Old 4th December 2011, 09:55   #1
Thanked: 777 Times
Default Ford Fusion Clutch Judder
My mom's Fusion, a 1.6L petrol model, is now 4 years old and has run almost 50,000 kms. For the last 1 year we have been facing occasional judder & shaking of the complete car when starting from a stop. Initially we had the hydraulic system bled (as per ford advisories on this problem), and later replaced the master cylinder. The problem is not solved and does reappear off & on. I have observed that it mostly happens when the car has been driven in stop & start traffic for some time.
Ford people are clueless about likely cause. I tend to suspect the clutch release bearing, worn out clutch plate or an small chance of the pressure plate being warped slightly & getting warped more when the clutch heats up.
Has anybody faced similar problems in the Fusion or Fiesta.
sridhar-v is online now   Reply With Quote
Old 4th December 2011, 10:26   #2
libranof1987's Avatar
Thanked: 4,221 Times
Default Re: Ford Fusion Clutch Judder
50k kms is a good time to change the clutch.
The clutch plate would be worn out and hence the jerking. It would be a good idea to change the clutch cable too.
libranof1987 is offline   Reply With Quote
Old 4th December 2011, 10:50   #3
ampere's Avatar
Thanked: 9,126 Times
I changed mine at 75K.
Even till then, no clutch related issues.
Old 4th December 2011, 11:20   #4
carwatcher's Avatar
Thanked: 1,003 Times
My fusion's clutch plate and pressure plate worn out after 67k kms and I was driving with it for 2 months or so. The car used to shake when put into 1 gear and pulled with great difficulty. Sometimes it missed the gears completely and only revving noise can be heard without actual acceleration while running in 3 or 4th gear. I would request you to change the Clutch plate, pressure plate and clutch cable as also suggested by libranof1987 also due to single reason of compromised fuel efficiency.
As regards solution to my Fusion(not +) (68K kms done) clutch problems, I simply changed the car as I got another (FF+ non ABS) (34k kms done) of same age by paying 30k difference around eight months ago.
carwatcher is offline   Reply With Quote
Old 5th December 2011, 10:28   #5
Thanked: 777 Times
Thanks guys. Will change the clutch plate & related items & report back.
Old 5th December 2011, 19:44   #6
Thanked: 103,688 Times
Do keep in mind that a bad flywheel or a misaligned transmission can also cause judder.
GTO is offline   (1) Thanks Reply With Quote
Old 5th December 2011, 22:55   #7
Thanked: 660 Times
Do a complete clutch overhaul. Also change the clutch release bearing.
As GTO suggested also do check the flywheel.
Old 5th December 2011, 23:03   #8
SS-Traveller's Avatar
Thanked: 11,630 Times
Originally Posted by sridhar-v View Post
For the last 1 year we have been facing occasional judder & shaking...
Were they clueless because your car was under warranty / extended warranty at the time?
The juddering is commonly caused by a burnt/glazed/overheated friction plate which tends to grip unevenly, resulting in uneven wear of the pressure plate &/or flywheel. Replace the friction plate & pressure plate, have the flywheel faced on a lathe, change the release bearing too while you are about it, and you are good to run another 50k-60k km at least.
SS-Traveller is offline   (3) Thanks Reply With Quote
Old 6th December 2011, 10:02   #9
Thanked: 777 Times
The problems surfaced much after the warranty expired. Will do the needful as suggested by all of you. The car does only 100 kms per month so the problem surfaces very occasionaly. we have decided to hold on to the car for another 6 months before replacing it so it is now necessary to rectify the clutch. Many thanks to all.
Old 13th January 2012, 20:22   #10
GoSlow's Avatar
Thanked: 68 Times
Hi
My Fusion has done 45K kms and I have faced the same issue, although very rarely.
What was the resolution?
GoSlow is offline   Reply With Quote
Old 31st March 2012, 09:48   #11
Thanked: 777 Times
Originally Posted by GoSlow View Post
Hi
Sorry for not updating immediately. About 45 days ago I insisted that Planet Ford replace the clutch plate, pressure plate & release bearing. Actually they were very reluctant to do the change as their test drives were not revealing any problems - I literally had to blow my top to get the work done. Turned out the clutch plate had started delaminating & there were large patches in which the material had been scored out. Also the pressure plate had some scoring marks.
Now the vehicle is a dream to drive & I did give it the full throttle on many an occasion & caused heads to turn.
I also insisted on them greasing the front caliper guide pins. The rubbing noise problem in the front left wheel has now disappeared.
Many thanks guys for your suggestions.
sridhar-v is online now   (1) Thanks Reply With Quote
Clutch judder & vibrations scuderiaferrari Technical Stuff 122 7th June 2018 12:27
From Fusion to Fusion: My Ford Fusion Diesel Plus (TDCi/DuraTorq) Glass Test-Drives & Initial Ownership Reports 87 9th July 2013 19:50
Swift Diesel Clutch Judder! humyum Technical Stuff 11 29th June 2011 12:33
04' WagonR - Poor FE, Hard clutch and judder DCEite Technical Stuff 12 30th September 2008 10:17
