Old 19th November 2011, 17:02   #1
vu2pmc's Avatar
Thanked: 32 Times
Default Gave my Honda City for an oil change. Now, the remote locking system won't work
I gave my honda city for an oil change at 25000km. The service centre is Peninsular Honda in Calicut. The service centre gave an exterior wash possibly to make me feel good. Thanks to them. However after the wash,
my remote locking system wouldnt work..
I suspect if water jets while washing the engine side would have gone into the conical alarm of the remote system and further damaged any electronics?
I hope things will be fine once the car dries up.
Any suggestions would be welcome.
vu2pmc is offline   Reply With Quote
Old 20th November 2011, 15:48   #2
Rehaan's Avatar
Thanked: 25,040 Times
Default re: gave my honda city for an oil change. And remote locking system wouldn't work
What part exactly "doesn't work"? Was the car there overnight? Is your remote battery low?
I once sent my car to the service station for some work. It came back and the autocop didn't work properly (can't remember exactly what the issue was).
Called the autocop guy, he reset the system (by turning the ignition and opening/closing the drivers side door in some pattern) - and it started to work fine again.
cya
R
Old 20th November 2011, 16:10   #3
rajeev k's Avatar
Thanked: 1,750 Times
This could be a minor hiccup. Which make is the remote locking system. Washing the car is a common gesture by almost all A.S.S.
The thread title lead to me to think of some major damage.
rajeev k is offline   Reply With Quote
Old 20th November 2011, 17:27   #4
Rudra Sen's Avatar
Thanked: 4,294 Times
Default Re: gave my honda city for an oil change. And remote locking system wouldn't work
Agree with you here. Thread name changed therefore.
vu2pmc, wait for the water to dry up completely and see if you need to probe further. Water can play temporary havoc for these kind of areas. After fitting front windshield film, wiper started working on its own. And this was without switching the wiper on.
Matter got sorted after the car was completely dry.
Old 21st November 2011, 15:20   #5
vu2pmc's Avatar
Thanked: 32 Times
Thanks guys. the problem seemed to be more with a fuse. replacing the fuse sorted out everything. However, now the range of the remote seems very low. Possibly take it to the autocop service centre for the lifetime warranty and try my luck there. Anyways, for the moment, all seems good.
vu2pmc is offline   (1) Thanks Reply With Quote
Old 21st November 2011, 20:15   #6
Default Re: Gave my Honda City for an oil change. Now, the remote locking system won't work
The service center people always pull out the fuse from the main switch... this is to prevent the auto cop from turning on when they just open the doors. All service center people keep the doors unlocked during the day.
More over some autocops just keep beeping when the ign is off and the doors are not locked. My car has this feature and is very irritating when u are loading some stuff in there.
This is an after market system right cause its autocop (I am assuming)... Check where IR sensor is (If the old system then it is the wire with the red blinking light - I think am not entirely sure)??? If that is covered by metal sheets all around (not kept in the open but concealed inside the metal framework) or too many wires surrounding it then the range will be very less.
adilj is offline   Reply With Quote
Old 22nd November 2011, 12:55   #7
revintup's Avatar
Thanked: 373 Times
OK so you got rain sensing wipers installed alongwith film.
On a more serious note i hope the wipers were away from the glass all the time it was working on its own.
I had some prob with horns too. Got ok soon after drying though
revintup is offline   Reply With Quote
Old 15th March 2015, 14:38   #8
virgopal's Avatar
Thanked: 80 Times
After some tinkering work and a body wash at the A.S.C, my remote has a minor malfunction. The door remains unlocked(with key removed),when I forget to remote lock.It was working fine before service. However,with the ignition ON, before starting, doors get automatically locked
Any suggestions.
virgopal is offline   Reply With Quote
Remote locking system - Key fobs not working ukamath Technical Stuff 15 21st August 2017 23:15
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 15:02
Programming a remote locking system? ph03n!x Modifications & Accessories 12 3rd October 2009 23:05
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 20:08
Hyundai owners help me choose a remote locking system... neverclever Modifications & Accessories 12 28th July 2008 20:51
