Old 31st May 2014, 14:15   #2641
Tushargohil's Avatar
Thanked: 69 Times
Mod Note : There are several spelling & grammatical errors in your posts. This negatively affects the forum experience for other readers.
Kindly ensure that you proof-read your posts prior to submission. Also, it would be a good idea to use spell-checkers.
Tushargohil is offline   Reply With Quote Received Infraction
Old 31st May 2014, 17:02   #2642
undead's Avatar
Thanked: 164 Times
Oh dear. It is still under warranty right ?
How much kms have you clocked so far ?
Kindly keep us updated on this issue. I wonder what will be the owners satisfaction after the warranty period is over.
undead is offline   Reply With Quote
Old 31st May 2014, 20:26   #2643
Thanked: 69 Times
Default Re: XUV 500 niggles and their solutions
This is 2.5 years old (ODO 25K)
I yet to get final cost but this what i was told. (Estimate)
5k for brake assembly
2.5k for towing.
8k for 3rd service
Old 31st May 2014, 22:28   #2644
SDP
SDP's Avatar
Thanked: 6,957 Times
2.5k for towing.
8k for 3rd service
Don't you have 3 year warranty?
Why is brake-assembly being repaired? Shared hydrolics ...clutch and brakes?
SDP is offline   Reply With Quote
Old 31st May 2014, 23:27   #2645
nitinralli's Avatar
Thanked: 445 Times
2.5k for towing.
8k for 3rd service
First one should be covered under warranty. Second and third is your expense i guess.
One question though. You said your clutch went kaput so why this brake assembly?
nitinralli is offline   Reply With Quote
Old 2nd June 2014, 10:06   #2646
Thanked: 69 Times
Yes clutch replacement will cover under warranty.
Somehow i missed this news, http://www.cartoq.com/mahindra-recal...h-replacement/
Apologies its not break assembly but clutch which need to replace.
Old 2nd June 2014, 12:05   #2647
Ok, so the start/stop came back alive on its own. The RM wants me to bring the car if it stops working again. All I did was to increase AC temp from 24 to 26 in the evening when it was raining. So It has something to do with the AC/outside temp ?
sriram.raghavan is offline   Reply With Quote
Old 2nd June 2014, 12:11   #2648
peterjim13's Avatar
Thanked: 250 Times
Originally Posted by raj.barcode View Post
4. That is a Mahindra trademark ; even I had the same problem and it took a full day at service center to rectify it
Hi Raj,
How did they rectify it. What is the issue. I do have the same thing and always misses it out during service
peterjim13 is offline   Reply With Quote
Old 3rd June 2014, 23:02   #2649
nitinralli's Avatar
Thanked: 445 Times
Recently i am hearing a Krrr krrr noise the moment i start the engine first thing in the morning. It only last for few seconds during the initial start and goes off after 4-5 seconds. It sounds as if its the belts rubbing on to something. Anyone else heard or facing this thing? What could it be?
Old 4th June 2014, 00:09   #2650
abhinavinc's Avatar
Thanked: 38 Times
Same here.
Every time I start the car after a gap of say 3-5 hours, I hear the same harsh noise for 4-5 seconds and then the engine settles into its normal running tune. This wasn't happening earlier but has recently started occurring in the last 2k kms. My XUV has run 32k kms. Even I was wondering what the issue is and how to explain it to the A.S.S.
It would be great if someone would shed some light on the above happening.
abhinavinc is offline   Reply With Quote
Old 4th June 2014, 02:32   #2651
Thanked: 111 Times
How old is your XUV??
Have the battery checked. Start/Stop sometimes doesn't work if the system on board feels it will be a burden on the battery, because this function heavily relies on it.
falconion is offline   Reply With Quote
Old 4th June 2014, 09:52   #2652
Its a new car purchased in Dec2013 and has done 6000 Kms. The battery is all fine.
Old 5th June 2014, 16:46   #2653
Hi
I have done 23k on my one year old xuv w8 and so far (touch wood) it has been a relatively issue free experience except for a couple of things.
1. Braking was an issue earlier but subsequently got fixed with replacement
2. Creaking / rattling noise - continues till date and have again given it to ASS (3rd service got over a month back)
3. The low beam is absolutely of no use while driving in the night and all that i hear is either live with it or get additional lights. Please provide what would be the best option that doesn't void the warranty.
1. Replace existing H7 low beam with Osram NB / Philips XtremeVision - 55w
2. HiD conversion kit for low beam (what does it do actually ?)
3. Get a pair of Hella 3003 fog lamps and mount it with clamps sourcing power from battery directly with an independent on/off switch. This costs anywhere between 9000 - 15000 is what i have been told.
Thanks & Warm Regards
AJ
WheelWizard is offline   Reply With Quote
Old 5th June 2014, 18:53   #2654
SDP
SDP's Avatar
AJ
I would suggest please go for a HID conversion kit from a reputed brand. The kit consists of Xenon bulbs, relays and ballasts. Its powered from the battery directly and no existing wires need to be cut or spliced for HID conversion kit installation. Please opt for 4300K Xenons, although they are difficult to find in the market. We (a bunch of XUV owners) did a group-buy for Morimoto HID conversion Kits. Got them imported and installed locally. Costed us around 12000 Rs each all inclusive, kit-price, customs, installation. Individual import price would be higher. The quality is superb and quite a few of us would vouch for the better illumination. All the best.
Last edited by Vid6639 : 8th June 2014 at 12:11. Reason: Split up the post into 2 and copied. Thanks.
SDP is offline   (1) Thanks Reply With Quote
Old 6th June 2014, 13:34   #2655
Thanks SDP for pointing me in the right direction. If there are other XUV owners in Bangalore who have done the HID conversion, do share some details as to who/where it can be done.
AJ
Metro and City Discrimination By Mahindra- XUV 500 Launch anjan_c2007 The Indian Car Scene 18 29th November 2011 15:10
Niggles, problems (Tyre and Stalling) in Palio 1.6 Sports 2007 anurag_p80 Technical Stuff 31 19th July 2010 17:31
