Thread Tools
Old 20th February 2008, 14:39   #46 (permalink)
nitrous's Avatar
First 60 seconds is crucial,Jaibir.
I've noticed that diesels warm up pretty quick and its quicker in the summer.
__________________
The Road less travelled, is less travelled for a reason
Old 20th February 2008, 15:52   #47 (permalink)
amitpunjani's Avatar
YES, true diesels engines get warmer, quickly due to the high temperatures inside the cylinders when compared to petrol engines.
amitpunjani is online now   Reply With Quote
Old 20th February 2008, 19:25   #48 (permalink)
headers's Avatar
it does matter summer or winter..unless one is talking sub 10 deg C.. also all modern cars warm up within the first minute..as the thermostat does not work then aiding in quick warm up.
Some manuals state that the engine is ready to rev once the temp gauge touches C [it is usually below C for the first 45 seconds or so to aid in lubrication]
A good practise is to NOT be a rev happy guy for the first couple of kms or so. Also check your brakes before opening up as the brake cylinders also need lubrication.
__________________
RWD Rocks!
Old 20th February 2008, 19:25   #49 (permalink)
arpandiv's Avatar
My alto 1.1 on a early morning cold start(car parked in open) starts and idles at 2Krpm. then after ~40 seconds it falls to around 900rpm. i guess this is normal?
I assume that it is harmfull to switch on the AC while the car is at the higher idling rpm level?
arpandiv is online now   Reply With Quote
Old 20th February 2008, 19:30   #50 (permalink)
gods-envy's Avatar
Infractions: 0/1 (4)
if i am not wrong, as soon as I start my car, the RPM meter usually moves almost immediately to the 1000+ mark and slowly comes down and settles down to the 800RPM mark in a few seconds or so(maybe 20 seconds).
and i think that solves the problem.
I mean that's what I felt so.
__________________
Palio 1.2 -140kmph
Swift 1.3 -165kmph
Palio 1.6 -165kmph
Corolla 1.8 -175kmph
Ford Mondeo 2.0 - 192kmph
gods-envy is offline   Reply With Quote
Old 21st February 2008, 00:09   #51 (permalink)
i like to give my swift 3 mins at least especially around this time of the year. The swift appreciates that and yes i actually always pump my brakes gently at first to get some heat in them.
Ran into my girlfriends honda city rear end once due to a dog , her inexperience and my cold brakes. Minor hood dent er .
cyneverdie is offline   Reply With Quote
Old 21st February 2008, 07:08   #52 (permalink)
headers's Avatar
Its not harmful..but just being a little harsh / rough on the car..imagine cars are like humans too..
The automotive systems are designed to withstand much abuse, the more gentle we are with it, the better and longer they serve us [read as trouble free]
__________________
RWD Rocks!
Old 21st February 2008, 07:21   #53 (permalink)
esteem_lover's Avatar
On the contrary, my carb esteem revvs at 600rpm in cold start & as it warms up touches 900 rpm. Guess the driver would have to be the brain behind the carb engines.
esteem_lover is online now   Reply With Quote
Old 21st February 2008, 07:28   #54 (permalink)
headers's Avatar
you are being unfair to the car..it needs signature too to keep you from working your brains
__________________
RWD Rocks!
Old 21st February 2008, 07:33   #55 (permalink)
he he he, unlike you, my car is a human being & gets the hangover, signature or not.
Old 21st February 2008, 08:55   #56 (permalink)
2005 alto - it does rev up on a morning start.
another thing that i noticed - gear in neutral and clutch engaged and then start, the vehicle starts in the first crank.
previously (ie till 2months back) i never used to do this and the time required to start used to be a bit more, some times even requiring a second crank!
is this just me, or does this 'clutch engaged' Vs 'clutch not engaged' start have any value? does it do anything to the load placed on the engine while starting?
HappyWheels is offline   Reply With Quote
Old 21st February 2008, 19:56   #57 (permalink)
headers's Avatar
The clutch engaged reduces the load on the engine..even if the geartrain is in neutral and is a good practise..
I too read about it in some auto magazine and have been startin the car always with the clutch pressed.. really dont know the significance though..i admit.
__________________
RWD Rocks!
Old 21st February 2008, 19:57   #58 (permalink)
headers's Avatar
LOL the car is just like its master..signature or not!
__________________
RWD Rocks!
Old 22nd February 2008, 01:57   #59 (permalink)
wolfinstein's Avatar
Irrespective- I Idle the engine up for 40 seconds to 1 min before converting to CNG Mode, Follow the same routine during shutdown.
With My lancer, Also the same procedure, AC switched on only after 2-3 min of running on Road.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 23rd February 2008, 22:56   #60 (permalink)
At least in the petrol swift , the manual says always start your car with the clutch fully depressed.
Thread Tools
Good morning sreenidhibr Introduce yourself 2 12th October 2007 10:58
Is Star Gas LPG kit good for Maruti MPFI-ed vehicles ? nicejits Technical Stuff 8 28th September 2007 23:08
Scorpio morning-start problem at high altitudes anupmathur Technical Stuff 2 7th September 2007 07:26
Would'nt you love this first thing in the morning? GTO Shifting gears 1 28th March 2004 01:25
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
