Old 3rd October 2016, 11:25   #4021
Thanked: 9 Times
Default Re: XUV 500 niggles and their solutions
Seeing few oil marks in the Brake mount (Actually have wiped off in the attached image). Saw few other XUV at the service center and they all had more oil than mine. Service adviser told that it could be issue with the brake booster. I wasnt convinced with his explanation as brake fluid wad not reduced and I have driven it more than 1500 kms after seeing the oil mark. Also no issue with the braking till date.
Its done around 17K kms now. Planning to give the vehicle to service after festival. Is this a common issue with XUV?
XUVwanderer is offline   (1) Thanks Reply With Quote
Old 6th October 2016, 06:01   #4022
Tanveer_2558's Avatar
Thanked: 1,297 Times
Originally Posted by kiranmohandas View Post
Agree. That was the second part of the OBD story. The second mechanic knew the OBD port but didnt know what the HUD was. Showed them a video of Navdy from Youtube to explain.
Had to go through the same drama again, My SA had no clue what was a HUD, Infact he could not even recollect what is a instrument cluster when i told him HUD is kept behind the instrument cluster, A moment later he says this dabba is fitted from outside hence we can't do anything, Gave him a piece of my mind, On the other note, Trouble with service center continues, A long posts in my thread would be coming up soon...
Tanveer_2558 is offline   (3) Thanks Reply With Quote
Old 6th October 2016, 12:12   #4023
SDP
SDP's Avatar
Thanked: 6,952 Times
Originally Posted by Ritesh_Dogar View Post
Hello BHP'ians!
The Tacho on my XUV where the gear position and the Kilometers done is displayed (the red area to the left of the Temperature Gauge in the old gen XUV) has a dark patch. It appears as a small patch on the red screen. The area is faded a little and has got dark. The color difference is not too prominent but on closer inspection its an eye sore.
I took the vehicle to the service center, the technician told its the first time he saw this issue and could not offer any explanation.
Has anyone experienced this in their XUV's, any possible explanation as to how it might have happened and the possible solution to it.
Thanks in Advance
Its very difficult to imagine what the problem is and how severe it is. Can you please post a pic?
SDP is offline   Reply With Quote
Old 15th October 2016, 14:30   #4024
Thanked: 17 Times
Guys, I have experienced blue sense app ( both iOS and android) doesn't show exact tyre pressure now. Earlier it used to show. Mine is oct 2014 XUV w8. Anyone else seeing same behaviour?
balpreetsingh is offline   Reply With Quote
Old 15th October 2016, 23:38   #4025
Thanked: 1,427 Times
With iOS10 upgrade for a moment while was on Beta program of iOS, device stopped connecting but with 10.1 beta 3, its all working fine. So I guess either it is something to do with you OS version upgrade.
What version of firmware you have and phone OS version? maybe someone who has exact combination can confirm.
abirnale is online now   (1) Thanks Reply With Quote
Old 15th October 2016, 23:42   #4026
Thanked: 17 Times
Smile Re: XUV 500 niggles and their solutions
Thanks.
However issue was there with iOS 9.1 onwards as well on Android 6.
Now I am on iOS 10, and its the same issue.
Old 15th October 2016, 23:48   #4027
Ensure that you have latest firmware on infotainment unit too.
Also, note that when you connect the phone via bluetooth for Phone and Music, the BlueSense App on iOS works without any issues. if the same phone is not connected over BT for Phone functions, BlueSense does not work. Hope you are using exact same phone connected via BT to car for phone and running latest BlueSense meant for your vehicle. There are two versions on the AppStore - one for old gen and one for new gen. Pick the appropriate version there.
abirnale is online now   Reply With Quote
Old 16th October 2016, 03:09   #4028
Thanked: 17 Times
Thanks again. Its only one Iphone that I use. Its the app for old XUV( as I have had this app for quite sometime)
It works for making call via bluetooth, play music over Bluetooth. Just that bluesense app ( specifically the tiretronic feature) that's not working.
So I am geting a sense, its something that no one else has experienced.
Old 17th October 2016, 09:14   #4029
Thanked: 164 Times
I have a 2016 XUV and the blue sense app does not show the correct tire pressure. The service center confirmed that it is the case for all vehicles, and that it is normal for the app to show lesser pressure by 2-3 psi. He said that as long as my infotainment screen flashed 'ok' for tire pressure, it was fine.
ajayclicks is online now   Reply With Quote
Old 17th October 2016, 10:20   #4030
Thanked: 17 Times
Thanks Ajay.
Earlier it showed a Value ( 26/28 etc.) Now it shows OK like the info unit. So earlier I knew even in OK, if its around 26 or so, I have to get the air filled.
Old 18th October 2016, 15:23   #4031
Thanked: 22 Times
Thank-you for the reply SDP Sir. I am attaching a pic I took of the peculiar issue I am facing. Its not severe, however its an eyesore every-time I look at the Instrument Cluster.
In the attached pic, the area below the number 4 is blackish and looks like it has faded, the surrounding area is a consistent red and looks as it should be.
Ritesh_Dogar is offline   (2) Thanks Reply With Quote
Old 19th October 2016, 10:11   #4032
Thanked: 164 Times
Thanks Ajay.
I use an android phone, and when I checked yesterday, mine still shows the individual tire pressure. My app is for the refreshed XUV.
Old 29th October 2016, 16:29   #4033
Hi all,
I saw strange issue in spare Tyre of Xuv 500. I have 2 months old Xuv and have changed 5 th steel Rim to alloy wheel. When I was checking the fifth tire I saw that alloy is chipped at three places. I suspected that when Tyre is tightened below the body of vehicle it must be definitely hitting something. My suspicion turned true when I saw that at the bottom of the body there are three points where Tyre touches and fits. Now seems in Xuv instead of these three points just touching Tyre, touches rim also. Now I saw this issue in many xuvs in service Centre. In this case if any of the 4 wheel which gets punctured and is moved to the bottom of the vehicle will get chipped at the rim. Has anyone faced similar issue and resolution from Mahindra?
Size:  432.0 KBName:  ImageUploadedByTeamBHP1477738746.812845.jpg
Size:  393.0 KBName:  ImageUploadedByTeamBHP1477738756.519036.jpg
Size:  449.9 KBName:  ImageUploadedByTeamBHP1477738768.340413.jpg
Size:  399.9 KBName:  ImageUploadedByTeamBHP1477738780.811299.jpg
SanjeevKalra is offline   (1) Thanks Reply With Quote
Old 2nd November 2016, 15:44   #4034
I did not see anything like this yet. But my car has steel rim as spare and not alloy. I have never used it as punctures were not frequent or nothing that needed the change of tyre. But I do check spare tyre almost every 1-2 months just like that. If the air is too low, I fill it. at least 4-5 times I have lowered the tyre all by myself and fitted never observed any such marks. Could it be the case that the spare wheels are tightened too much?
BTW, My car is June 2015 mfg'ed.
Old 2nd November 2016, 15:56   #4035
Hi Avinash,
You could be right in tightening it too much by Service center guys. But I saw this in few other cars also in my apartment and service center. Now how to solve this problem. Also, Mahindra should have deviced some better way like rubber padding to prevent this.
Thanks,
Sanjeev
Metro and City Discrimination By Mahindra- XUV 500 Launch anjan_c2007 The Indian Car Scene 18 29th November 2011 15:10
Niggles, problems (Tyre and Stalling) in Palio 1.6 Sports 2007 anurag_p80 Technical Stuff 31 19th July 2010 17:31
