Old 21st May 2012, 12:00   #76
TaurusAl's Avatar
Thanked: 328 Times
Default Re: Air-con compressor in a diesel car does not trip?
Originally Posted by krivbel View Post
I have had it fixed at Girimaji Enterprises, an authorized Maruti service center many times over, and every time they told me that it was a rat problem, and the Rats have been chewing the pipes, and cables. Even after they fixing the problem, the problem persists. Finally, a mechanic was referred to me, who apparently could fix the problems. He took the Car last week.
Though your query is completely , my 2 cents -
I am surprised an authorised service centre could not fix your problem. Maybe you should meet a senior engineer of that Service Center and report your persistent problem. If still the case is not solved you can try approaching another authorised service center with a complete history, all the best.
TaurusAl is offline   Reply With Quote
Old 26th August 2016, 17:47   #77
humyum's Avatar
Thanked: 2,495 Times
Default 2016 Baleno Diesel AC Query
I have a Query, my friend recently got a 6200 km run Baleno Diesel Top version with climate control. When he showed me the car, at idling rpm the AC compressor kept shutting every 25 to 30 seconds and then after 15 seconds would restart again. I set the temperature to the lowest, fan speed to the highest, even shut off the climate control and kept everything to full, still the same behaviour. What could it be? or is this behaviour normal for Baleno Diesels? Damn irritating this.
Old 26th August 2016, 17:50   #78
rakesh_r's Avatar
Thanked: 738 Times
Default Re: 2016 Baleno Diesel AC Query
The same thing happens in my S Cross 1.6 too. Whereas in my 2010 Swift the compressor used to run continuously.
rakesh_r is offline   Reply With Quote
Old 26th August 2016, 19:27   #79
Thanked: 14,415 Times
Nothing abnormal buddy. In the top end models the ACC doesn't let the compressor running continuously.
It senses (Read calculates) the difference between the data acquired from cabin temperature sensor and solar sensor. Depending on this difference, it decides the duration for letting the compressor ON.
Same thing happens in my Swift but the compressor in my Ertiga and Alto K10 run continuously till the A/C button is kept ON.
Your S-Cross is Alpha, right?
Old 26th August 2016, 20:42   #80
Thanked: 2,375 Times
Infractions: 0/1 (4)
That means no VD compressor here. Strange in a car with ACC.
Sutripta
Old 26th August 2016, 22:49   #81
rajeev k's Avatar
Thanked: 1,749 Times
The air-con compressor would shut to control the temperature to the set level even in cars without Climate Control, if the temperature control switch is set to lower temperature levels. This, perhaps, is wired to a thermostat for temperature control. Or else why is this switch there in the first place.
rajeev k is offline   (1) Thanks Reply With Quote
Old 26th August 2016, 23:37   #82
thoma's Avatar
Thanked: 1,093 Times
I am having terrible NVH with my Micra diesel's a/c cutting off and coming on every 30 sec or so. I checked a brand new Micra D and found the same. The SA connected a pressure gauge and showed me that it cuts off once a particular pressure is reached and soon the pressure drops quickly and then the compressor turns on (or rather the clutch engages, I am not sure) at a minimum pressure. This does not happen if the fan is kept high and so I guess the cut-off-and-on is to prevent ice formation on the evaporator(?).
But why not for my Vento which too is ACC? the compressor does not cut off at all like this, which is a boon to the NVH characteristics. So I have to believe that it does not blindly dependent on if the a/c is climate controlled or not.
thoma is offline   Reply With Quote
Old 26th August 2016, 23:43   #83
Sankar's Avatar
Thanked: 4,564 Times
Sutripta
My Mk1 Octavia vRS with auto climate control comes with Sanden SD7V16 variable displacement compressor with a magnetic clutch and it turns itself on and off while in operation.
http://www.sanden.com/pistoncompressors.html
Jetta has clutchless PX variable displacement compressor with electrically controlled refrigerant control valve.
Old 27th August 2016, 06:58   #84
vigsom's Avatar
Thanked: 601 Times
Originally Posted by rajeev k View Post
The air-con compressor would shut to control the temperature to the set level even in cars without Climate Control, if the temperature control switch is set to lower temperature levels. This, perhaps, is wired to a thermostat for . Or else why is this switch there in the first place.
That knob in the picture is used just to operate a louvre which opens the air path through the heater coil.Essentially that means mixing of hot and cold air for temp control as the knob is moved from the Blue position to varying degrees of red.
In the Corolla ACC , I found that the louvre was motor operated and hence setting the temperature higher than , say the outside temp.would allow the heater louvre to open partially.
This is an inefficient way of operating an AC.
There is a temp. sensor on the evaporator and that helps the compressor cut on and off.
This is how old gen clutch operated systems work , from what I know.
The pressure switch in the circuit prevents the compressor from turning on in a low refrigerant pressure situation ; have experienced this first hand with my Corolla in Surat.
The Superking AC in my Padmini had a thermostat ring to control temperature which , to me , seemed more sophisticated.There was also a pot meter control to cut off the AC compressor during hi acceleration.
vigsom is offline   (1) Thanks Reply With Quote
Old 27th August 2016, 07:35   #85
rajeev k's Avatar
Originally Posted by vigsom View Post
That knob in the picture is used just to operate a louvre which opens the air path through the heater coil.Essentially that means mixing of hot and cold air for temp control as the knob is moved from the Blue position to varying degrees of red..
Thanks for the info and yes, in this case it is an inefficient way of control but offering passenger comfort.
rajeev k is offline   Reply With Quote
Old 27th August 2016, 10:33   #86
Thanked: 1,067 Times
The compressor of my M800 would cut off just like the room air conditioners. Earlier if the temperature was on hotter side and later (or never in hot summers) if set at the coolest level. Later on when heaters became standard in cars, the compressor would never cut off and all that the temperature knob did was to mix hot air with cold to maintain the set temperature.
In order for the compressor to cut off at a temperature set by the knob, there has to be a separate control for switching the heater on. In most cars the temperature knob just adjusts the heater and not AC.
Old 27th August 2016, 20:59   #87
Did you note when it switches off?
Switching off should only be when an abnormal condition like overheated engine, or high head pressure is encountered.
Temperature control by cycling the compressor is, I would think, reserved only for the cheaper cars. It is not comfortable, and the primary goal of an AC should be comfort. The norm is to blend hot and cold air.
Sutripta
Air-con Blower not working silver_shadow Technical Stuff 22 31st January 2018 12:09
Air-con: Center vents throwing out warmer air than side vents? 90Horses Technical Stuff 82 7th July 2015 16:03
Terrible Chevrolet Beat Diesel experience: Problems with engine, suspension & air-con GTO Technical Stuff 19 8th June 2015 07:40
Air-con repair & installation - Amjad Car A/C (South Delhi) ankur_gupta10 Delhi NCR 1 10th July 2014 16:09
High pressure car washer using air compressor recshenoy Modifications & Accessories 2 1st October 2009 09:59
