July 2013, 22:38   #1967
fundagenie's Avatar
Thanked: 387 Times
I checked it out. There was a very slight dimming of the headlights when operating the power windows. Nothing really noticeable. But something present if observed closely.
FundaG
fundagenie is online now   Reply With Quote
Old 13th July 2013, 23:49   #1968
nitinralli's Avatar
Thanked: 445 Times
FundaG
Exactly, it happens not just when you use both front windows but it also happens when using single window button. Never felt this ever in my other cars.
nitinralli is offline   Reply With Quote
Old 14th July 2013, 08:32   #1969
dhanushmenon's Avatar
Thanked: 1,654 Times
I dont think this is normal. Haven't experienced this anytime in any of my cars.
As per Ford, this is actually a cross check to assess whether all electricals are working fine.
"when operating any other equipment which draws load, there should not be any change in the characteristics of the other systems.
Eg: If you try to pull up the power windows normally or beyond completely pulled up state, there should not be any dimming of the instrument cluster lights or the headlight"
Source: the Service Engineer at Malayalam Ford, Kochi
dhanushmenon is offline   Reply With Quote
Old 14th July 2013, 08:35   #1970
SDP
SDP's Avatar
Thanked: 6,963 Times
While we are discussing the headlight dimming a bit when powerwindows are operated, I do believe that may be there is a capacity issue with the electricals. I have seen the infotainment screen also flicker n number of times.
SDP is offline   Reply With Quote
Old 14th July 2013, 11:55   #1971
Rossiter's Avatar
Thanked: 40 Times
The newer XUVs (reduced GC ones) are reported to have an improved/different electrical system, so maybe it doesn't happen on the newer iterations. For the record, this dimming never used to happen till a month or two back.
Rossiter is offline   Reply With Quote
Old 14th July 2013, 12:10   #1972
Tushargohil's Avatar
Thanked: 69 Times
Hello Guys, thought to share with you; yesterday during general check up SIREN ASSY got replace, though my complain was related to noise (seats/door/instrument cluster/suspension)
Tushargohil is offline   Reply With Quote
Old 14th July 2013, 18:16   #1973
Thanked: 54 Times
Hey guys,
Noticed something new in my XUV while a casual cleaning excercise.
The rear left side corner of the bumper seems to be a little out of line than the right side counterpart. This has resulted in a noticeable gap betbeen the bumper and the light assembly/body panel on the rear left corner. Never noticed this earlier. There is absolutely no incident which would pressure on the rear bumper till date. Seems to be a original misalignment issue. Don't know if this is a 'general assembly' problem or a 'piece' problem. Have to check a couple of XUV's rear corners now.
Here are the snaps. First, the rear right corner...
And the rear left corner...
Old 14th July 2013, 19:14   #1974
HotChillyPepper's Avatar
Thanked: 215 Times
Originally Posted by coolboy007 View Post
Thats complete normal Nitin, happens with all the cars i own/owned so far. The power window motors are a real battery sucker
I second that. All cars that I have driven having same behaviour. Winding up two window glasses at same time can create problem if the windows are very tight in the metal frame.
-HCP
HotChillyPepper is offline   Reply With Quote
Old 15th July 2013, 18:15   #1975
nitinralli's Avatar
Thanked: 445 Times
Hey guys,
Attachment 1110270
Attachment 1110271
This does look awkward. I dont think its there in my XUV, however will check once i leave from office today.
nitinralli is offline   (1) Thanks Reply With Quote
Old 15th July 2013, 20:11   #1976
ssadwelkar's Avatar
Thanked: 60 Times
In the XUV500_owners_manual there is a mention on page 8 in Smart power Window a function called Auto UP (for driver door only), The glass is supposed to move all the way up automatically without holding the switch.
This function does not work in my vehcile while the Auto DOWN works perfectly.
Has anyone tried this Auto UP function? Does it actually work?
ssadwelkar is offline   Reply With Quote
Old 15th July 2013, 20:15   #1977
SDP
SDP's Avatar
Its a mistake in the manual. There is no auto-UP in XUV. The manual also mentions that the windows are anti-pinch. That is not correct either. The windows in XUV5OO are NOT anti-pinch.
SDP is offline   (1) Thanks Reply With Quote
Old 15th July 2013, 20:24   #1978
ssadwelkar's Avatar
Thanked: 60 Times
Maybe its something that needs to be enabled? I am taking my vehicle for 1st service after a couple of days to NBS, I will also confirm with them, thanks for your reply.
ssadwelkar is offline   (1) Thanks Reply With Quote
Old 15th July 2013, 20:34   #1979
fundagenie's Avatar
Thanked: 387 Times
One other mistake in the manual is that all internal lights will turn off automatically 3mins after locking the car to save battery. Except the centre light in the second row, no other lights turns off automatically. Have to switch them off manually. Checked it with the RM during the last visit and we tried it out in different cars. Same situation across. So manual is not correct for this also.
Ssadwelkar, while you are there check out regarding this also. Is a useful feature considering the number of times I forgot to switch off some internal light and the security calls me back.
FundaG.
fundagenie is online now   (1) Thanks Reply With Quote
Old 15th July 2013, 20:39   #1980
ssadwelkar's Avatar
Thanked: 60 Times
[quote=Ssadwelkar, while you are there check out regarding this also. Is a useful feature considering the number of times I forgot to switch off some internal light and the security calls me back.
FundaG.[/QUOTE]
Hi FundaG, I had the same problem a few days, the lights remained ON from night till he morning until the security called me, I already have that on the list.
Metro and City Discrimination By Mahindra- XUV 500 Launch anjan_c2007 The Indian Car Scene 18 29th November 2011 15:10
Niggles, problems (Tyre and Stalling) in Palio 1.6 Sports 2007 anurag_p80 Technical Stuff 31 19th July 2010 17:31
