Old 14th June 2016, 20:12   #3901
mtnrajdeep's Avatar
Thanked: 74 Times
Default Re: XUV 500 niggles and their solutions
Faced my first niggles a couple of weeks back, just when I was starting on a long drive to Tirupati from Bangalore.
I had purchased an OBD II adapter on ebay earlier. This I connected to the car & synced to my Nexus 5 phone via bluetooth. Car started & drove normally for 10km till I reached a fuel station where I stopped for refuelling.
As it my habit, I switched off the engine, went to the fuel dispenser for the tank-up, completed the payment, came back into the driver seat & started the car. On engaging the gear to R, I felt a jerk. Moving the lever to D, there was another jerk. HDC & HHC failed error alerts popped up a second later.
I tried the normal troubleshooting procedure of switch-off, wait, switch-on for a couple of times but the errors kept coming back along with the jerks when trying to engage D or R modes.
As the only new component was the OBD II adapter, I immediately disconnected it & these errors never occurred again.
Did anyone try using OBD II adapter for their XUV AT? Do you get similar errors? Or is mine an isolated case where the problem is with the OBD adapter?
mtnrajdeep is online now   Reply With Quote
Old 14th June 2016, 23:26   #3902
rahul_kej's Avatar
Thanked: 229 Times
Seems you are using ELM 27 Bluetooth obd adaptor. These are Chinese make and I don't think its wise to keep it connected every time, it has interfered with the ECU i feel.
Use it once a while just to check and clear any error codes if it has appeared, and don't keep it connected while driving.
And I won't call it a niggle.
rahul_kej is offline   Reply With Quote
Old 15th June 2016, 06:37   #3903
Singh09's Avatar
Thanked: 70 Times
Hey guys I have a 2012 XUV 500 W8 and it has done almost 84K on the ODO and has never troubled me before or left me stranded in the middle of the road. But yesterday while I was coming to Delhi from Moradabad I started facing issues with my clutch. While I was changing gears the clutch became really light and the pedal won't Come back when I pressed it. So I had to pull it back with my foot and then it started working fine but the lightness in the clutch was still there.
Then again the same thing happened after a while and I did the same thing and that's how it's been acting ever since. I know I should have stopped and called the Mahindra guys but I couldn't as we were tranfering my dad to Asian hospital as he got a cardiac attack and I was following the ambulance.
Once we reached the hospital I called my RM and explained him the situation and he said that the master cylinder has leaked and gave me an estimated cost of 20-25k to fix it. So I just wanted to know what might be the reason for this issue? Is it really the master cylinder that might have leaked or is it something else.
Singh09 is offline   Reply With Quote
Old 15th June 2016, 12:42   #3904
inder's Avatar
Thanked: 30 Times
The engine oil, engine and battery warning lamps are glowing in my XUV. Any idea what might be the issue. I have asked the driver to tighten the battery terminals and the engine oil.
inder is online now   Reply With Quote
Old 15th June 2016, 12:45   #3905
nitinralli's Avatar
Thanked: 445 Times
Yes it looks like a master cylinder issue. Many members have reported same scenarios like yours when their master cylinder died.
Please do let us know here if anything else was detected also the final damage to your pocket too.
nitinralli is offline   Reply With Quote
Old 15th June 2016, 14:25   #3906
Thanked: 111 Times
Hey guys I have a 2012 XUV 500 W8 and it has done almost 84K on the ODO and has never troubled me before or left me stranded in the middle of the road. So I just wanted to know what might be the reason for this issue? Is it really the master cylinder that might have leaked or is it something else.
Master cylinder is no longer part of any warranty.
As told by my RM:
The problem it seems to be is that they have designed the master cylinder to be compact and this has led it to become overheated in situations where the driver uses half clutch quiet often. In addition to it being compact it also lacks sufficient ventilation. The overheating causes its seal to fail causing a leak. Leading to this situation.
In my opinion your vehicle lasted quiet longer than majority of other vehicles. Just last week I noticed a 20k km run vehicle having the same issue costing around 20k. Majority of the expenditure taken by the clutch system. Master cylinder I think was around 4k.
falconion is offline   Reply With Quote
Old 15th June 2016, 16:16   #3907
Sisu's Avatar
Thanked: 73 Times
Hi Falconian,
Do you have any official communication from Mahindra regarding this?
