Old 5th December 2011, 12:23   #1
Question '02 Maruti Zen MPFI - Steering becomes hard when hot!
Hi Guys ,
My dad has a ZEN LX MPFI (75,000km and running)
It has only the normal steering system (no PS).
Such a lovely car with awesome mileage (18kmpl)
We are facing a nagging issue for almost a year and half.
Whenever the car is parked in Hot midday sun for a while and when we start the car , the steering unit becomes so rubbery and stiff :(
In heavy traffic , this problem is causing much difficulty in maneuvering.
This problem fades after driving continuously for an hour or more .
The service guys say that , it is a common issue in normal steering units
and it cannot be resolved
This problem was not there before 2 yrs.
Can anyone help me with any solution for this issue
Viki
Vignesh Mohan is offline   Reply With Quote
Old 5th December 2011, 23:01   #2
Thanked: 660 Times
Default Re: ZEN LX 2002 MPFI - Steering problem
First of check the small thingy, if its find you can move along to rack. Check the universal joint that connects the steering wheel to the rack. Its a cheap Rs.800 rod made of iron with two U joints. Normally this U is made of iron and gets rusted over time. WD 40 spray is a quick solution but in the long runs replace it.
If this joint is fine you can move on to steering rack and its related parts like tierod ends etc.
SirAlec is offline   (1) Thanks Reply With Quote
Old 5th December 2011, 23:13   #3
SS-Traveller's Avatar
Thanked: 11,627 Times
And which service guys are these? MASS?
Agreed. Hey, it's an almost 10-year old car, the rack needs some greasing and lubrication too. Have an FNG open up the rack, lube it up, replace the rubber boots if they haven't been touched recently, and fit the whole thing back again. Should take about 3-4 hours of work, and the car will feel like you have installed power steering once it comes back!
SS-Traveller is offline   (1) Thanks Reply With Quote
Old 5th December 2011, 23:36   #4
Jaggu's Avatar
Thanked: 8,685 Times
As others mentioned check the rack and steering system in general, sometimes a service does help. Also how is the tyre condition, if its worn out steering becomes hard to turn esp in a non power steering vehicle.
Jaggu is offline   (1) Thanks Reply With Quote
Old 8th December 2011, 09:16   #5
That was an Authorized service center (ASC) at chennai. If Mods agree i ll reveal the names . Not one .. all the ASCs i ve been to were not ready to fix this issue up .
Thanks for your suggestion . Could you please tell what FNG means ?
Why is that issue happening when it is in hot sun an goes away after a while as if nothing had happened . Thats why i felt it as bizzare.
BTW Can u tell me a place in chennai where i can get this lube work and rack check done ? Apart from the service centers ?
Viki
Old 8th December 2011, 12:21   #6
Friendly Neighborhood Garage.
Please check this forum.
Old 8th December 2011, 12:33   #7
Default Re: '02 Maruti Zen MPFI - Steering becomes hard when hot!
Hi Vignesh,
I faced the same problem with our Zen, except it didn't take as long for the problem to present itself. We faced the problem almost 3-4 years into it's ownership. We took the car to an ASC in Mumbai, but though, they said they fixed it, it used to recur after a few weeks or months. We were never told that it was a known issue.
We never found the problem when we had the Zen. Now that I think about it, the temperature sensitivity seems to suggest that it might have something to do with clearances and/or lubricant. Have the ASC check the lubricant and the clearances during such an "attack". Perhaps something is drying up or expanding.
messershtig is offline   Reply With Quote
Old 13th January 2013, 09:17   #8
Thanked: 337 Times
Hi Vignesh,
I too own a 2001 MPFi Zen LX (Non PS). The same problem of stiff steering crops up after the car has been parked in the sun for a while. Of course it goes away after driving for a few kilometres.
Was this problem resolved in your Zen?
If yes, then what was the culprit & what needed to be done, so that I can tell my mechanic to specifically look out for that particular issue .
Cheers !
Ironhide is offline   Reply With Quote
Old 13th January 2013, 10:41   #9
humyum's Avatar
Thanked: 2,502 Times
How much tyre pressure are you maintaining ?
Old 13th January 2013, 12:06   #10
amrisharm's Avatar
Thanked: 302 Times
We have a 2005 model Zen LX (non PS) and I do not have this problem at all on our zen. The steering is so well balanced I wonder why the zen was ever offered with PS, it just does not need it.
Anyways, could this problem be related to the older model zens? I think the last update that the zen received was in 2004 (pls correct me). Then the headlamps, rear lamps and bumpers were changed, the tyre was downgraded to R12 from R13's as well. Did maruti bring about any mechanical changes during that update to eliminate this problem?
amrisharm is offline   Reply With Quote
Hyundai Xcent / Grand i10 EPS issue: Steering suddenly becomes 'loose' RVVSatya Technical Stuff 49 28th December 2017 00:28
Invader 4x4 : Hard steering and steering box leaking DirtyDan 4x4 Technical 26 26th April 2013 13:30
'09 Maruti DZire : Steering too hard tripsme Technical Stuff 9 30th May 2012 13:06
99'ZEN carb to ZEN mpfi.... Balram Modifications & Accessories 17 10th December 2006 09:04
