Old 8th August 2016, 15:17   #3961
Thanked: 51 Times
Default Re: XUV 500 niggles and their solutions
Originally Posted by abhi182 View Post
I have misplaced one of the keys on my XUV500 W10
I am unsure if it is misplaced within the house or been flicked
I had a similar issue on my X1 and I was able to disable the missing key via the OBD port and the BMW dealer level software
Is there a way to do the same with the Mahindra?
Yes, please take it to the Dealer, they will do it.
tirthankard77 is offline   Reply With Quote
Old 9th August 2016, 00:40   #3962
kushgandhi's Avatar
Originally Posted by krishnaraja View Post
I suspect it is turbo problem. However, have never faced problems in accelerating beyond 90kmph, I am able to touch 100 with ease, as usual. The noise when I have the window down, is irritating. Even on long drive, in case I bring the window down, I do hear this extra noise in the engine bay. This noise of course, is only during the rpm in the 1100 to 1500. It is very pronounced in the 1000-1200.
You didn't describe the type of noise that is coming off the engine bay. Maybe its just a worn out or lose engine belt that is squeaking even a slight left right movement of the belt can cause a disturbing noise that may not be audible due to insulation when windows are closed.
A better way to inspect this would be open the hood and detect the noise, in the end MASS is the way to detect and rectify the problem.
kushgandhi is offline   Reply With Quote
Old 9th August 2016, 09:43   #3963
Thanked: 25 Times
Originally Posted by triedeverything View Post
Each tap of the + or - button increases or decreases speed by approx 2kmph. Are you keeping the button pressed? If yes, then it is designed to disengage. The system feels that the button might have jammed and disables cruise for that ignition cycle. But if you press and leave... it will work. So let's say you are at 60kmph... and want to go to 70. just press and release the + button 5 times. This behavior is described in the user manual.
The resume button working is a new one. Check with the authorized service center.
The fundamentals of cruise is very well known and the problem is not in the fundamentals of usage. Very simple, after engine start when you are at 80, you want to cruise at that speed, you press the + button for 3 seconds to start. That itself is not working. Also, what I have stated is, instead of the +, if I use cruise off, it works like using the + button!
To me it appears like the turbo noise. As if it is not working. May be my ears are not able to catch it properly or something wrong, but I hear it only when I am inside the vehicle with window down, not when the hood is opened and I stand in front of it
krishnaraja is offline   Reply With Quote
Old 9th August 2016, 09:49   #3964
a4anurag's Avatar
Thanked: 10,390 Times
Connections on the steering wheel buttons are reversed? May be!! Get it opened and checked by the technicians at ASC.
EDIT:
Get yourself an OBD 2 Reader. Hook it up and check the turbo boost readings. That should tell you if it is working or no.
Old 23rd August 2016, 12:35   #3965
Thanked: 7 Times
I own a W10 which is about 6 months old. Yesterday, it threw up an alert on tyre pressure saying that the pressure is low. Therefore, I went to a gas station and got all 4 wheels filled up as per the standard 32 psi. The warning did not go away. I opened up the screen and noticed that it is throwing this warning for the spare tyre which is at the back. You can also see the image of the alert here.
Either I do not understand the warning or the W10 is indeed somehow measuring the tyre pressure on the spare which I found surprising. Why would they want to measure the pressure of the spare (I have no complaints if it is actually doing so somehow)? Or has my sensor just gone bonkers? Would love to hear back from you.
shiva75 is offline   Reply With Quote
Old 23rd August 2016, 12:48   #3966
mpksuhas's Avatar
Thanked: 2,700 Times
Isnn't it good that tyre pressure of spare is also measured?
Anyways, TPMS works with help of sensors attached on inside wall of alloys. Hence, it is required to have it on all 5 tyres. Else after a tyre rotation or changing a punctured tyre, you may end up a tyre without sensor.
In your case, it could be both- A faulty sensor or actually low pressure. You will have to fill the air and check. The issue with spare tyre sensor display is that, pressure is not displayed even in Bluesense app.
OT: I guess this was the most this thread was silent. No activity for full 2 weeks.
mpksuhas is offline   (2) Thanks Reply With Quote
Old 23rd August 2016, 12:56   #3967
SDP
SDP's Avatar
Thanked: 6,981 Times
...noticed that it is throwing this warning for the spare tyre which is at the back. You can also see the image of the alert here.
Yes, the tyretronics system does track pressure in all 5 tyres. The spare tyre is same size with a proper alloy just like the remaining 4. So its can be used as a proper tyre in case of a puncture and not as a temporary tyre till you get the puncture fixed.
