Old 22nd September 2014, 21:59   #16
Default Re: Heavy steering vibration on idle
For Steering heaviness.. check out the front tire threading wear out and the wheel balancing.. this should clear the problem.
sweet_poison is offline   Reply With Quote
Old 5th August 2015, 12:37   #17
blackstallion76's Avatar
Thanked: 12 Times
Friends,
I have medium/mild vibrations on steering wheel at idle rpm (800rpm).
Mine if Fiat MJD 75 BHP. Normally, it feels just engine running.
But the vibrations are little more and visually I see horn pad/steering wheel border trembles lightly. Is this normal?
OR Am I over-sensitive. Not sure
blackstallion76 is offline   Reply With Quote
Old 5th August 2015, 17:51   #18
Thanked: 1,077 Times
Originally Posted by blackstallion76 View Post
Friends,
Check engine and gear box mountings - with engine off, try to shake the engine by hand. If it shakes a lot, mountings have gone soft.
Old 6th August 2015, 14:15   #19
kapilsharma80's Avatar
Thanked: 28 Times
Friends,
Mild steering vibration is an 'inherent feature' in punto. It has been there in my Punto since day one.
In case you are feeling irregular vibrations then get the engine mounts check.
Also get the condenser cleaned by pressure wash as the radiator fan movement also causes the steering to vibrate.
kapilsharma80 is offline   (1) Thanks Reply With Quote
Steering wheel vibration lohithrao Technical Stuff 44 17th August 2012 22:59
Baleno - Power Steering heavy when AC is on. Subbu Technical Stuff 18 24th March 2011 17:59
Vibration of Accelerator and Steering PatienceWins Technical Stuff 6 15th April 2008 10:19
Swift Diesel - excessive engine vibration when Idle. EDIT : Solved by MUL DieselFan Technical Stuff 36 2nd May 2007 11:37
