Old 9th November 2013, 16:03   #2341
Vasuki's Avatar
Thanked: 180 Times
Default Re: XUV 500 niggles and their solutions
Hi Nitin,
I am talking about a very harsh vibration and resonating sound, right from the dashboard to the boot. I think it should not be a normal behaviour.
Normally there is a resonating sound when you accelerate from low rpm say 1200 to 1400 in high gears, 5th or 6th. This was noticed in my earlier car, elantra crdi too. But this in no way very harsh, and not so intrusive, can you pls upload the sound?
BTW do check the cowl. You can take up this with the service centre as this is a known issue. In my case they were able to reduce the noise from cowl substantially.
If we change the driving style by changing gears only after say 1800 rpm this resonating sound can be avoided.
Vasuki is offline   Reply With Quote
Old 9th November 2013, 18:19   #2342
raj_5004's Avatar
Thanked: 1,942 Times
I will tell you a scenario -
Say you are driving at 50 kmph in 3rd gear. Now for some reason, you need to brake and the vehicle slows down to say 30 kmph. Now XUV's engine is very much capable for pulling cleanly from 30 kmph in 3rd gear. If you give a normal throttle input, the car pulls cleanly and normally, without any glitch. But if suppose the road ahead is empty and you want to floor the throttle, that is where the problem arises - the car vibrates like hell.
What I mean is - I am well aware of the knocking which happens in lower speeds and higher rpm. I dont lug the engine and I change the gears well within the reasonable rpm. But this vibration happens only when you floor the throttle, you can hear it louder when you are in lower speeds and higher gears.
Old 10th November 2013, 11:50   #2343
Heavy Horse's Avatar
Thanked: 273 Times
Originally Posted by SDP View Post
Diesel vehicles have a strong 'tug' that you feel due to the higher torque. Additionally, the XUV does have a dual-mass flywheel which tends to maintain the momentum even after you leave the accelerator.
So, no need to worry. This is perfectly normal and intended behaviour. Once you get used to it, you would start liking the torque.
You answered my unasked question
It remained unasked because I just could'nt word it properly
Heavy Horse is offline   Reply With Quote
Old 10th November 2013, 14:26   #2344
dean5545's Avatar
Thanked: 682 Times
XUV owners from Mumbai, any good M&M A.S.S. you can recommend?
Not only XUV but all Mahindra owners any good ASS recommendation ? My friend owns a Thar he too needs one as the last one botched up the job to such an extent that we had to later on replace the flywheel!I even posted on SDP's thread but no reply.
Please help
dean5545 is online now   Reply With Quote
Old 10th November 2013, 15:31   #2345
Thanked: 20 Times
The higher torque at low rpms is an inherent trait of diesel engines. The dual mass flywheel, although helps in maintaining engine momentum, more importantly helps reduce vibrations. Otherwise even a solid flywheel should do the job.
mdsaif92 is offline   (1) Thanks Reply With Quote
Old 10th November 2013, 22:15   #2346
SDP
SDP's Avatar
Thanked: 6,957 Times
Please help
Sorry, saw that post and forgot to respond.
Mahindra handles XUV and Rexton separately. So the service-centers I have seen have been dedicated-ones for these 2 models. So, no clue about THAR.
I would suggest you send a PM to speedy (Mumbai based THAR owner) and may be Tejasperiompl (Mumbai based offroad expert, owns a Mahindra offroad vehicle..not sure which one). Hope that helps.
SDP is offline   Reply With Quote
Old 10th November 2013, 23:56   #2347
nitinralli's Avatar
Thanked: 445 Times
In Delhi, XUV and Rexton are handled in one service station only and not separately. You guys are lucky if these are handled separately cause with W4 coming in the picture, things are gonna get worse for sure.
nitinralli is online now   Reply With Quote
Old 11th November 2013, 08:55   #2348
SDP
SDP's Avatar
That's what I meant.
XUV+Rexton handled in one service-center and the remaining handled in another.
Looking at the lackluster center-console of the W4, I doubt how many would actually opt for that variant.
Old 11th November 2013, 09:37   #2349
Thanked: 21 Times
Thanks for the reply SDP, Raj, Saif
Have you migrated to the XUV from a petrol engined car? Or a low powered diesel car?