When you have a puncture and want to use the spare tyre, nobody likes a nasty surprise that even that spare tyre does not have enough air. One would get stranded in such a situation. So tracking the pressure on the spare is a good logical thing to do.
Just measure the pressure of the spare-tyre using a physical pressure gauge and you would know if the pressure is indeed low or the sensor has gone bad.
SDP is offline   (1) Thanks Reply With Quote
Old 23rd August 2016, 13:17   #3968
Thanked: 56 Times
My XUV W6 infotainment system started malfunctioning after 20K service in May.
I have been following up with Anant Cars and Mahindra customer care since then and it has not yet been resolved.
As a last resort i posted on Mahindra Xuv Facebook page on 4th August
https://www.facebook.com/MahindraXUV...82812258471004
Today I posted again as it is not yet resolved
https://www.facebook.com/MahindraXUV...12583852139135
One service centre having customer care issues is known and do happen with any company.
But state of Mahindra customer care is so pathetic I don't have words to explain.
kiranvakati is offline   Reply With Quote
Old 23rd August 2016, 13:58   #3969
Thanked: 1,438 Times
For new-gen, it is not an alloy like 4 other tyres. Its a simple steel rim. Thats what I have - bought in Jun 2015. The refresh editions comes with alloy for fifth tyre?
abirnale is offline   Reply With Quote
Old 23rd August 2016, 13:59   #3970
SDP
SDP's Avatar
Frankly, Facebook posts don't really help.
If not satisfied with response from customer-care, please escalate to Area-Customer-care-Manager (name, email, cell-no available with your service center) and if it is still not resolved write to VP-Customer-Care (email address available on XUV website).
SDP is offline   Reply With Quote
Old 23rd August 2016, 14:35   #3971
mpksuhas's Avatar
First gen like mine are with all 5 alloys. The new gen like yours are with 4 alloy + 1 steel rim.
I don't think there is change to the combination for new ones.
PIC
mpksuhas is offline   Reply With Quote
Old 23rd August 2016, 14:57   #3972
Thanked: 7 Times
Mine is a simple steel rim and not an alloy.
Old 4th September 2016, 05:15   #3973
Thanked: 144 Times
This 2013 XUV5oo W8 belongs to a friend of mine. The Odo reads just 11,500 kms.
Date and Time of Incident :01/09/2016, 11:45pm.
Problem : Engine refuses to start.
A little bit of background : Engine cranks normally, all tell-tale lights switch on/off as usual, no abnormal sound from the engine, half tank of fuel.
My friend called the Mahindra toll free helpline at around 11:45pm and they asked him to get the car towed to the nearest Mahindra workshop the next morning to diagnose the problem.
Later that night he calls me and we decide to check the car in daylight. We met early morning and upon quick inspection I find this fuel supply hose to be cracked and leaking.
Yes, the fuel line(low pressure side) which runs from the filter assembly to the high-pressure injection pump developed a crack. I was surprised to find a crack in this area since there is nothing in the proximity which could damage it either by heat or contact/friction.
As a temporary fix I disconnected the hose from the filter side and used an electrical tape to cover and seal the crack (after cleaning the hose with paper towel to get rid of the diesel so that the adhesive of the tape has nice clean surface to grip onto) . I then primed the manual pump and cranked the engine, it came to life within 5 seconds of cranking. Saved the hassle and expense of getting the car towed with this simple and effective fix.
The Hose was replaced later that day with a new one.
The manual Fuel Pump
interc00led is online now   (3) Thanks Reply With Quote
Old 4th September 2016, 08:09   #3974
PADAS's Avatar
Thanked: 50 Times
Angry Re: XUV 500 niggles and their solutions
Thats interesting. Mine is a first gen too (W8, Mar 2015) and it came with 4 alloys + 1 steel rim. I did notice this and asked the sales guy at the time of PDI and he confirmed thats how it was. Was I taken for a ride ?
PADAS is offline   Reply With Quote
Old 4th September 2016, 09:19   #3975
rahul_kej's Avatar
Thanked: 229 Times
I faced the similar incident. Even i was asked to get the car towed. I was not that keen on getting the car towed so got it checked by a known mechanic.
So it turned out to be like yours but it was a major cut and it was due to rats activity because the cut was at couple of places. The position of the cut on the pipe was the same as yours.
rahul_kej is offline   Reply With Quote
Metro and City Discrimination By Mahindra- XUV 500 Launch anjan_c2007 The Indian Car Scene 18 29th November 2011 15:10
Niggles, problems (Tyre and Stalling) in Palio 1.6 Sports 2007 anurag_p80 Technical Stuff 31 19th July 2010 17:31
