Old 18th February 2015, 19:10   #3121
avimal's Avatar
Thanked: 36 Times
Default Re: XUV 500 niggles and their solutions
I have one day-1 issue in my 2 year old xuv so wanted to check if it is the case with all.
whenever I rotate steering on neutral and standing position, it makes some grrr sound/vibration. I think it is there when car is moving on gears but b/c of other vibrations/noise it is felt more on neutral/standing.
I checked with another xuv also and found the same. reported the same to SA and as per him it is in all xuvs.
This is something I have found only in xuv out of all other cars that I have driven in past.
avimal is offline   Reply With Quote
Old 18th February 2015, 20:40   #3122
username's Avatar
Yes. This is observed in all XUVs, and i have checked this in a few new XUVs when i went for a test drive. The vibration is due to the power steering.
username is offline   (1) Thanks Reply With Quote
Old 18th February 2015, 21:40   #3123
ISO
Thanked: 55 Times
Default Re: Brakes Stopped Working !
Originally Posted by rajatmakar View Post
I took my XUV W6 delivery around a week back. Today morning in slow moving traffic, I found the brakes were not working. There were no warning lights glowing.
I stopped the car using hand brakes and then slowly took it to a near by ground. Checked multiple times and brakes were not working.
I then switched off the engine for 5 mins and then restarted the car. The brakes worked fine and everything seemed normal. I tested the brakes 15-20 times in the ground before continuing to office.
Sireesh service personnel is coming to check the issue. Anyone else has faced similar problem?
Rajat
this is critical failure. Imagine what will happen on highway in emergency situation?
Are breaks controlled by ECU?
ISO is offline   Reply With Quote
Old 19th February 2015, 11:10   #3124
peterjim13's Avatar
Thanked: 250 Times
Did you try cleaning it with some acidic solution e.g. white vinegar? But I am not sure if it is safe to try on windshield but it works fine on general glass e.g. aquarium.
M&M has called me in for a test drive in the night on real traffic to understand the issue. I have it at 7 today. Will suggest this but I am not sure though.
peterjim13 is offline   Reply With Quote
Old 19th February 2015, 22:34   #3125
Thanked: 21 Times
This does technically does not classify as a niggle but got my windshield replaced for a crack that happened due to a stone hit in the parking area. Had to pay only 2K from my pocket due to insurance.
But due to this they also fixed a squeaking noise that used to happen between the dashboard and windscreen. So all good. Sireesh Auto at Marthahalli did this and did a good job at this.
But recently have noticed a squeaking noise when I apply brakes. Going on a long trip this weekend, so shall get it checked once I am back. Anyways have to take the vehicle to the ASS for a service action for which I got an SMS.
carChef is offline   Reply With Quote
Old 20th February 2015, 22:54   #3126
abhinavinc's Avatar
Thanked: 38 Times
Didn't the guys at Sireesh charge anything for the rain sensor and light sensor fitted on the windshield? Even I have a cracked windshield and I'm getting a Rs 4000/- quote over and above the Rs 2000/- charged for processing the case.
abhinavinc is offline   Reply With Quote
Old 22nd February 2015, 08:27   #3127
TaureanBull's Avatar
Thanked: 299 Times
Even my XUV W8 was hit by a stone and a crack appeared on the left side of windshield. I got the windshield replaced under warranty here in Pathankot. I was charged Rs 2000/- as per the policy norms. The total cost is approx 21k. But no one asked about that additional 4k. I suggest you check before paying that additional 4k.
TaureanBull is offline   (1) Thanks Reply With Quote
Old 22nd February 2015, 08:39   #3128
debuda's Avatar
Thanked: 1,295 Times
To the best of my knowledge, no car manufacturer provides 'warranty' for windshields. I would like to know how M&M replaced your windshield (which cracked not due to a manufacturing defect but due to an impact) under warranty.
debuda is offline   (1) Thanks Reply With Quote
Old 22nd February 2015, 08:43   #3129
Thanked: 299 Times
You are right the windshield was not replaced by M&M under its vehicle warranty policy. It was replaced under the vehicle insurance policy. The terms and conditions of the policy will definitely dictate how much one would need to pay.
Old 22nd February 2015, 13:33   #3130
abhinavinc's Avatar
Thanked: 38 Times
But I guess the XUV windshield is more prone to cracking and being damaged by a stone hit vis-a-vis other cars. I and my in laws both have 4 cars each in our respective families, and the 2 XUVs are the only cars which have/had a cracked windshield!
abhinavinc is offline   (1) Thanks Reply With Quote
Old 22nd February 2015, 14:32   #3131
This noise is from the power steering. I experienced the same in my old Santro but much subdued as compared to Xuv.
dubeneeraj is offline   Reply With Quote
Old 22nd February 2015, 14:56   #3132
Thanked: 83 Times
But I guess the XUV windshield is more prone to cracking...
Had parked my XUV in my covered parking slot on a Saturday afternoon. Was shocked to see the windshield cracked when I took out the car Monday morning! The windshield was absolutely fine when I had parked it - there is no sign of any impact as well. The car will complete 2 years in May this year!
Spoke with Anant cars in Bangalore about coverage under warranty , they said they would need to inspect the car. Will be taking it shortly. XUV 500 niggles and their solutions-imageuploadedbyteambhp1424596800.849229.jpg
aajohn is offline   (1) Thanks Reply With Quote
Old 22nd February 2015, 23:21   #3133
Thanked: 21 Times
Spoke with Anant cars in Bangalore about coverage under warranty , they said they would need to inspect the car. Will be taking it shortly. Attachment 1342360
I have heard from a cousin of mine who works in Mahindra service, that there were some XUVs for whom the glass cracked without a reason. You should probably check with the ASS as if there's no impact, then it has got to do with the windscreen quality.
Old 22nd February 2015, 23:25   #3134
Thanked: 21 Times
Nopes. They did not charge anything for the rain sensor or the light sensor. They didn't even mention anything on that. Mine was replaced under the insurance and I had full bumper to bumper coverage. They did say that had I bought another insurance I would have to pay 2K more. Guess that varies with the coverage that insurance gives.
carChef is offline   (1) Thanks Reply With Quote
Old 23rd February 2015, 12:42   #3135
peterjim13's Avatar
Thanked: 250 Times
I thought the entire windshield set came at 6.5k excluding labor
@Debuda : As you mentioned, I am not sure of the warranty under the case of a crack but, the windshields are covered under the warranty. On my case they are trying to evaluate whether mine is worth a warranty cover as its a one off case.
@CarChef ; Does that mean that they used your old sensors. I thought the whole windshield and the wiring came as a single pack.
And on my case :
I had mailed it to M&M and they are looking at this issue of hard water marks, what I learn from the Works Manager is that M&M might take 3M's advice on the same.
If that doesn't work out they might get this sorted under warranty.
And on the replacing windshield, I was informed that the Windshield set comes with the sensors and associated wiring, so the whole thing might get replaced. In that case, I am not sure of insurance cover, but they might get this under warranty.
peterjim13 is offline   (1) Thanks Reply With Quote
Metro and City Discrimination By Mahindra- XUV 500 Launch anjan_c2007 The Indian Car Scene 18 29th November 2011 15:10
Niggles, problems (Tyre and Stalling) in Palio 1.6 Sports 2007 anurag_p80 Technical Stuff 31 19th July 2010 17:31