The points you have mentioned are not isses IMHO. I guess the rpm increases automatically to avoid stalling the car. I have to try it in my car though.
No Sir. I've been a diesel junkie till now having owned Sierra (2000-03 - 55K Kms), Indica (2003 Oct - 2011 dec - 115K Kms), XUV 5oo( 2012 Jan - till date - 22K Kms)
Having had the Beast for the last 2 years this is the first time I'm noticing this behaviour for the first time.
If you mean, the car does not slow down at all, then are you by any chance accidentally activating the cruise control?
no Sir. this is not the case.
SDP, Raj can you please test this in your Beasts
1. Put your vehicle in first gear
2. dont use accelerator, but just use clutch to move the Beast up the ramp.
3. hold the break and now put the gear in neutral and see what will be the rpm in neutral
for me the engine will still be revving at around 1200rpm and does not come back to 800-900 mark without me depressing the accelerator once.
SAMUDRA is offline   (1) Thanks Reply With Quote
Old 11th November 2013, 12:08   #2350
humyum's Avatar
Thanked: 2,057 Times
The last time I posted this, I got no response. I am posting it again since I need to know if any members are in the same situation like me -
My XUV has 3 issues all are irritating ones-
1) As mentioned above, I cannot floor the throttle of my car. If I do so, it is accompanied by a harsh resonating sound and vibrations through the entire body, including the boot! The last time I mentioned this to the A.S.S. (Infinity Autolinks), they replaced the air filter (!!!) but as expected, it did not solve the problem.
2) When I rev the car in lower speeds and higher gear (say from 30-40 kmph in 5th gear), I can hear a strange knocking like sound (something like a bolt or chain is loose somewhere) from the bonnet. Again, this has been unsolved.
3) I can hear a noise while idling (something rubbing inside the bonnet). I asked my SA to check if its the siren, but he claims the siren is perfect.
The incompetent A.S.S. of Mahindra just wants to earn quick buck the easy way and are not really interested in solving the issues.
  • Has anyone in this forum faced a similar issue so that I can advise my A.S.S. on what should be done?
  • Can anyone guide to a good/competent A.S.S. in Mumbai? I have been to Global Gallarie (Thane) and Infinity Autolinks (Sakinaka) and both are useless.
When was water from the fuel filter last drained or lets say when was the fuel filter last changed ? This might be the source of your problem.
Old 11th November 2013, 12:44   #2351
raj_5004's Avatar
Water was never drained from the fuel filter. Even the fuel filter has not been changed as far as I know.
Old 11th November 2013, 12:46   #2352
humyum's Avatar
Well there you have your problem. Get the water drained or get the fuel filter changed. The vibrations will vanish.
humyum is offline   (1) Thanks Reply With Quote
Old 11th November 2013, 12:53   #2353
raj_5004's Avatar
For curiosity sake, why does a choked fuel filter cause such harsh vibrations on hard acceleration? And not in normal acceleration.
Old 11th November 2013, 13:36   #2354
humyum's Avatar
Restricts the supply to the fuel pump and when you suddenly gush the throttle, I would assume the fuel pump is not getting enough supply to up the pressure in the rail to your requirements and hence the vibrations.
I have faced this many times in the Swift D ( similar vibrations to what you are talking about, can feel it on the accelerator pedal, floor kinds) and a simple water removal from the fuel filter does the trick. I replace the fuel filter of course every 20 thousand km.
humyum is offline   (2) Thanks Reply With Quote
Old 11th November 2013, 14:34   #2355
J.Ravi's Avatar
Thanked: 3,880 Times
In Chennai also XUV500 and Rexton are serviced in one service centre. Other Mahindra vehicles are serviced in different locations. This was confirmed by the XUV500 Experience Executive of India Garage, Chennai.
J.Ravi is online now   Reply With Quote
Metro and City Discrimination By Mahindra- XUV 500 Launch anjan_c2007 The Indian Car Scene 18 29th November 2011 15:10
Niggles, problems (Tyre and Stalling) in Palio 1.6 Sports 2007 anurag_p80 Technical Stuff 31 19th July 2010 17:31