As far as I know, this was a known issue with the XUV and any premature failures in the master slave cylinders are to be covered in warranty.
Sisu is online now   Reply With Quote
Old 15th June 2016, 18:08   #3908
Thanked: 111 Times
Originally Posted by Sisu View Post
Hi Falconian,
Yes it was and is a known issue.
I had gone to the service center last week due to reverse cam not working as the fuse was blown. I was sitting on the desk and noticed an invoice with all the parts that are involved in the master cylinder failure in a 2 year old vehicle. I inquired about the invoice which was about 20k and did not show anything as warranty replacement. My RM confirmed the bill is for master cylinder failure and that Mahindra has stopped providing warranty for it for the past 3 months.
falconion is offline   (1) Thanks Reply With Quote
Old 15th June 2016, 18:57   #3909
Twiny's Avatar
Thanked: 46 Times
Please let me know if there is any workaround for Bluetooth calling issues with Android 6 (Marshmallow) phones; I am using Moto 3G
Twiny is offline   Reply With Quote
Old 15th June 2016, 19:02   #3910
Tanveer_2558's Avatar
Thanked: 1,315 Times
Do you mean the, "click click" sound that comes during the call?
Tanveer_2558 is offline   Reply With Quote
Old 15th June 2016, 19:13   #3911
Twiny's Avatar
Thanked: 46 Times
^^ No click sounds. After a call is answered, nothing will be heard thru speaker nor the other side caller gets any sound. I have to press Answer using Phone and speak thru phone
Old 15th June 2016, 19:15   #3912
Thanked: 47 Times
I just checked with my service manager and he confirmed that master cylinder is indeed covered under mahindra warranty and even covered in extended warranty as well
gpriyesh is offline   (1) Thanks Reply With Quote
Old 15th June 2016, 19:50   #3913
Have you tried pairing with other phones to check if everything works fine?
Tanveer_2558 is offline   (1) Thanks Reply With Quote
Old 16th June 2016, 10:42   #3914
Default XUV recall??
Today I received a call from Anant Cars Bangalore regarding my XUV w10. The conversation was as follows.
AC Lady = Lady calling from Anant Cars.
[AC Lady] - Good morning sir, I am calling from Anant cars. This is regarding your XUV W10 with license plate xxxx.
[Me] - Yes, this is me. Go on please
[AC Lady] - We are conducting a proactive maintenance schedule for XUV owners at Anant Cars. As part of this maintenance, we will open the radiator of your XUV and will observe the nuts and bolts.
[Me] - I do not understand, why would you want to do that? I have never heard of anyone do that as part of maintenance. Also, how long will this activity take?
[AC Lady] - Sir, we have been mandated by Mahindra to reach out to you and we have been told it is mandatory to carry out this task which is why we are reaching out to you. We will conduct this task for 1 & 1/2 days.
[Me] - What? You need 1 & 1/2 days to observe nuts and bolts and also you want to open up the radiator completely. I would like to understand this better as I am not convinced on what is going on. I have not heard of Mahindra requesting for this or any news of it anywhere. Can you please have your manager call me later? Thank you.
[AC Lady] - Sure sir. We will get back to you. Thank you.
The above conversation leads me to believe that Mahindra is quietly doing a recall of sorts to fix an issue probably with a certain batch of XUV's. I would like to hear from this esteemed group if anyone has received such a call if there are any further insights anyone can provide. Thank you.
shiva75 is offline   Reply With Quote
Old 16th June 2016, 12:40   #3915
Thanked: 47 Times
Heard that there is a transmission related major recall on one batch of new age xuvs.
gpriyesh is offline   Reply With Quote
Metro and City Discrimination By Mahindra- XUV 500 Launch anjan_c2007 The Indian Car Scene 18 29th November 2011 15:10
Niggles, problems (Tyre and Stalling) in Palio 1.6 Sports 2007 anurag_p80 Technical Stuff 31 19th July 2010 17:31
