Old 15th June 2012, 19:03   #91
Neil.Bhujbal's Avatar
Thanked: 59 Times
Default Re: TSI, TSFI, FSI, CGI Engines -Will these work properly with Indian petrol?
Originally Posted by vinj14 View Post
Thanks. Just a question though. So the CGI technology makes the car more fuel efficient and possibly mildly more powerful right? But speed 97 costs 15rs more than normal unleaded petrol for litre. So even if the car gives you 1.5 or 2 kms more per litre you actually would not be saving much. Does this logic make sense?
Or are there other advantages in the CGI technology?
Also, do you have any idea about the FE i can expect on this car?
CGI doesn't just increase the mileage by 2kms/l .. its more than that.
You can expect a mileage of around 9-10 km/l in city traffic with AC. There are people who get more that that too.
Neil.Bhujbal is offline   (1) Thanks Reply With Quote
Old 15th June 2012, 19:25   #92
Thanked: 1,172 Times
Originally Posted by Neil.Bhujbal View Post
Yesterday in workshop I had a chance to service a C-200 CGI. When I took it up on ramp I was surprised to find a normal exhaust rather than a complicated one with 2 catalytic converters, 4 sensors, bypass pipe etc which we had studied about.
So to cut it all in short these are just normal direct injection petrol engines running normal AF ratios.
They don't run on stratified mode (crazy lean mode) for which they are actually designed.
Reason : low octane fuel , they need atleast 95 Ron fuel.
Countries which have high octane fuel available have these engines running what they are designed for.
Great info.
So the only visual ID of stratified mode is this dual, complex exhaust pipe? If my Laura TSI has a simple, single exhaust pipe, then will it confirm that it's a turbo chanrged, direct injection petrol engine, but running on regular air-fuel ratio (14.x)?
Or can there be a stratified mode car with simple exhaust (stratification achieved with the aid of something else)?
Thanks again for this wonderful topic.
anandpadhye is offline   Reply With Quote
Old 15th June 2012, 19:51   #93
Thanked: 59 Times
Originally Posted by anandpadhye View Post
Great info.
I think its a turbocharged ,direct injection petrol engine running normal AFR's.
You can confirm it from the "fault diagnosis guy" in the workshop next time you leave your vehicle for service. Fault Diagnosis guy because these are the people who are trained by skoda when new engines are launched & they know every technical thing about it.
Neil.Bhujbal is offline   Reply With Quote
Old 27th June 2012, 13:35   #94
vinj14's Avatar
Thanked: 259 Times
Ok. To my amateur eyes this doesn't look like a simple exhaust pipe. With these avg. pics could you tell if the CGI technology exists in my car?
vinj14 is offline   Reply With Quote
Old 27th June 2012, 22:17   #95
Thanked: 59 Times
Ok. To my amateur eyes this doesn't look like a simple exhaust pipe. With these avg. pics could you tell if the CGI technology exists in my car?]
No CGI tech is not present. Not even a single Mercedes sold in India has it.
By simple exhaust pipe i meant (manifold > upstream o2 sensor > catcon > downstream o2 sensor > some sort of cooler > muffler > muffler tip)
This all is present on your C - 200 but
A Mercedes engine with working CGI tech needs ( nox catcon,main pipe,bypass pipe,bypass valve,nox sensor,temp sensor) in addition to already existing components of your exhaust.
By the way Congrats on your C - 200
Old 10th September 2012, 19:29   #96
Thanked: 99 Times
Came to this thread while searching for some else matter on the forum.
This type of threads tells that Automobile Engineering has become far head from just “suction, compression, power & exhaust stroke”.
How you came to know that car is Mercedes (& model if C 200) by only seeing pics?
Please mark cooler part in picture.
(Alok) is offline   Reply With Quote
Problem with Skoda Superb 3.6 V6 FSI Petrol Turbo Head Technical Stuff 70 1st June 2016 05:01
Do Diesel engines generate more Torque than Petrol engines? ex670c Technical Stuff 224 25th November 2013 12:20
Mercedes E200 CGI (Petrol) versus E220 (Diesel) mudittandon Luxury, Imports & Niche 27 29th March 2013 03:28
Difference between old engines and new engines (petrol and diesel) srijit Technical Stuff 32 26th January 2011 10:20
Spied – 2010 Mercedes Benz C250 CGI on Indian soil. EDIT : Maybe not after all Sudan_NFS The Indian Car Scene 10 14th May 2010 20:47
