| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) |
| Distinguished - BHPian ![]() Join Date: Apr 2005 Location: Pune
| Topic is already discussed http://www.team-bhp.com/forum/techni...ht=Idling+MPFI (Idling Time during Morning Start for MPFI Vehicles) |
| | #32 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
| | #33 (permalink) |
| Newbie Join Date: Aug 2005 Location: vasco, goa
| thanks guys.. that did help a bit.. but still not satisfied with the answer.. mostly the idling problems happen in cold weather. The place where I stay is much hotter now a days than it used to be ( approx 30 degC compared to the usual 25 degC). But this reving problem started just a few weeks ago and never before that. why now all of a sudden? Also, the increase in revs comes in sudden bursts ( which add ~+500 revs) is that normal? PS- I searched some threads as adviced.. but most of them describe a gradual increase in the revs on startup which deaceases gradually over minutes.. my car's revs shoot up and down suddenly in episodes lasting 1-2 secs. |
| | #34 (permalink) |
| BHPian | you mentioned it.. revvs.. as soon as you press the clutch.... if thats what you are refering to as episodes lasting 1-2 secs.... then again its normal (you disengage the gear and it revvs.... no issue) My WagonR does not revv down untill I stop (PARK) the car... and let the engine idle for 30 secs... after its crossed the operating temperature. Same happens with the Alto... So its not revving down gradually... in my case too. Also say... I do not park the car to revv down the engine... I switch on the A/c and then park the car..... it idles at about 1000rpm. now while remaining parked... I switch off the a/c..... the revvs SHOOT up to 1500rpm... and remain so for FULL 15-20secs.... then its comes down to 800rpm. (and this is normal)
__________________ Č╠╣€€Я$ $£Қ |
| | #35 (permalink) |
| Newbie Join Date: Oct 2005 Location: Delhi
| The revving engine during cold starts is a normal phenomenon. Happens with my WagonR as well. I usually start it, wait for about 1 min, while I adjust the mirrors, seat, put on glasses etc... and then gently drive off. It usually warms up by the time I reach the first traffic light. When I stop for the light it still revs for about 20 secs, before gradually settling to a whispering 800 rpm. The reason this happens with most MPFI cars is this... since they have no choke (carburetted cars rev when the choke is pulled), the ECU senses a cold engine - and makes the fuel slightly richer - while opening the throttle flap marginally. Once the engine is warm it settles down. The only thing I find odd about the ECU's logic is that if the car is moving, it does not reduce RPM (even if you let the engine idle and let the car roll in neutral, while slowing down). Cheers, Roshun |
| | #36 (permalink) | |
| BHPian | Quote:
You are lucky to have a first traffic light close to you!.... BUT for me sometimes I end up driving 20kms.. non-stop!... and still find the engine revving hard. (and all those 20kms without engine braking is no fun) happens on both my WagonR and Alto Vxi.... now i make it a point to stop by the side of the road to... let it idle! Maruti Service centre guys did not have enough IQ/EQ/Common Sense to understand. But does not happen on my MPFI 800DX.....
__________________ Č╠╣€€Я$ $£Қ Last edited by SLK : 7th April 2006 at 17:26. | |
| | #37 (permalink) | |
| BHPian Join Date: Mar 2005 Location: Minneapolis
| Quote:
(Make sure u stop the car and dont put the car in neutral and turn off the ignition - the power steering and brakes become tough to operate or totally inoperable when ignition is off, u may not be able to steer the car in traffic, so its better to stop on the side for a few seconds) Dont know why the car used to behave this way. | |
| | #38 (permalink) | |
| BHPian | Quote:
the car when started stays at 1500 rpm and takes about a min to get to 800-900 rpm.....thats when i start driving off... if i dont wait(sometimes wen im in a hurry) the car stays slotted at 1700 rom even after driving it for a hour.....not exaggerating.....this has got to do something with a hitch in the ecu software that gets confused if we drive off without running in the engine in the morning one of the ppl has made a very valuable point by talking about the gear change......one minute MAKES A HELL OF A DIFFERENCE in the smoothness and ease of gear shift(esp in slotting it into reverse) Last edited by frankmehta : 12th April 2006 at 18:39. | |
| | #39 (permalink) | |
| BHPian | Quote:
... I think we can safely put this down as another "Maruti Phenomenon". My MPFI Esteem does exactly what you have described!I read somewhere that Maruti has cut some corners with the engine management sensors / ECU and that's why we see this issue. Here's a tip to all Maruti MPFI owners: In case you need to drive off immediately (before the engine has reached operating temp), you can avoid the "over-rev" problem by not using the accelerator. It's ok to let the engine get loaded (release the clutch slowly and drive in 1st / 2nd) but DONT even tip the accelerator... somehow, when the ECU is in "warmup mode" using the accelerator confuses it. This works for my Esteem and a couple of Wagon R & Alto owners I know. Interestingly, the Swift has not inherited this problem... - T u r b o C - | |
| | #40 (permalink) | |
| BHPian | Quote:
I have driven continously for 20kms after cold start just to test the thing and not unknowingly. The solutions I have found till now:- 1) PARK it and let it idle after its warm 2) while its rolling on a straight road put in neutral..... and restart the engine (might remind some of Microsoft Windows).
__________________ Č╠╣€€Я$ $£Қ Last edited by SLK : 15th April 2006 at 23:32. | |
| | #41 (permalink) |
| Team-BHP Moderator ![]() | I just shot a small video of my vRS on cold start. the display is showing ltrs/hour . I press the clutch and give it the crank. Watch how the figure jumps up and then settles down. ps - I could not finish the video but it settles down around1.0 ltrs/hour which takes about a minute and only after that I start rolling. Cold start on the vRS |
| | #42 (permalink) | |
| Senior - BHPian Join Date: May 2006 Location: Chennai..the city of cars..
| Quote:
Nitrous..its like you gettin up in the mornin and runnning @ full speed to the bathroom.. or do you do a slow dance to whatever.. cars are like humans too..remember ![]()
__________________ RWD Rocks! | |
| | #43 (permalink) |
| Senior - BHPian | OH GOD! I warm up my engine more religiously than my prayers,Vikram. I give all my cars exactly 60 seconds idling time (not 10) before I gently warm her and cross 2000 rpm only after the temp guage shows operating temperature.
__________________ hindu.com/mp/2008/08/25/stories/2008082522220200.htm |
| | #45 (permalink) | |
| Quote:
| Thread Tools | |
Similar Threads | ||||
| Good morning | sreenidhibr | Introduce yourself | 2 | 12th October 2007 10:58 |
| Is Star Gas LPG kit good for Maruti MPFI-ed vehicles ? | nicejits | Technical Stuff | 8 | 28th September 2007 23:08 |
| Scorpio morning-start problem at high altitudes | anupmathur | Technical Stuff | 2 | 7th September 2007 07:26 |
| Would'nt you love this first thing in the morning? | GTO | Shifting gears | 1 | 28th March 2004 01:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
